| Enriching Fuel mixture: IAT Hacking | |
| Subject: Enriching Fuel mixture: IAT Hacking Wed Jun 14, 2017 10:32 pm | |
| Further to Lloyd193's earlier post regarding hacking the engine coolant temperature (ECT) sensor to enrich the fuel mixture is this post detailing hacking the IAT sensor from "another" Silverwing forum:
- By Dutchwing Date 2014-03-12 05:12
It was time to do some big maintenance on my FJS600A 2007 with 23.000km. I live in The Netherlands and the Honda Dealer is so expensive that even with buying some extra tools (like torque wrench etc.) it's cheaper to do everything myself... Also ordering parts online (especially in Italy) saves a lot of money.
List of what has been done:
[Edit: What followed then was a long list of various standard maintenance and upgrades the OP performed]
But what was really necessary and is not really well documented for this motor scooter: installed home brew IAT modification!
*** Note: When the complete exhaust is exchanged with a wide pipe exhaust without catalyst converter AND the "open" K&N air filter is installed the air-fuel mixture gets too lean during acceleration. For continued closed loop operation with the O2 sensor it's fine because the lean mixture will be compensated by the ECU but during acceleration the ECU works open loop and will be too lean. That's why I decided to think out-of-the-box and come up with a solution for that.
On the internet numerous articles can be found about "tuning boxes" that "modify" the signal from the IAT. Basically, the IAT is just a simple NTC resistor and it has a certain characteristic. If some other resistance is put in series with the IAT sensor the total resistance will be higher and the ECU thinks the temperature is colder. However, just adding a fixed resistor does not work because the curve is not linear. Some tuning boxes have internal "compensation" for that and lots of other claims but in the end the ECU just needs to be tricked to "see" a 20 degrees Celsius colder air than what it is in reality. This will add approximately 6% fuel to the mixture. So why putting a +$150 box in series with a cheap temperature sensor instead of just replacing the cheap sensor itself? So I took out the original Honda IAT and measured its curve (put it in the fridge with -18C, 0C, in water of 10, 20, 30, 40 and 50C and had Excel draw a nice curve through the dots. Then I shifted the curve by 20C and got a much steeper curve to fit the new NTC in. Comparing the curves of numerous commercially available NTCs I found one that pretty well fits and the best feature of it is that it's an ordinary NTC that is also used in airco systems and it comes in a nice sturdy plastic molded housing. The price is around 12 euro so a bit more expensive than an ordinary NTC but this one really fits well. The size of the housing is 8mm round and that's exact the size of the original sensor. So I drilled the original sensor out with an 8 mm drill and glued the new one in so I could use the old sensor housing as mount for the 2 screws. Connected the wires with soldering and some crimp-tube and that was it!
Result of this is that the engine now runs very well, no more "lean fuel" hesitation and in combination with the K&N filter and "street legal" Laser exhaust with added O2 sensor it's really fun to drive. Reaction on quick throttle changes used to be a bit tame, now it's much more aggressive and really wants to accelerate. Even with a passenger it easily tops +180Km/h on the speeddial without hesitation and with a new belt, while the rpms are even a bit lower due to the new belt. Of course the JCosta helps a lot too...
For those who would like to get rid of the lean mixture, the NTC I used is the Epcos B57020M2502A0001 and it's relatively easy to replace. The deviation is small, aim is -20C in the range between 0 and 40C and it does -14C at outside temp of 0C and 19C at outside temp of 40C (hence between 14 and 21C under outside temperature). So the enrichment gets a little more at higher temperatures which is nice to keep the engine cooler in a hot summer. Note you won't see a noticable fuel consumption change. The enrichment of max 6% is only active during acceleration. During constant speeds the ECU works with the lambda (O2) sensor in closed loop mode. In case the NTC is disconnected an error will be logged by the ECU and internally it will work with a fixed value that corresponds with 25C. http://www.conrad.nl/ce/nl/product/182800/NTC-temperatuursensor-Epcos-B57020M2502A0001-M-2020-40-tot-60-C-Soort-behuizing-Kunststofbehuizing-met-aansluitkab?ref=searchDetail
Temp C Original EPCOS 5K -20 22853 48614 -15 17272 36503 -10 13054 27680 -5 9866 21166 0 7456 16330 5 5635 12696 10 4259 9951 15 3219 7854 20 2432 6246 25 1838 5000 30 1389 4028 35 1050 3266 40 793 2664 45 599 2185 50 453 1803 55 342 1495 60 259 1246 65 195 1044 70 147 878
Last edited by Cosmic_Jumper on Fri Jun 16, 2017 4:03 pm; edited 1 time in total (Reason for editing : Content) |
| | | terrier Touring Scooter Rider
Number of posts : 302 Age : 75 Location : Northumberland, UK Points : 3726 Registration date : 2015-08-12
| Subject: Re: Enriching Fuel mixture: IAT Hacking Thu Jun 15, 2017 1:50 pm | |
| Wow |
| | | DickO Founding Member
| Subject: Re: Enriching Fuel mixture: IAT Hacking Thu Jun 15, 2017 5:27 pm | |
| Huh ?? |
| Subject: Re: Enriching Fuel mixture: IAT Hacking Thu Jun 15, 2017 5:50 pm | |
| Yeah guys, it's a pretty long post, a lot of which is not to the point, but I figured that I'd post it in its entirety. Actually the meat of the post is pretty good technical information.
And again, it's more so intended for we who can't leave well enough alone.
| | | Japcati Scooter Rider
Number of posts : 60 Location : Ireland Points : 1326 Registration date : 2021-06-16
| Subject: Re: Enriching Fuel mixture: IAT Hacking Wed Jun 16, 2021 9:37 am | |
| Very interesting read this,does this mod do away with the need for a Power Commander or a custom map on a dyno? |
| Subject: Re: Enriching Fuel mixture: IAT Hacking Wed Jun 16, 2021 11:30 am | |
| - Japcati wrote:
- Very interesting read this,does this mod do away with the need for a Power Commander or a custom map on a dyno?
First I want to congratulate you on your expeditious use of the forum Search function. As you’ve discovered there is a wealth of information to be found here. To your question: An IAT mod is not going to take the place of a Power Commander. The IAT mod is more so a poor man’s Power Commander. If you do decide to use a PC you’ll realistically also need to have access to a dyno to custom map. It’s been several hears since I had a PC and I was never impressed with three or so maps which come with the PC. However I suppose that if you’re going to do a lot of free breathing mods to the Silverwing then a custom mapped PC will be needed. Somewhere I may have a photo of BJ’s Hayabusa-mufflered Silverwing. I’ll have to look in my stuff. |
| Subject: Re: Enriching Fuel mixture: IAT Hacking Wed Jun 16, 2021 2:12 pm | |
| Hi,thanks for the reply and info. If you could dig up that photo of the hyabusa exhaust,then I'd really appreciate it. Thanks. |
