| Dr Pulley sliders | |
+16willajabir Meldrew vmaximus john grinsel The Bern Easyrider Leena H MadDog Mech 1 twa GHM-PM Sidewinder Pilot Cosmic_Jumper BillScooterDude Flyingpanman cliffyk bill tucker 20 posters |
bill tucker Scooter Rider
Number of posts : 37 Age : 57 Location : kansas Points : 2535 Registration date : 2017-07-23
| Subject: Dr Pulley sliders Mon Jul 24, 2017 7:12 pm | |
| I was just wondering if anyone else are running the dr pullys sliders and what kind of results your having , I put the 30gram sliders in and noticed a big difference at hi way speed , at 75mph I'm doing 5100 rpm it does feel a little more doggy at take off but that's about it. was wonting any input from other members. Bill |
cliffyk Maxi-Scooter Rider
Number of posts : 182 Age : 78 Location : Saint Augustine FL Points : 3125 Registration date : 2016-05-15
| Subject: Re: Dr Pulley sliders Mon Jul 24, 2017 7:24 pm | |
| The stock rollers are 28 g, making what your are experiencing with the 30 g sliders what I would expect. My first change, seeking improved acceleration was to 26 g sliders, and then to 24 g. The 26's provided a good boost, the 24s a bit more but not enough for me to live with the 5200 rpms at 70 mph.
I now run four 24 g and four 26 g sliders, 5050 rpm at 70 mph (my belt needs to be replaced in a couple thousand miles) and am very pleased with the overall performance... |
| Subject: Re: Dr Pulley sliders Mon Jul 24, 2017 7:31 pm | |
| thanks cliffyk, do you run 1 24 and 1 26 all the way around , or how do you place your sliders. Bill |
| Subject: Re: Dr Pulley sliders Mon Jul 24, 2017 9:44 pm | |
| - bill tucker wrote:
- thanks cliffyk, do you run 1 24 and 1 26 all the way around , or how do you place your sliders. Bill
Yup, alternating all the way around--it's the only way to distribute their force evenly. Did this with 18s and 14s on my 400 Burgman too... |
Number of posts : 237 Age : 74 Location : Morecambe, Lancs., UK. Points : 3178 Registration date : 2016-06-03
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 6:14 am | |
| If you go to the Dr Pulley web site and do a bit of searching, you'll find they recommend either 24g. or 25g. sliders for the 600 Silver Wing. |
BillScooterDude Scooter Rider
Number of posts : 48 Age : 79 Location : Auburn CA Points : 4311 Registration date : 2012-09-22
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 1:41 pm | |
| I run 22g Dr Pully rollers I like the low end acceleration and normally don't exceed 70 on the freeways.
Bill
Last edited by BillScooterDude on Fri Jul 28, 2017 6:59 pm; edited 1 time in total |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 1:59 pm | |
| thanks Bill for your input , I run mine on the HI way regularly and part of the hi way speed limit is 75 mph so I normally run 75 and 80. I think I will go to the 24 or 26 gram sliders, one problem I'm having is finding anything other than 28 and 30 gram sliders ? dose someone have a corner on this . thanks Bill |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 3:50 pm | |
- thanks Bill for your input , I run mine on the HI way regularly and part of the hi way speed limit is 75 mph so I normally run 75 and 80. I think I will go to the 24 or 26 gram sliders, one problem I'm having is finding anything other than 28 and 30 gram sliders ? dose someone have a corner on this . thanks Bill
Have you checked with Buggy Parts North West? If you scroll down to the bottom of the link it says to contact them if you would like to special order sliding weights. But given that the Silverwing experience is new to you I don't see any reason why you wouldn't be satisfied with 26gm Sliders. As a matter of fact you would be very hard pressed to notice any difference between 26gm & 25gm Sliders. Kinda splitting hairs there. https://www.buggypartsnw.com/index.php/dr-pulley-products/dr-pulley-slider-weights/400cc-and-higher/dr-pulley-slider-weight-28x20-for-600cc.html Tim |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 3:58 pm | |
| thanks Tim, I have looked at there site they have the 24g not 26 and have 28 and 30 it seems that the 26g are hard to find, as of now I have the 30g in my swing now, I put in with a belt change out , just a little doggy taking off . |
Number of posts : 200 Location : Ocala, FL Points : 3499 Registration date : 2015-05-21
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 5:11 pm | |
| Hi Bill,
I just put 25,000mi on a set of 26g's, and switched to 30g just to experiment...the difference was profound to say the least.
