| Hand Brake or Parking Brake | |
+4Dimond model28a Old Limey Donie 8 posters |
Donie Scooter Rider
Number of posts : 80 Location : Ireland Points : 4272 Registration date : 2013-04-07
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Hand Brake or Parking Brake Tue Sep 16, 2014 12:36 pm | |
| Is there a trick to using the parking brake.
I've only had my Swing for a short while but notice when I try to use the parking brake the lever will not stay in a locked position.
Old Limey Silver Wing Expert
![Old Limey](https://2img.net/u/3413/63/00/33/avatars/654-64.jpg)
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6221 Registration date : 2010-06-09
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Sep 16, 2014 2:41 pm | |
| I always use the parking brake, it should just lock in place as you pull it forward and release the handle. Pulling it forward again should release it. I would look at the rear wheel where the parking brake lever is, might need an adjustment there. |
Donie Scooter Rider
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Sep 16, 2014 3:56 pm | |
| Thanks Old Limey.
I'll have to investigate if it actually latches at the back caliper, and not at the lever mechanism in front. |
![model28a](https://2img.net/u/3413/63/00/33/avatars/494-23.jpg)
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7483 Registration date : 2010-02-03
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Sep 16, 2014 4:27 pm | |
| Again it would help if you give us the information asked for in your post on the V-light. |
Donie Scooter Rider
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Sep 16, 2014 7:41 pm | |
| Silverwing ABS 2005 approx 45,000 miles
No modifications other than ( I believe) Dr. Pulley sliders
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Sep 16, 2014 10:15 pm | |
| With that many miles it's probably time to adjust them. To adjust them put your scooter on the center stand and pull the parking brake handle up two clicks, back at the caliper for the parking brake you will find a threaded rod with a flat for a standard screw driver and a nut on it. Loosen the nut and spin the wheel by hand, turn the rod in until the wheel will not turn. Then hold the rod with a screwdriver and tighten the nut. Now pull up lightly on the parking brake handle to release. You should then be able to engage the parking brake within two or three clicks. If you look at the pads i the parking brake caliper you probably will think they are too thin but they are now very thick when new. They are not used to stop the scooter they are only there to hold the scooter when stopped so they don't need much pad. I made the mistake of buying new pads only to find the new pads were not much thicker than my old ones. |
Donie Scooter Rider
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Wed Sep 17, 2014 8:11 am | |
| Roger,
My problem is that I don't have any 'clicks' when I pull the lever.
The ratchet pawl, or whatever system it employs, presumably in the vicinity of the lever, is not working.
There is no threaded rod at the rear caliper. The cable goes all the way to the lever on the caliper.
This lever is attached to the caliper by a nut and washer, and perhaps the lever is spline-mounted and the adjustment is done by moving it a spline or two.
