Fitting Side Wind Deflectors I_icon_minitimeby JohnyC Today at 5:39 am
Fitting Side Wind Deflectors I_icon_minitimeby JohnyC Yesterday at 10:04 am
Fitting Side Wind Deflectors I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Fitting Side Wind Deflectors I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Fitting Side Wind Deflectors I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Fitting Side Wind Deflectors I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Fitting Side Wind Deflectors I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Fitting Side Wind Deflectors I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Fitting Side Wind Deflectors I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Fitting Side Wind Deflectors I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
willajabir
RazorbackUofA
Pastor Ron
Scootypuff Snr
ericclapham
churchmouse
mymuk
Olivertse
Flyingpanman
bikerboy
Maxaryaman2004
Sidewinder Pilot
Jolly Bodger
22 posters
Jolly Bodger
Number of posts : 105
Registration date : 2016-10-05
Fitting Side Wind Deflectors Empty
PostSubject: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeTue Apr 25, 2017 8:48 pm
Bought these a while ago and finally decided to look at fitting them.
The kit comes with 2 pathetic little studs to hold the Deflectors in place!  I know that they are attached with the adhesive strips but if that was to fail for any reason, I doubt that the 2 little studs would be strong enough to hold them.
The engineer in me says use half a dozen self tapping screws.
The question to those that have fitted them - What did you Use?
JB
Sidewinder Pilot
Sidewinder Pilot
Number of posts : 200
Registration date : 2015-05-21
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeTue Apr 25, 2017 9:06 pm
When I received mine, I thought the same thing.
I settled for a SS sheet metal screw at each end, and used the adhesive tape as provided.
It's worked without any issues since last year.
They will definitely help with the trouser flap! Smile
Maxaryaman2004
Registration date : 2016-04-17
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeTue Apr 25, 2017 11:53 pm
I've had mine on my scoot for a year now. I followed the installation instructions to a 'T', and used only the 3M adhesive supplied, as well as the single 'stud' that goes on each side.
I can left the adhesive to 'cure' in the warm summer sun for a day before riding the scoot and have had not troubles at all. Here in the Canadian prairies where we regularly get winds, sustained at 35 kmph with gust to 70, I not had any issues. I've also ridden at speed near 180 kmph for extended periods of time and have had not issues at all.
bikerboy
Number of posts : 405
PostSubject: Fitting side wind deflectors   Fitting Side Wind Deflectors I_icon_minitimeWed Apr 26, 2017 4:42 am
Mine worked fine with the adhesive strips, just make sure that you do it in warm conditions and give the adhesive time to harden.  The plastic stud is removable so that you can take off the body panel it's fastened to when needed.
Flyingpanman
Flyingpanman
Number of posts : 237
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeWed Apr 26, 2017 5:03 am
One of my plastic rivets keeps working loose, so I'll be using a s. steel self-tappers top and bottom.
The self adhesive strips have held fine. In fact, they would be the biggest problem if I ever needed to remove/replace the deflectors.
Olivertse
Olivertse
Number of posts : 4
Registration date : 2017-05-04
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu May 04, 2017 9:24 pm
Hi, I've seen them on eBay. Just wondering, are they any good after fitting them on. They are very expensive £109.00 . I wanted to be sure they are with the purchase and not just for looks. Thanks
Number of posts : 3837
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeFri May 05, 2017 2:52 am
One of the few add-ons which really are of benefit - worth every penny.
mymuk
mymuk
Number of posts : 11
Registration date : 2017-08-17
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Aug 17, 2017 9:14 am
That's the impression I got. Just purchased one of the last two sets I could find online: Ebay item 161965937250
churchmouse
Number of posts : 3
Registration date : 2017-02-28
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeSun Sep 03, 2017 10:35 am
Hey Maryann or anyone. Where did you find the wind deflectors?. I have searched and not found any except for some outrageously expensive in the UK.
Help, please? Smile If you want to email me at cp@cpedley.com I would appreciate it immensely!
-Churchmouse
http://charlespedley.com
Number of posts : 2008
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeSun Sep 03, 2017 11:34 am
Unfortunately the wind deflectors are not readily available in north America.
You can find David Silver Spares, and Chiswick Honda online. Both are known to ship overseas.
My recommendation is if you are in North America, buy two pair and make sure you only pay shipping for one pair. Tell them to put both pair in the same box.  Yes they both fit in the stock box for one pair.
Why? 2 reasons:
1:   If you go down, the wind deflector will be the first to hit the pavement and crack.  Then you will need a replacement, and you will already have it, without the hassle or expense of having to pay for shipping for another pair, which is a significant part of the overall cost.
2:   You can look for someone on the board who also needs them and split costs.  Its cheaper to have two pairs sent to you and then the cost of forwarding one pair to someone else, then to pay overseas shipping for two items.
There was an aftermarket company that was selling what they called wind deflectors, on ebay. This consisted of a piece of thick rubber (Think the center treaded section of a car tire) and some mounting kit.
You attached it to where your feet go, and it bent up in the area in front of your feet. It did the job and a much lower cost, but it was very utilitarian. No curves, Very inelegant, didn't look great.
Don't see it on ebay now, so it may have been discontinued due to lack of demand.
Good luck.
