First topic message reminder :
I've just overhauled my rear brake caliper. Soda blasting, new pistons, new seals, new banjo joint washers. Also overhauled the rear master cylinder. Clean up, new piston and seals kit and new banjo joint washers. Now I'm trying to bleed them.
Bought a vacuum pump system which seems to doing the job of sucking the fluid through. Did the front caliper first then the rear. The system has been drained of all fluid so I'm starting with empty lines.
The front one kind of went OK, I think, but the rear one just keeps pouring air bubbles out. The brake lever is offering 'no resistance' at all. I've used half a litre of fluid so far and I would have expected at least some resistance from the lever by now. The only result so far is that the caliper pistons have moved from the fully home position to resting against the pads, but no pressure from the lever.
Does anyone have any experience of this or have any tips or tricks. I don't want to waste any more fluid until I'm sure I'm doing it right.