There was an 1100 rpm drop through the ratio change, with it only rising when the CVT travel was at max. -(My 26g set put me at 5200rpm, the 30g's were 4100)
I have a set of 24g's coming from Asia, and I'm anticipating my rpm's will be somewhere around 5500.
I think you will be the most pleased with the performance. If you can't find them local, and don't mind waiting for the slow boat from China.... http://www.ebay.com/itm/Dr-Pulley-Roller-SR2820-28x20-26g-for-Honda-Silver-Wing-600-scooter-moped-/332317138279?hash=item4d5fa51d67:g:H9IAAOSwxH1ULs1x&vxp=mtr |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 5:16 pm | |
| thanks sidewinder pilot , I love the aviator that's great, was wondering at what speed are you doing your rpm study on. thanks Bill |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 5:17 pm | |
| Well, if you would have to special order something then go for what you want.
Not surprizing you have more sluggish accelleration with 30gm sliders (or rollers). They are intended for better fuel economy. I know that when I tried 30gm sliders years ago, I was appalled at the lack of mid-range accelleration. Damn scary trying to pass another vehicle.
Eventually I ended up mixing 20gm & 30gm sliders to effectively achieve 25gms, which proved impressive enough. But I prefer the 26gm, sometimes even 28gm, sliders for overall performance & economy.
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 5:40 pm | |
| Tim, do you think you can find the rpm>mph study I did a while ago? It might be useful for Bill... Thanks, I would do it but I'm mobile |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 9:33 pm | |
Number of posts : 2566 Age : 71 Location : Bullhead City, AZ Points : 7255 Registration date : 2012-05-17
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 9:40 pm | |
| I switched mine to 28 gram sliders. Not much change (basically stock weight). No difference in MPG with a slight drop in RPM. Biggest thing I noticed was less vibration. I went with 28 because I use the SWing for trips, highways and some freeway usage. Did not need more acceleration. So overall for me the 28 grams work OK. Good luck with whatever you decide. |
| Subject: Re: Dr Pulley sliders Tue Jul 25, 2017 10:52 pm | |
| I've been running 30g for the past few thousand miles, I like the 5-6 mpg increase, but aside from the sluggish response, (which I wouldn't experience if I weighed the 150 pounds Honda wants me to weigh) I end up running right around 4000rpm. This is right where the engine's resonant vibration is.
Because I have a stiffer contra spring, I probably have similar results as a 28g slider. If I went with the 32g set I would likely be below the vibration point, but would be a bit more gentle.
I'm going the other way. I need my acceleration, the cagers here do not look before changing lanes.
| Subject: Re: Dr Pulley sliders Wed Jul 26, 2017 8:00 am | |
| I ordered a set of 21g and will just do a mix of 30g and the 21g , hopefully that will be a good compromise. and once aging thanks for all the help with this. Bill |
| Subject: Re: Dr Pulley sliders Wed Jul 26, 2017 8:29 am | |
| 21g!....You should try it for a while with straight 21's, your acceleration will be "quite strong" off the line and merging, you should be able to pass anything but a gas station! I doubt you would see much difference from the 30's at 80mph, you'll just get there way faster, so hiway mpg would be close to what you've been getting.