Dan
ericclapham
ericclapham
Number of posts : 106
Registration date : 2014-01-30
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeSun Sep 03, 2017 9:17 pm
Initially, I fitted the Ebay el-cheapo type. The pair I had were made of garden edging material and worked well but did look bit agricultural. Then I fitted the OEM Honda ones a year ago, as per the instructions and to date, have had no problems. I managed to track down a set in the UK from "doble.co.uk". I don't know if they still stock them. Total cost then was GBP81.80 inc. postage to OZ.
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 4:45 am
They had a few 'new old stock' (NOS) that were sold off cheap, all gone now & back to full price 'new new stock' now
Number of posts : 4218
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 5:02 am
Hi bud, I've came across the odd pair of wind deflectors on various Honda dealers and spares websites down to the £80 mark when they're usually £110. Isn't the price drop down to the FJS Silver Wing being a discontinued model. I've also noticed that the newer SW-T Silver Wing has been gradually phased out in the last few years by some European Honda importers.
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 8:42 am
Hi bud, last summer when I gave it a good service & tidy I got a pair of NOS off Dobles for about £65 +p&p, when I had my 'off' this spring I went back to them for replacements & they were £116 including p&p I remember because Mrs.B commented on how little plastic you got for your money these days
Scootypuff Snr
Scootypuff Snr
Number of posts : 230
Registration date : 2017-04-21
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 2:06 pm
That's Dobles, "robbing dogs" dealership but i wanted a set and had to pay up or shut up.
Pastor Ron
Number of posts : 400
Registration date : 2013-02-24
PostSubject: Hi Bud   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 2:21 pm
I put mine on with adhesive only, 5 years ago and it is still working perfectly. I bought mine in the UK I do not remember from whom
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 2:40 pm
I hardly see how Dobles are robbing anyone, I paid my Honda dealer the 2010 price to have wind deflectors, heated grips, and a Givi Monorack fitted when I took delivery of my new Silver Wing. I've never regretted spending any of that extra cash, I bought and fitted an Airflow after a few rides behind the rubbish OE screen and for me my maxi was sorted.
As you bought used, you could have easily looked around like others have and bought a Silver Wing with wind deflectors and other toys already fitted. There's a lad on the Muppets just bought a used 2012 Silver Wing with wind deflectors, a Givi screen, and a Honda top box fitted.
Over the years I've been on this forum there's always been a bit of resentment from some owners about the Honda leg wind deflectors, (a) because they were never made available in the US, and (b) they didn't want to pay the combined cost of buying a set and having them shipped to the USA.
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Sep 04, 2017 3:49 pm
Nah, not "robbing dogs" at all bud, they sold off the old stock cheaply because the boxes were dirty &/or damaged due to extended storage/movement, my point was that when our other member found them at a reduced price NOS was the reason, I was not gripeing about the regular cost.
RazorbackUofA
RazorbackUofA
Number of posts : 85
Registration date : 2017-04-23
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Oct 05, 2017 9:00 am
chickendance
Fitting Side Wind Deflectors 20806612
RazorbackUofA
RazorbackUofA
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Oct 05, 2017 9:02 am
Fitting Side Wind Deflectors 20773310
Fitting Side Wind Deflectors 20806510
Fitting Side Wind Deflectors 20806715
Fitting Side Wind Deflectors 20813411
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Oct 05, 2017 9:38 am
affraid OMG!
Where's yer Fazer, lad?
RazorbackUofA
RazorbackUofA
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Oct 09, 2017 12:27 am
all need now is a grill and fridge
willajabir
Number of posts : 161
Registration date : 2012-08-21
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeMon Oct 09, 2017 11:10 am
And now that you have custom made an automatic Goldwing, rumor has it that Honda is releasing one this month. Of course the Honda version will be substantially higher.
Siataukreg
Siataukreg
Number of posts : 222
Registration date : 2014-08-24
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeSun Oct 15, 2017 5:58 pm
Just bought a set for mine think they were around £85 from this place www.ajsutton.co.uk
barthezo
Number of posts : 1
Registration date : 2017-12-25
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Jan 11, 2018 8:56 am
I'm just about to bring wind deflectors for my silverwing.
Are got guys have been talking about these ones?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F161965937250
Are they good? Can you feel a big difference in cold days?
Sent from Topic'it App
v23nb
Number of posts : 36
Registration date : 2017-12-27
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeThu Jan 11, 2018 9:28 am
I bought my swing from Dobles. It had those same leg deflectors fitted on instruction of the previous owner and had been done by Honda mechanics to the original instructions. I have no worry about the fit. I haven’t ridden without them so can’t do a proper comparison but found them pretty good. I currently also have a Tucano Urbano leg cover fitted (will probably come off at the end of next month) which fits no problem despite having the leg deflectors in place. I have been riding on seriously wet roads in driving rain and always arrive dry as a bone.
gavinfdavies
Number of posts : 137
Registration date : 2017-10-20
PostSubject: Re: Fitting Side Wind Deflectors   Fitting Side Wind Deflectors I_icon_minitimeSat Jan 20, 2018 2:11 pm
I've fitted mine over winter while I had the fairing off waiting for my givi screen to arrive. I made two little tweaks to the instructions: I move the lower pop-rivet up a couple of inches so that it attaches to the main fairing panel, hence I don't need to remove it when taking off the fairing. I also added a bead of grey silicon sealant to the front edge to stop water and crud being blown into the gap where the adhesive tap lives. They seem to work well. The grey silicon isn't an exact match for the silver paint, but close enough.
» Wind deflectors fitting tips or advice required
» Side Wind Deflectors
» Wind deflectors
» Honda Leg Extensions too expensive
» foot pegs??
