gremlin Super Scooter Rider
Number of posts : 227 Age : 72 Location : Brisbane, Australia Points : 3782 Registration date : 2015-04-09
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Nov 28, 2017 10:52 pm | |
| - Bash On! wrote:
- I'd worry about liability in case of a mishap. Especially because the Honda Owner's manual (2010 MY edition used) says this:
Do not pull a trailer or sidecar with your scooter. This scooter was not designed for these attachments, and their use can seriously impair your scooter’s handling.
Disclaimer: I'm a lawyer, but I'm not your lawyer. This post does not constitute legal advice, nor does it create an attorney-client relationship. I totally agree and cannot comprehend why on this forum everyone seems to ignore the manufacturers advice and specifications, when it comes to such an important issue and merrily discuss the various options of going against this advice. |
willajabir Maxi-Scooter Rider
Number of posts : 161 Location : Birmingham, AL Points : 4736 Registration date : 2012-08-21
| Subject: Re: Trailer Hitch For SilverWing Scooter Mon Dec 11, 2017 11:59 pm | |
| - Hcastillo64 wrote:
- Hi I have a 2003 SW with 37000 miles and still going. Do you think my wing could pull a small trailer.
I think so. 2004 Models. Toured the lower 48. The burgandy one towed a trailer for about 30k miles. The silver one was close to 50k. Disclaimer: Owners manual does say not to do it. Of course the OM (page 5) also says not to add anything not designed by Honda, so top cases, grips, seats, after market windscreens, GPS, power outlets, etc are all to be avoided. Bolt on hitches are usually covered by insurance (USA) and frame modded add on hitches like those made by Joe Wolfe should probably be mentioned to your insurance company. Mine was covered with no additional premiums. Got as low as 52 mpg in WV and as high as 62 mpg crossing the salt lake flats and Utah. Attempting to cover any additional thoughts/questions you might have. You can view more of my Swing photos HERE that show some closeups. As a side note. My brother had a minor accident(not his fault) that removed his right trailer wheel about 4 hours after this photo. I turned his trailer upside down and mounted it on top of mine for a little over an hour to a shop to get him back on the road. |
Number of posts : 237 Age : 74 Location : Morecambe, Lancs., UK. Points : 3367 Registration date : 2016-06-03
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Dec 12, 2017 5:44 am | |
| I've considered a trailer for camping trips, but the only hitch I've seen so far is bolted to the rear axle/brake/swing arm and doesn't make sense to me. Attaching it there subjects the hitch attachment to all the road shocks normally absorbed by the suspension. A frame mounted hitch will not suffer in the same way.
Willajabir, is yours a commercially available kit? Is it welded and/or bolted to the frame? Any info appreciated.
Paul. |
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Dec 12, 2017 9:07 pm | |
Paul. Paul, I got in touch with a scooter rider/modder in Kingsport, Tn named Joe Wolfe. Got his name & contact from another inmate here. I just looked back and see you are from the UK. I'll venture a guess that you could find a tinkerer somewhere near you that could do the same. I've had 3 made for my scoots and they all were made with flat steel welded to the side frame in a triangular shape, then attached to square tubing that came down just short of the mud flap. Holes drilled in the tubing for hitch pin to hold a smaller size tube so I had a removable hitch. Pulled the trailer wiring through a hole made behind the tag so the wiring would hide behind the tag when not in use. |
The Bern Silver Wing Expert
| Subject: Re: Trailer Hitch For SilverWing Scooter Wed Dec 13, 2017 6:10 am | |
I'll venture a guess that you could find a tinkerer somewhere near you that could do the same. Sadly it doesn't work like that in the UK/Europe Willajabir, towing hitches have to be 'type approved' when fitted to vehicles manufatcured after 1998, meaning the maker has to be registered & designs tested for various criteria. However, there is one Silverwing in East Anglia that tows a trailer & apparently has all the necessary documentation, IIRC he brought it from America, looked to be well made & well thought out (given the limitations of a bolt on fitment), can't recall the makers name but it was deffo tubular steel & attached at the top suspension mounts & the exhaust bracket |
| Subject: Re: Trailer Hitch For SilverWing Scooter Wed Dec 13, 2017 10:14 am | |
| - willajabir wrote:
I got in touch with a scooter rider/modder in Kingsport, Tn named Joe Wolfe. Got his name & contact from another inmate here. <> Larry Is Joe Wolf still in the game? I thought that he stopped fabricating "stuff" many years ago. At least for Silverwings. However you seem to have had him fabricate a hitch more recently. If you have a link, please post it. How about some detailed photos of your Joe Wolf hitch and its mounting configuration. Tim |
| Subject: Re: Trailer Hitch For SilverWing Scooter Wed Dec 13, 2017 4:33 pm | |
Tim Tim, I don't know if he still makes things or not. I talked to him last month, but not about fabricating anything. I'll ask him and reply here. Nothing detailed as far as under the hood. I have a close up of the hitch on my Burgman with the trailer connected and a distant one with the Swing. HERE is my album from 2011 with the hitch on the Burgman. HERE is my album of the 2004 Swing. After restoring the last Swing, a family member unrestored it. |
| Subject: Re: Trailer Hitch For SilverWing Scooter Mon Jan 08, 2018 7:25 pm | |
| I think I've waited long enough for a response. I contacted him(Joe Wolfe) twice since my last post and got no reply. |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3600 Registration date : 2015-10-10
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Jan 09, 2018 9:21 am | |
| Denray in Canada.