Please let us know, it would be good to see what max pulley travel yields as far as mph:rpm for 21g
| Subject: Re: Dr Pulley sliders Fri Jul 28, 2017 2:55 pm | |
| well I put my new 21g with my 30g sliders today and so fare I like it , lots more take off and passing power haven't been on hi way yet, but will tomorrow morning a little trip in to see my father . I also changed out my final drive oil and put new in and new spark plugs , so I'm good to go for a while. Bill |
Number of posts : 1382 Location : Allentown PA. Points : 4538 Registration date : 2016-01-02
| Subject: Re: Dr Pulley sliders Sat Jul 29, 2017 7:05 pm | |
| I like the 26g I installed. Faster acceleration, Better mileage. Went from 50mpg to 56 . Givi windshield, sliders, fork springs and top case. 2013 left over 7,900 miles so far. Lower RPM's at highway speeds. I love this scooter. Great on hot days no engine heat.
| Subject: Re: Dr Pulley sliders Sat Jul 29, 2017 11:06 pm | |
| My 24g sliders arrived from Taiwan today, 2-3 weeks sooner than expected. And, after dealing with the sluggish passing performance of the 30g sliders, it is none too soon!
My plan is to get up early and change them out, from my testing of the 26g and 30g sets I think the 24's will be the perfect solution, putting my RPMs right at 5400, right at the point where my power band starts to build.
I know, I'll give back the 5-6 mpg the 30's gave me, but it's a price I'm willing to pay for the ability to get out of the way in a forward direction! |
| Subject: Re: Dr Pulley sliders Sun Jul 30, 2017 6:33 am | |
| so I ride my swing Saturday morning put right at 110 miles on used right at 2 gallons of gas so with new 21g and 30 g mix still getting about 55 miles per gallon and that is running 75 mph and lots more passing power on the hi way , on a different note it was kind of funny I meet up with a guy I now at a stop light and he was on his roadstar , he was smiling at my bike and asked if I was retired, I'm 50 ! , when we left the light , I was the one smiling after a block. love my swing . Bill |
| Subject: Re: Dr Pulley sliders Sun Jul 30, 2017 5:51 pm | |
| I just got back from a ride with my new 24g sliders, and I no longer feel like a sitting duck in traffic or passing trucks. Totally different than 30g, with a good bit more acceleration than the 26's had, and the same RPM:MPH at hiway speed as either of them.
MadDog Scooter Rider
Number of posts : 37 Age : 87 Location : Northumberland NE UK Points : 2916 Registration date : 2016-07-11
| Subject: Locating Dr Pulley Sliders Wed Aug 16, 2017 5:18 pm | |
| Hi regarding the sliders it seems no one in the the UK or Europe stock them , I've been trying to find the address of the actual manufacturer so I can contact them direct. I'm looking to try 28 gm any information I would be grateful. |
| Subject: Re: Dr Pulley sliders Wed Aug 16, 2017 5:28 pm | |
| Hi again I don't know how I missed Sidewinder Pilots link , I have since ordered them .Once again I am grateful to all you guys ,Thanks a lot for the site. Carry on with brilliant work |
Leena H Maxi-Scooter Rider
Number of posts : 103 Location : Vaasa Finland Points : 2968 Registration date : 2016-09-17
| Subject: Re: Dr Pulley sliders Tue Nov 14, 2017 12:48 pm | |
| A fellow SW owner in Finland has this kind of problem with his Dr Pulley sliders resulting broken variator and the belt. What might have caused the this damage? He said the metal inside the slider had broken the it. Has this happened to anyone else? Did he install them correctly or not? |
Number of posts : 1012 Age : 73 Location : HI Points : 4161 Registration date : 2015-12-18
| Subject: Re: Dr Pulley sliders Tue Nov 14, 2017 12:57 pm | |
| Does your friend use the same weights or does he/she mix weights? My thoughts would be that the heavier weights would have more stress and start engaging before the lighter sliders causing the heavier weights to wear and damage sooner. If all the weights are the same, the load is spread evenly. That is my thoughts. |
| Subject: Re: Dr Pulley sliders Tue Nov 14, 2017 1:26 pm | |
| The only thing I know that he has installed them in april and has driven only 5500miles with them.
