Brake bleeding. I_icon_minitimeby JohnyC Today at 5:39 am
Brake bleeding. I_icon_minitimeby JohnyC Yesterday at 10:04 am
Brake bleeding. I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Brake bleeding. I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Brake bleeding. I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Brake bleeding. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Brake bleeding. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Brake bleeding. I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Brake bleeding. I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Brake bleeding. I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Brake bleeding.
3 posters
JamieB
JamieB
Number of posts : 224
Brake bleeding. Empty
PostSubject: Brake bleeding.   Brake bleeding. I_icon_minitimeMon Mar 26, 2012 2:52 pm
Hi all,
I have changed brake fluid for both brakes today due to the age.
The front lever is far better now and the front brake is very good.
The left bar brake is far better now as well, but with constant bleeding the lever does come a lot further back than before but does not touch the bar.
Any thought at all would be great as the brakes were fine, but i am a little un sure on the left one.
Pads are all fine.
masscoot
masscoot
Number of posts : 438
PostSubject: Re: Brake bleeding.   Brake bleeding. I_icon_minitimeMon Mar 26, 2012 8:51 pm
A belated welcome to you!
I just did front and rear brakes this weekend. What I found on the front was a leaky bleed valve (for the middle piston). I could not get the bleeder vacuum pump to hold. After about 20 minutes I discovered the leak. I removed the bleed valve and used some teflon tape to seal it and was able to get the vacuum to hold. Not sure this helps. My lever comes back pretty far now and the brakes work very well. Note: bleeding the front brake is a two step process. Bleed the front (linked piston) then go back and bleed the rear again. It should be fine after that. Are you using a vacuum bleeder pump or pumping the handle and gravity?
JamieB
JamieB
PostSubject: Re: Brake bleeding.   Brake bleeding. I_icon_minitimeTue Mar 27, 2012 8:14 am
Hi and thankyou for your reply.
I am using good old traditional piece of pipe method, no bleed kit tool of any kind.
forgitaboutut
Number of posts : 55
Registration date : 2009-04-03
PostSubject: Re: Brake bleeding.   Brake bleeding. I_icon_minitimeSun Apr 01, 2012 9:52 pm
this tool came highly recommended,and works great!
pretty close to speed bleeders, only you just slip it on the existing nipple, open it,and squeeze the lever and pump the fluid through...
http://www.motionpro.com/motorcycle/partno/08-0143?utm_source=webgains&utm_medium=affiliate&utm_campaign=webgains
Brake bleeding.
» I Need Help With The Brake Bleeding
» Brake Bleeding Nightmare
» Yet more brake bleeding problems - resolved
» Hand Brake or Parking Brake
» Tip For Bleeding Brakes