https://www.denray.ca/produits/produits.php?cartId=20090901155133LaHXTd1ajnfENBX10367&categorie=attachessearch |
vmaximus Maxi-Scooter Rider
Number of posts : 133 Age : 71 Location : Kirkby in ashfield Nottinghamshire England Points : 5137 Registration date : 2011-04-15
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Jan 09, 2018 3:25 pm | |
| The Bern, i have a trailer hitch fitted to my Silverwing made by myself similar in design to Dennis's hitch. My previous full insurance for a Majesty 125cc came stating that the scooter was allowed under the motorcycle insurance policy to tow a trailer. When I fitted the tow bar to the Silverwing I informed my insurance company that I intend to tow a legal camping type trailer and would I be covered under my insurance policy, they contacted the underwriters and replied that it would be ok to tow a trailer and that the bike rider and pillion would be covered fully comprehensive and the trailer would be insured 3rd party while it was coupled to the insured bike. Both insurers never asked me who, where and how the tow bar is fitted or for that fact whether it was type approved or not. When insurance renewal time (multi bike policy) comes around I always make a point of mentioning that I tow a trailer behind the S/wing and that I am still insured to do that as per previous years insurance and up till now I have had no problems. I was of the opinion that type approval was needed if more that one made that's why a one off custom type car/bike doesn't need type approval but please correct me if I am wrong. Pud. |
ItBeMe Maxi-Scooter Rider
Number of posts : 169 Age : 77 Location : Carrollton, GA Points : 2825 Registration date : 2017-09-29
| Subject: Re: Trailer Hitch For SilverWing Scooter Tue Jan 09, 2018 5:04 pm | |
Tim Tim, I don't know if he still makes things or not. I talked to him last month, but not about fabricating anything. I'll ask him and reply here. Nothing detailed as far as under the hood. I have a close up of the hitch on my Burgman with the trailer connected and a distant one with the Swing. Tim thanks for posting the trailer pictures. I think I will build one. |
carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2963 Registration date : 2018-01-22
| Subject: Trailer Fri Mar 02, 2018 3:27 am | |
| This thread has tons of great information about the hitch and trailer but the one thing that is missing is the electrical aspect.Is there a clean and professional looking way to attach trailer wiring to the Silverwing? |
joerider101 Scooter Rider
Number of posts : 4 Location : Riverview Points : 1139 Registration date : 2021-10-14
| Subject: How do i purchase a trailer hitch Sun Jul 03, 2022 10:00 pm | |
| I like the hitch ..how do i buy one or can someone send me a link for a hitch...would like a trailer too
BrianInVA Super Scooter Rider
Number of posts : 295 Location : VA Points : 1298 Registration date : 2022-04-17
| Subject: Re: Trailer Hitch For SilverWing Scooter Mon Jul 04, 2022 12:28 am | |
| - joerider101 wrote:
- I like the hitch ..how do i buy one or can someone send me a link for a hitch...would like a trailer too
I picked up a good quality Chinese (not Harbor Freight) motorcycle trailer on Facebook Marketplace for $300. It was already titled/registered but be careful, if they’re not it can be a real headache getting your state to register it. Since I’m using it to build a micro camper to pull with my Silverwing, I didn’t need the big cargo box on top. |
| Trailer Hitch For SilverWing Scooter | |