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4442 Registration date : 2014-11-20
| Subject: Re: Dr Pulley sliders Tue Nov 14, 2017 2:06 pm | |
| I'm guessing they were fitting wrongly, have your friend watch this video & see if they did it the same way .... https://www.youtube.com/watch?v=Q-lUnRhnCz4 |
| Subject: Re: Dr Pulley sliders Tue Nov 14, 2017 5:13 pm | |
| Could have been a bad part or not installed correctly. Slider looks crushed it may have slide out of place and when the the VAR. nut was tightened it got damaged.
I'm using 26G and like them. I sometimes hear a noise at idle maybe belt slapping?? Sliders may stretch the belt a little more than its designed for. 2013 left over manufactured in 2012 so belt is over 5 years now but only 12k miles. May replace in spring if noise is still there. Winter is here may get a ride or two in . |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 7:34 am | |
| I replaced my rollers with DR sliders about 2 1/2 years ago and have about 7 K on them with no problem so far. I am guessing it was a defective part or install. |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 9:32 am | |
| - Leena Hallasmaa wrote:
This is not the first time I have seen a problem like this. Though this is the most serious one. A clue to the problem may lie in the photo: the impact gun. Quite possibly the ramp plate was not firmly held to the variator when the assembly was slid back onto the crankshaft. That allowed one Slider to dislodge during assembly. And/or one of the ramp plate sliding pieces to fall out, allowing the Slider to dislodge. Because the impact gun was used to rapidly reassemble the other half of the variator, belt & bolt, the mechanic never got the sense that something was amiss. And so it goes... I personally had an incident where one Slider "rotated" or stuck and failed to return to the correct position which caused the "V" light to turn ON. I attribute that to "loose" sliding pieces which allowed a Slider to rotate when I rapidly decelerated then reaccelerated during a high speed maneuver. As I was 1200 miles away from home at the time, thankfully I had tools along to "repair" the problem. Link to Bruce Kohler's inexpensive DIY variator holding tool: https://xa.yimg.com/df/hondareflexowners/Variator+Pulley+Tool.pdf?token=8Yb3Om7M0bazPskBM1wmZ3DoCeN59eBim4frEOqsKXacr4uvf1-ogPX1oEN_l09PK7P4NQZx605a3GDYs8T-XAQuICosZUW1tM7LcvrTxs2O6rsYBXcMrjGX8Q&type=download I strongly suggest that Dr Pulley ramp plate Silding Pieces be used along with Sliders. The new SP fit much tighter than OEM sliding pieces and aren't going to fall out or wear out. Oh, and don't forget to lubricate the variator ramps and sliders when installing the new parts. The best product we've found is PB'laster with Teflon http://blastercorp.com/Dry-Lube-with-Teflon. It sprays on wet but rapidly dries to a white powder. I'm sure a similar product is available in the EU. I also advise not using an impact gun to reassemble the variator. Use a variator holding tool and a torque wrench. That way you can "feel" what's going on. Tim
Last edited by Cosmic_Jumper on Fri Nov 17, 2017 11:55 am; edited 3 times in total (Reason for editing : Additional info link) |
Number of posts : 3299 Age : 85 Points : 9256 Registration date : 2009-08-18
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 10:10 am | |
| I see all this monkey business changing rollers/sliders. Stock just fine---2 new SilverWings over 90,000 miles, worked for me....and I never walked or had to make repairs underway. |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 11:37 am | |
| You are correct, Mr Grinsel. There is nothing wrong with a stock Silverwing. However some folks opt to tailor their Silverwings to suit their personal preferences. Just as you have opted to add a topcase, an aftermarket windscreen and Ride-On.