On the other hand it may be done at the cable end at the lever. |
Dimond Silver Wing Expert
![Dimond](https://2img.net/u/3413/63/00/33/avatars/1542-7.jpg)
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5458 Registration date : 2011-08-07
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Wed Sep 17, 2014 1:13 pm | |
| - Donie wrote:
- Roger,
On the other hand it may be done at the cable end at the lever. Don't really know why you are having rachet engagement issues - but here are some thoughts. 1. Get a Honda Service Manual ($30 on ebay) as there is lot's of data in that manual they you need to service you SWing. 2. Be aware that you can look up pictorial parts schematics on-line that help you see how things go together. 3. The cable goes to the lever - but lever is adjusted with locknut and threaded rod (screw) in or out. (item 16 in this schematic is the locknut http://www.onlinecycleparts.com/oemparts/a/hon/5053f2f1f870021c54be6cba/parking-brake-caliper ) 4. Start by adjusting (at the rear) the brake so that you have the proper pre-tension on the rachet. 5. Check to see if you are getting rachet to now engage and check that pulling up on rachet is actually pulling on cable. 6. Remove the two screws holding the parking brake BOOT (item 9 in this schematic http://www.onlinecycleparts.com/oemparts/a/hon/5053f2f1f870021c54be6cba/parking-brake-caliper ). This will allow you to see the 'rachet' area and maybe figure out what is going wrong - maybe spray some WD40 in area or some oil - may get things 'freed up'. I am pretty sure that the BOOT screws thread into cover and that you will not lose any nuts - but not 100% sure of this). 7. If above does not work then you likely will need to remove a lot of plastic to gain access to the 'rachet mechanism' for its repair/replacement. I have had this area apart once (for another matter) and did not find doing so (for me) was a simple task. Let us know what you conclude. |
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Wed Sep 17, 2014 3:50 pm | |
| If you remove the right glove box you may be able to reach the back of the parking brake handle to see if the cable is hooked up. If you look at what looks like a plunger in the middle of the picture by the dust seal #18. That sticks out the caliper and has a lock nut on it, it looks like I was wrong saying a flat screw, it's square not slotted. but that is for adjusting the brake pads, using the method I explained before. I hope this makes it a little clearer. If not just ask again. ![Hand Brake or Parking Brake 115354](https://2img.net/h/ziporiginal.ru/cat_img/catalogs/115354.gif) |
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Wed Sep 17, 2014 9:16 pm | |
| - model28a wrote:
- If you remove the right glove box ...
+1, and easy to do. |
Donie Scooter Rider
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Fri Sep 19, 2014 1:59 pm | |
| I removed the exhaust/muffler and thoroughly checked the hand-brake caliper, and all appears to be good.
It does activate properly when I pull the lever, but the light in the dash doesn't show, and as said earlier, the ratchet/pawl system doesn't operate, and I'm assuming that it's part of the lever mechanism. |
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Sat Jul 01, 2017 6:18 am | |
| You might like to try searching 'parking brake' over on the left there.
I had similar trouble so look for my write up on it. I'm trying to post pictures but can't seem to login to the host site for the pics.
Watch this space. |
![Siataukreg](https://2img.net/u/3413/63/00/33/avatars/3657-55.jpg)
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3957 Registration date : 2014-08-24
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Tue Jul 04, 2017 7:09 pm | |
| If you need any parts for it I have the complete assy. |
Winger61 Silver Wing Rider
![Winger61](https://2img.net/u/3413/63/00/33/avatars/903-64.jpg)
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5559 Registration date : 2010-10-15
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Wed Jul 05, 2017 4:18 pm | |
| - Donie wrote:
- I removed the exhaust/muffler and thoroughly checked the hand-brake caliper, and all appears to be good.
It does activate properly when I pull the lever, but the light in the dash doesn't show, and as said earlier, the ratchet/pawl system doesn't operate, and I'm assuming that it's part of the lever mechanism. Donie, I had a similar problem with the light not working, turned out to be dirty contacts. Posted this in 2014 - might be worth a try. Had the same problem a while ago. I took out the right side glove box and gave the contacts a dose of WD40, then worked the parking brake lever on and off a few times to clean the contacts. Works OK now, and the light comes on each time. If you don't feel confident about taking the glove box out, you could try spraying through the slot where the p/brake lever is (through the rubber sleeve thingy). IIRC, you need to direct the spray upwards to get at the switch contacts doing it that way. |
Dave Weller Scooter Rider
Number of posts : 85 Location : Chatham Kent UK Points : 4786 Registration date : 2011-11-09
![Hand Brake or Parking Brake Empty](https://2img.net/i/empty.gif) | Subject: Re: Hand Brake or Parking Brake Thu Aug 09, 2018 1:42 pm | |
| I've just replaced the Pads on the handbrake at 20000 miles. The existing OE pads had more 'meat' on them than the new ones I brought, so I think the existing pads would outlast the bike. Still a good idea to lube up the friction points. The pads only have about 3mm of material from new, so save your cash, stay with existing. |
