Add in to changing last Scooter Tire I_icon_minitimeby MikeO Yesterday at 6:23 pm
Add in to changing last Scooter Tire I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Add in to changing last Scooter Tire I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Add in to changing last Scooter Tire I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Add in to changing last Scooter Tire I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Add in to changing last Scooter Tire I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Add in to changing last Scooter Tire I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Add in to changing last Scooter Tire I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Add in to changing last Scooter Tire I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Add in to changing last Scooter Tire I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
3 posters
Number of posts : 3313
Add in to changing last Scooter Tire Empty
PostSubject: Add in to changing last Scooter Tire   Add in to changing last Scooter Tire I_icon_minitimeSun Aug 20, 2017 5:31 pm
The rear tire I mounted last week or so....developed slow leak.
Checked tire for nail/screws=nothing
Changed valve core 2 or 3 times to find one that sealed.  Soapy water test, ok now
Then did more soapy water tests at base of special Honda Part number, H rated $11   valve stem----small bubbles around base, let air out of tire, rotated stem a little and wiggled, aired up tire again, checked for bubbles=ok  BUT real fix is to  remove wheel, break down tire, replace valve stem----Probably $80 job if you pay somebody.....because of mickey mouse involved with rear wheel removal.
Will work on this next week-----maybe can break bead with wheel on bike....and get inside to push new stem thru.
Current stem has been in use less than 6 months. I think older SilverWings may have or are going to have rear valve stem problems as the rubber parts age.   i got rid of the original stem at about 40,000 miles and replaced with straight one....making checking pressure/filling tire from left side easier.
Leak developing early is probably just a fluke?
PostSubject: Re: Add in to changing last Scooter Tire   Add in to changing last Scooter Tire I_icon_minitimeSun Aug 20, 2017 6:09 pm
Jeez, Mr Grinsel, if you would have had a Darkside tire and an Ariete valve stem you wouldn't have had these problems Rolling Eyes
Actually the Ariete valves bolt on from the inside and can be mounted for a left side fill.
http://www.ariete.com/en/catalog/road/valvole/
PostSubject: Re: Add in to changing last Scooter Tire   Add in to changing last Scooter Tire I_icon_minitimeSun Aug 20, 2017 6:23 pm
I go around corners---why would I want car tire?---beside bike and car wheel have different beads---there is SAE paper on this.
Mighty Mouse
Mighty Mouse
Number of posts : 117
Registration date : 2017-05-03
PostSubject: Re: Add in to changing last Scooter Tire   Add in to changing last Scooter Tire I_icon_minitimeMon Aug 21, 2017 5:33 am
Do yourself a favour and upgrade to a metal valve. Also check the bead of the tyre for leaks - that has been the culprit of a slow leak for me in the past.
PostSubject: Re: Add in to changing last Scooter Tire   Add in to changing last Scooter Tire I_icon_minitimeMon Aug 21, 2017 3:00 pm
Got rubber valve sealed: I see no or have no interest in spending more money on bike that is ending its time with me.
Tip here: At near 50,000 miles my 2013, has had 5 or 6 rear tires---next to last dealer installed. I take care to wire brush/clean bead area on rim----dealers usually don't---this time spent time to really clean rim bead....so no leaks at bead. Use soapy water as lube to seat bead-- then mount on my balance stand to make sure bead is seated all around....and tire round....AND I ended up with leaky stem....should have changed it, even though it had been in service short time.
I use "Ride On" as balance medium and have for several years=works well for me and as my tires stay in balance thruout their life, seem to get more miles out of them.---I am fairly experienced with mc tires having used up something like 450 in 62 years of riding, most self installed, tube or tubeless. Real problem with Maxi-scooter like SilverWing---mickey mouse involved in rear wheel removal., stiff sidewalls of some tires.
» I installed new tires on my scoot all by myself today
» Maxi-Scooter! Mega-Scooter?
» Have I just changed last motorcycle/scooter tire myself?
» Did I change last scooter tire today??
» New Weight Loss program! Flat tire on scooter!