vmaximus Maxi-Scooter Rider
Number of posts : 133 Age : 71 Location : Kirkby in ashfield Nottinghamshire England Points : 4948 Registration date : 2011-04-15
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 1:06 pm | |
| John just because you prefer the standard rollers on your scooter it doesn't mean that they all have the same characteristics or you haven't had any problem with them irrespective of how many miles you've ridden. The stock rollers on my 2008 silverwing where the pits, heavy vibration on take off, constant de glazing of the variator didn't help much to relieve the problem. I changed to 26g Dr Pulley sliders and it made a whole lot of difference, I don't get the vibration on take off, acceleration is better fuel consumption is about the same and I run slightly less RPM at my cruising speed so all in all I am happy with the change, if you feel that there is no need to change from he standard rollers then don't but I can assure you that on my scoot it was well worth doing the change. And on another note because I rate the Dr Pulley sliders being superior to standard rollers when I get round to doing a belt change on my 2012 Sym Maxsym 400i I will also replace the rollers for D/P sliders. There is only one person who knows how his scooter performs and that is the man who is riding it so stock is not always best. Pud. |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 4:03 pm | |
| Think stock----breakdown in middle of nowhere---how dealer can get parts. Breakdown remote---you may waste valuable and expensive time. My take has always been....don't like performance of bike, get something different.....cheaper in long run. SilverWing as it came new=fine except for being overweight |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 4:36 pm | |
| Think stock, Think aftermarket, if like you say you break down in the middle of nowhere you are still stuck in the middle of nowhere and parts are probably just as difficult to source however you look at it. I am just saying for me they worked superbly and just because I prefer them and I think that they are an improvement overall am not going to preach them as a must have mod on every occasion that this topic crops up, I didn't fit them as a performance gadget but as a way of reducing vibration on take off which they have done so I am happy with the result and as I have said before if anybody doesn't like them don't fit them, simples. With the mention of the Silver Wing being overweight so am I perhaps both could do with shedding a bit of ballast, which is probably another category that a lot of people fall into. Good night all, time for bed. Pud. |
| Subject: Re: Dr Pulley sliders Fri Nov 17, 2017 9:05 pm | |
| FWIW I've got 10k miles with DRP sliders on my '06, 2k with a set of 26 g and 8k with four 24 g and four 26 g--no problems of any sort... |
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 12:01 am | |
| - john grinsel wrote:
- Think stock----breakdown in middle of nowhere---how dealer can get parts. Breakdown remote---you may waste valuable and expensive time. My take has always been....don't like performance of bike, get something different.....cheaper in long run. SilverWing as it came new=fine except for being overweight
John, Even a stock bike can break down. That's why you always ride a new bike under warranty. There's nothing to say aftermarket items are any worse than stock. |
Number of posts : 4179 Location : York, North Yorkshire, England UK Points : 9218 Registration date : 2010-11-16
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 4:09 am | |
| - Easyrider wrote:
- There's nothing to say aftermarket items are any worse than stock.
Of course there is, there's topics about using off the shelf dodgy oil filters, various tyres that aren't as good as the OE ones, cheapo heated grip kits that aren't as good as the Honda ones. Or rubbish like those foam Grab On grips I was daft enough to fit. Then there's expensive aftermarket exhausts that do nothing apart lighten the Silver Wing a bit, your wallet a lot and advertise the manufacturers logo. I replaced my pilot bulbs with useless LED bulbs that lasted a few weeks before one failed, the OE ones I put back in are still working The OE horn is a bit weedy but who really uses the horn much. Good luck in finding somewhere to hide a Nautilus horn or other aftermarket audio lump. Then there's the false economy of fitting cheap replacement belts or brake pads that only last a few thousand miles. Owners that buy replacement screens for the useless OE screen that are far too tall for them rather than pay a bit extra for the adjustable Airflow. Then they have to cut them down or convince themselves and forum members that they really prefer looking through them in rain or at night rather than looking over them. Even the Dr Pulley fetishists can't make their mind up about what slider weight to fit and rely on others experiences, or try one or two sets before they get it right. Then of course there's the HyperPro fork springs which if you've gone through all the hassle of fitting them, you can't really say then that their advantages are minimal. Plus not everyone has any nearby twisties for blasting through, so what's the point. In a nutshell it's old men with too much time and spare cash farkling an old scooter for no other reason other than they've been influenced by what they've read on here. Or alternatively they've bought some old dog of a Silver Wing to throw money at.
