| Front brake disk hole | |
+3Sknrdtec Pastor Ron steve_h80 7 posters |
steve_h80 Silver Wing Guru
Number of posts : 1036 Location : Teesdale, UK Points : 4223 Registration date : 2016-05-15
| Subject: Front brake disk hole Sun Aug 20, 2017 1:47 pm | |
| Just noticed one of the holes in my front disk is bigger than the rest. What's thaft all about? |
Pastor Ron Silver Wing Rider
Number of posts : 400 Age : 72 Location : Asheville,NC Points : 4765 Registration date : 2013-02-24
| Subject: Re: Front brake disk hole Sun Aug 20, 2017 2:03 pm | |
| I believe it is so your disk will not get too hot when brakes are applied IMO |
| Subject: Re: Front brake disk hole Sun Aug 20, 2017 3:18 pm | |
| Generally the holes are to help heat dissipate, to clear water and gas build up. What I'm asking is why one hole is larger than the rest. Most likey just a manufacturing glitch, but it a one off or do we all have one? |
Sknrdtec Scooter Rider
Number of posts : 58 Age : 60 Location : Cedar Grove In. Points : 4437 Registration date : 2012-11-28
| Subject: Re: Front brake disk hole Sun Aug 20, 2017 6:17 pm | |
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4262 Registration date : 2013-10-08
| Subject: Re: Front brake disk hole Mon Aug 21, 2017 3:18 am | |
| Often here in UK city's people drill one bigger for a disk lock. If you do 3 equally round the disk and a small notch in line in the rim with white paint it makes it easier to find one when parking. |
Number of posts : 4217 Location : York, North Yorkshire, England UK Points : 9438 Registration date : 2010-11-16
| Subject: Re: Front brake disk hole Mon Aug 21, 2017 5:23 am | |
| I really do find that hard to believe that when it's far simpler to choose a disc lock with a locking pin size that fits through all of the holes of your motorcycle/maxi scooter brake disc (17mm on the Silver Wing) rather than go through the rigmarole of drilling through a thick steel brake disc (11mm on the Silver Wing) to enlarge a few holes. Then having to mark out where they are, and that's just if you already have a good drill and the correct size drill bits to do the job.
I've a unused 19mm pin disc lock in the garage, it doesn't fit the holes on the Silver Wing's disc so why would I try to make it fit. A good thing about a maxi scooter is the underseat storage, and the heavy duty locking Abus chain I keep there aces any disc lock.
Disc locks are a nuisance anyway, probably ever rider that's bought and fitted one will have at least once forgotten about it and moved his bike/scooter off it's centre stand with it still fitted. Or even worse tried to ride off with it in place. That's why they sell those hi-vis plastic reminder cables you tether to the disc lock and handlebars.
Number of posts : 1999 Age : 78 Location : Princeton, MN Points : 6068 Registration date : 2014-02-13
| Subject: Re: Front brake disk hole Mon Aug 21, 2017 9:30 am | |
| A bike lock sounds logical but how about balancing the disk? I don't know dip squat about it but that's what popped into my mind. |
| Subject: Re: Front brake disk hole Mon Aug 21, 2017 3:17 pm | |
| I'm with Meldrew on disk locks, they are the work of the devil! Rev, bang, crump, expense... |
Number of posts : 1013 Age : 74 Location : HI Points : 4344 Registration date : 2015-12-18
| Subject: Re: Front brake disk hole Mon Aug 21, 2017 5:34 pm | |
| The larger holes may be made to balance the disc. Kinda similar how crank shafts are drilled for balancing. My 2¢ |
