Warning, battery related I_icon_minitimeby JohnyC Today at 5:39 am
Warning, battery related I_icon_minitimeby JohnyC Yesterday at 10:04 am
Warning, battery related I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Warning, battery related I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Warning, battery related I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Warning, battery related I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Warning, battery related I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Warning, battery related I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Warning, battery related I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Warning, battery related I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Modernman1953
8 posters
Number of posts : 1935
Warning, battery related Empty
PostSubject: Warning, battery related   Warning, battery related I_icon_minitimeMon May 29, 2017 10:03 am
When I was waking up the S'Wing this spring I noticed some " white powder " on the area below the battery cover, took cover off and found corrosion around the negative terminal. This was on a Power Source sealed battery. I set it aside and replaced it with a new battery. Today I used it as a power supply to test horns. The battery had been in the upright position but it still developed a very noticeable pile of corrosion around the same terminal, this sealed battery apparently is leaking around the base of the terminal. It's easy to forget a battery when it's working but a check on it's condition may save a headache in the future.
Modernman1953
Number of posts : 379
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeMon May 29, 2017 10:57 am
Sorry you are having troubles.
I take my battery out of the bike if the bike is going to be dormant for awhile and bring the battery inside and keep it on a battery tender.
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeMon May 29, 2017 11:21 am
Thanks it was in a warmer than outside garage on a tender. I was just surprised to see a sealed unit leak like this one, hidden under the battery cover it went unnoticed for a couple months.
Number of posts : 757
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeMon May 29, 2017 11:31 am
Heads up ! Thanks.
Jay.
Modernman1953
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeMon May 29, 2017 3:34 pm
Bummer. Did fluid leak out onto the bike? Any damage you can see?
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeTue May 30, 2017 1:22 am
Just old school but I still have the habit of greasing the terminals after the cable is connected. It does tend to reduce corrosion from condensation around the terminals.
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeTue May 30, 2017 8:24 am
None noted, just the white powder / corrosion, I laid it on it's side for a couple days and no liquid seen.
Jolly Bodger
Number of posts : 105
Registration date : 2016-10-05
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeTue May 30, 2017 8:45 am
".....honestly officer it's off the battery!!!"  clown
JB
Number of posts : 1999
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeThu Jun 01, 2017 1:29 am
For what it's worth: I've had my Lithium Ion Battery Tender battery in my 08 Swing for a couple of years now with no problems. In the winter I put the Battery Tender Jr. on about every other month just to bring up the charge. There's no acid to leak and so far so good. It starts the SWing with no problems and everything operates great.
Although I've read that they aren't the best in cold weather but seeing as I DON'T ride in cold weather it works great for our two weeks of summer here in Minnesota... :lol!:
Number of posts : 1037
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeFri Jun 02, 2017 2:26 pm
JB
... imported from Columbia... ?
Greysilver
Greysilver
Number of posts : 493
PostSubject: Re: Warning, battery related   Warning, battery related I_icon_minitimeFri Jun 02, 2017 3:36 pm
I put a battery tender on my battery about every two weeks or after a ride. So far so good. Battery is about a year old.
» Dead battery ???
» Not SWing related, but.
» 2 Wheel Related but not on Scooter
» English Rant - non bike related.
» Interesting on greasing related to tire change
