| Converting Non Abs Rear wheel for tone Ring woes | |
Kennylxix Maxi-Scooter Rider
Number of posts : 156 Location : FL Points : 3140 Registration date : 2016-11-05
| Subject: Converting Non Abs Rear wheel for tone Ring woes Mon Nov 21, 2016 4:31 pm | |
| So this is where some nice pretty pictures of my newly drilled mounting holes on my replacement rear wheel are supposed to be. Unfortunately a non abs rear wheel isnt just undrilled for the tone Ring mounting holes, it also is missing a bit of machining that allows the ring to slip into place. The casting has about . 020 in taken off of the side and about. 050 in taken off the top of each mounting lug. I was able to fab up a couple tabs to mount the sensor on the non abs swing arm which went just fine. I just wasn't prepared for the other issue. Soooo next time I have the wheel off I will be prepared with some die grinder bits to take off the necessicary material. I won't be able to get it perfect but I think I can get it close enough. For now my abs is still down though |
bandito2 Maxi-Scooter Rider
Number of posts : 181 Location : Somewhere outside of the box Points : 5547 Registration date : 2010-04-04
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Mon Nov 21, 2016 5:08 pm | |
| Started to do something like that once but only got as far as tapping new threads in. Then the tap broke off in one of the holes. Cheap taps; had one break doing another project but managed to get it out because not too much of it was down in and the break was near the handle. Pretty sure I tossed that set of taps. Not sure if it was a set from HF (but probably was) Didn't even try to drill it out as it likely would have just pushed off of the piece of tap never to hit the hole center. And the rim was too big to fit in the throat of the drill press any way. Sold the rim + a tire to a buyer that did not need it to be an ABS rim. |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Mon Nov 21, 2016 5:11 pm | |
| Yeah trying to dig a broken tap put of a blind hole in aluminum usually ends in tears. I am going to keep my eyes open for an abs rim as I would would honestly rather not take a die grinder to mine. Not too worried about tapping the holes. I got rid of my hf tap and die set long ago:) |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Tue Nov 22, 2016 11:27 am | |
| Well, there's one on ebay right now for $79.20 + 12.26 shipping. (that's odd an bunch of numbers if you ask me) But it looks in as rough a shape as I have ever seen any scooter wheel. Not sure if it would even be usable in that kind of condition. But new they are something like $340. If it were me, I'd pass on that one. You might try checking at used/wrecked motorcycle type salvage yards for a wheel or just keep checking ebay. Funny, I'd see them there when I didn't want or need one. Typical. http://www.ebay.com/itm/07-Honda-FSC600-A-FSC-600-ABS-Silverwing-rear-back-wheel-rim-/400931882974?hash=item5d596707de:g:kTsAAOSwpdpVcD44&vxp=mtr |
vmaximus Maxi-Scooter Rider
Number of posts : 133 Age : 71 Location : Kirkby in ashfield Nottinghamshire England Points : 5139 Registration date : 2011-04-15
| Subject: converting-non-abs-rear-wheel-for-tone-ring-woes Tue Nov 22, 2016 7:11 pm | |
| That wheel on ebay is perfectly alight providing it is straight although a bit rough looking. My wheels where getting to look like that but after sending them off for shot blasting and a gloss black powder coat they look 100% better and easier to clean. Pud. |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Tue Nov 22, 2016 8:03 pm | |
| - vmaximus wrote:
- That wheel on ebay is perfectly alight providing it is straight although a bit rough looking.
Well, the ad does say it is straight. Maybe with a good clean up and some of that plastidip stuff people talk about, it may be a less expensive alternative to a new rim or a used one that has been bead blasted and covered with fresh powdercoat. But as it is now, it looks horrid and suspiciously unusable. |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Wed Nov 23, 2016 1:32 am | |
| Yeah I saw that one. I think I'm just going to be patient. I saw that they do sell for significantly less occasionally.
Ive never had a bike with abs before so I don't feel Ike I'm, missing anything in the meanwhile. |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Fri Nov 25, 2016 12:02 am | |
| - Kennylxix wrote:
- Yeah I saw that one. I think I'm just going to be patient. I saw that they do sell for significantly less occasionally.
Ive never had a bike with abs before so I don't feel Ike I'm, missing anything in the meanwhile. When you do have operational ABS, the first time you have to grab the brakes (like on wet pavement for instance) that might have locked up standard brakes and sent you skidding you will appreciate them. It might seem a little unnatural at first to grab the front brakes HARD and not have the bike put you down or do a stoppie or endo. |
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Fri Nov 25, 2016 12:04 am | |
| I definitely think I will appreciate them and be a little less likely to sit out rain. I've seen videos comparing with and without and abs on a bike is definitely a good thing! |
Number of posts : 222 Age : 70 Location : uk saddleworth Points : 4037 Registration date : 2014-08-24
| Subject: Re: Converting Non Abs Rear wheel for tone Ring woes Wed Oct 18, 2017 5:55 pm | |
| - Kennylxix wrote:
- So this is where some nice pretty pictures of my newly drilled mounting holes on my replacement rear wheel are supposed to be.
Soooo next time I have the wheel off I will be prepared with some die grinder bits to take off the necessicary material. I won't be able to get it perfect but I think I can get it close enough. For now my abs is still down though I have just done the front wheel and am starting on the rear is the .050 in on the rear mtg. points right? |
