| Clutch modifications | |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3316 Registration date : 2017-05-13
| Subject: Clutch modifications Fri Jun 23, 2017 11:20 am | |
| Experimentation with modified Variator's and Malossi torque springs have revealed the following. Using the stock clutch springs works best along with the White Malossi Torque spring in the fact that it allows the clutch to fully engage sooner than with stronger clutch springs and forces the rollers to remain further down in their channels in the variator. All the modifications I have explained have no negative effects on street use and performance other than the slight loss of fuel mileage caused by the rider using his tremendously increased performance more often. Since the belt has climbed to its highest position by about 60 MPH Highway mileage is not effected. Delaying the clutch engagement with stronger springs brings on unnecessary wheel spin and results in higher ET's than use of the stock clutch springs. No clutch slippage is experienced with these modifications. Using the #1 setting on the rear shocks also results in less wheel spin as it allows the bike to transfer weight to the rear wheel during acceleration, Resulting in a better ride and better handling and the moderate wheel stands I have reported as all weight of the bike and rider are transferred to the rear wheel. Some of the posters here will not agree with what I have reported as they have lamely demonstrated in the past, My reports are based on years of experimentation and success on hundreds of bikes, not theory or wet dreams. Using the explained modifications may result in the V lamp occasionally illuminating, The reason being that we have varied from the look up table limits programmed into the Computer, Resetting the V lamp is a simple process. Happy motoring lloyd 193 |
| | | E.D. Scooter Rider
Number of posts : 42 Age : 77 Location : Tampa Bay, Florida Points : 3144 Registration date : 2016-05-29
| Subject: Re: Clutch modifications Sat Jun 24, 2017 1:05 am | |
| Yes Malossi has some good springs. The white torque spring also works well in the Burgman 400. I didn't use it in mine, but others have said it worked for them. Cheers! |
| | | Easyrider Silver Wing Guru
| Subject: Re: Clutch modifications Sat Jun 24, 2017 1:34 am | |
| - lloyd193 wrote:
Delaying the clutch engagement with stronger springs brings on unnecessary wheel spin and results in higher ET's than use of the stock clutch springs. Should it not lower the ET's? |
| Subject: Re: Clutch modifications Sat Jun 24, 2017 8:55 am | |
| Seems to me that a Dr Pulley HiT Clutch, which can be adjusted to lock-up at whatever rpm desired, would be ideal for your application.
I'm sure that an up-rated contra spring would help with the Hit Clutch too. But I just cant wrap my head around how the interplay of changed variator weights and up-rated contra spring works --even though Sidewinder Pilot has made several excellent posts regarding that very subject.
Lloyd, your lighter weights, heavier contra srping seems to be the opposite of "conventional" wisdom which is "heavier variator weights, heavier contra spring". But then maybe your variator & clutch mods are more focused on drag racing type performance rather than improved daily use performance.
| Subject: Re: Clutch modifications Sat Jun 24, 2017 11:59 am | |
- Seems to me that a Dr Pulley HiT Clutch, which can be adjusted to lock-up at whatever rpm desired, would be ideal for your application.
Lloyd, your lighter weights, heavier contra srping seems to be the opposite of "conventional" wisdom which is "heavier variator weights, heavier contra spring". But then maybe your variator & clutch mods are more focused on drag racing type performance rather than improved daily use performance. A variator works by weights climbing ramps to increase the diameter of the variator, By applying more resistance to the variator, The Torque spring. the weights can not climb the ramps as fast. The lighter weight of weights is affected less by the syntrifical forces and remain lower on the ramps longer. Thus increasing the ratio of the variator as compared to the driven pulley. A lighter clutch spring appling more load sooner to the variator accomplishing the higher torque curve that we seek. All these things work in unison to greatly increase the bikes acceleration. Anyone riding one of my silverwing scooters will go home and throw rocks at their silverwing. Performance is accomplished by many seemingly small changes, There is no one item improvement that offers outstanding improvements other than supercharging and or use of fuel. Incidently My AA/A that I built (Tube Chassis car) used a Blown Olds 340 Cubic inch Engine, 1400 lb car did the Quarter mile in 9.5 seconds @ 165 MPH, (6-71 GMC blower) on pump gas in 1960. I am no newbie to performance and how to get it. Happy motoring lloyd 193. |
| Subject: Re: Clutch modifications Sat Jun 24, 2017 1:56 pm | |
| - Easyrider wrote:
- lloyd193 wrote:
Delaying the clutch engagement with stronger springs brings on unnecessary wheel spin and results in higher ET's than use of the stock clutch springs. Should it not lower the ET's? Wheel spin increases ET's, That is the reason maximum traction is sought by all knowledgable drag racers. We want increased acceleration, Not increased wheel spin. Maximum weight transfer also fits into this puzzle. Happy motoring lloyd 193. |
| Subject: Re: Clutch modifications Sat Jun 24, 2017 2:33 pm | |
| Perhaps you mean to say maximum wheel speed (along with increased traction) increases ET's. Reduced traction = increased wheel spin = increased higher ETs. However IMHO stronger clutch shoe springs causes the clutch to engage at a higher rpm and closer into the power band. 'Tis a puzzlement |