willajabir Maxi-Scooter Rider
Number of posts : 161 Location : Birmingham, AL Points : 4547 Registration date : 2012-08-21
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 9:26 am | |
| That's right, Don't be influenced by what you read on here.....oh wait...... |
steve_h80 Silver Wing Expert
Number of posts : 999 Location : Teesdale, UK Points : 4002 Registration date : 2016-05-15
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 1:45 pm | |
| Soooo, has anyone fitted a nitrous kit ... ? |
SlvrwngTraveler Scooter Rider
Number of posts : 27 Location : California Points : 2415 Registration date : 2017-11-03
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 7:31 pm | |
| Hi gang! Can someone please post SW's OEM sliders weight? I'm reading all these useful comments here trying to decide on which set to purchase for my 80% freeway riding. I like to keep up with the freeway traffic (70-80mph) but also would like to improve stop light acceleration if possible. Appreciate all the wisdom inputs greatly! |
| Subject: Re: Dr Pulley sliders Sat Nov 18, 2017 8:14 pm | |
| OEM rollers are 28g
Sliders can be purchased in 21-24 -25- 26-28-30-32. 24-26 are the most popular. Faster acceleration lower engine speeds on highway. Slightly better mileage.
0-30 not much of a difference. Passing and acceleration sliders are better.
Search this site and make your decision.
pgnz Scooter Rider
Number of posts : 54 Location : New Zealand Points : 2708 Registration date : 2017-02-21
| Subject: Re: Dr Pulley sliders Sun Nov 19, 2017 2:35 am | |
| Subject: Re: Dr Pulley sliders Sun Nov 19, 2017 1:12 pm | |
There are posts where even the stock oil filters rusted through. After market exhaust will not cause a break down. The after market grips won't set you back alot.
I added a second horn and use it at least once a week. Too many riders talking, texting on their phones.
Each rider has personal preferences. Some do it for performance, some want smoother acceleration from stop. The mod is inexpensive and easy to install. I did try two sets as you state. My first Swing vibrated badly and going to the 26g sliders did not smooth out the vibrations enough, so I went to the 24g sliders and it solved the vibrations. I also liked the added low end power. I moved the 24g sliders to my 2013 Swing at 1000 miles. Never regretted it.
One can't assume that the advantages are minimum unless you try it yourself.
Very true Meldrew! And it is because we can
| Subject: Re: Dr Pulley sliders Sun Nov 19, 2017 1:33 pm | |
| ^^^^^^ you need to learn how to do quoteboxes bud, that post is too hard to read & understand, I will guess though that your lines of reply are nearly as many as the lines in your sig' |
| Subject: Re: Dr Pulley sliders Sun Nov 19, 2017 4:53 pm | |
| - The Bern wrote:
- ^^^^^^ you need to learn how to do quoteboxes bud, that post is too hard to read & understand, I will guess though that your lines of reply are nearly as many as the lines in your sig'
Sorry, was late for church. Just corrected by changing the colors. Then again, I am color deficient. Ah, you like my signature. I do too! Thank you! |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 2993 Registration date : 2017-09-07
| Subject: Re: Dr Pulley sliders Mon Nov 20, 2017 4:49 pm | |
| "In a nutshell it's old men with too much time and spare cash farkling an old scooter for no other reason other than they've been influenced by what they've read on here. Or alternatively they've bought some old dog of a Silver Wing to throw money at."
"Very true Meldrew! And it is because we can"
Both above quotes deserve repeating. That's what those of us on this forum are all about. I probably wouldn't dress my bike the way you dress yours, and you wouldn't submit to all of my ideas, either, but it's fun to copy something from everybody--good ideas and help here! |
| Subject: Re: Dr Pulley sliders Tue Nov 21, 2017 12:35 pm | |
| Thanks for the info Mech 1 twa. |
| Subject: Re: Dr Pulley sliders | |
