| Tyre pressures | |
+14The Bern Hondafreak john grinsel lloyd193 micbusathens MikeO Jolly Bodger Dale N. Meldrew Scootypuff Snr Smaug steve_h80 dekare Silverwingdays 18 posters |
Silverwingdays Scooter Rider
Number of posts : 98 Location : UK Points : 2835 Registration date : 2017-06-05
| Subject: Tyre pressures Fri Sep 08, 2017 5:44 pm | |
| Hi I tend to put 36 in the rear and 30 in the Silverwing when solo but I see on the label on the bike it says only 33 solofor the rear and 29 for the front.
I suppose we are all different sizes and weights but can it really cope with 33 in the rear with a 200 or so pound bloke on ? as many of us are I`m sure.
Best SWD
dekare Maxi-Scooter Rider
Number of posts : 125 Location : MN Points : 3140 Registration date : 2016-08-09
| Subject: Re: Tyre pressures Fri Sep 08, 2017 7:42 pm | |
Best SWD I'm a Mother Honda fan. As a result I go by the book on my tire pressures. I figure somewhere Honda is paying a very large salary to someone with a lot more education than I have to keep Honda out of class action lawsuits. By golly if they specify a pressure, that's what I'm going with. I'm not about to arm chair quarterback their decisions. |
| Subject: Re: Tyre pressures Fri Sep 08, 2017 8:05 pm | |
| Well I`m with you there but a bloke can weigh anything from 10 or so stone to 25 + even.
I`m 15 and a 1/2 ( probaply 16 in helmet etc ) so will try the 33 this next week and see how it feels.
Best SWD. |
steve_h80 Silver Wing Guru
Number of posts : 1035 Location : Teesdale, UK Points : 4205 Registration date : 2016-05-15
| Subject: Re: Tyre pressures Sat Sep 09, 2017 2:48 pm | |
| I wouldn't fret sbout it too much. Mine stays at 36 for two up use but I can't be bothered dropping it for the odd solo run. But I do adjust the rear shocks cos I can feel the difference. |
| Subject: Re: Tyre pressures Sat Sep 09, 2017 4:55 pm | |
| I adjusted the rear shocks down to 2 ( one up ) to see if it would absorb bad bumps more, it did`nt really, but felt really unsafe etc.
Back up to 4, harder but at 215 lbs feels much safer/better.
I might take the air down to 33 one up to see if its any better on the back roads. But I`m pretty sure that might be a bit low for me.
Best SWD |
Smaug Scooter Rider
Number of posts : 67 Location : Chicago area Points : 4581 Registration date : 2012-07-30
| Subject: Re: Tyre pressures Wed Sep 13, 2017 10:45 am | |
| My advice is to follow the manual, unless you a re REALLY big. (and 200 lbs. isn't)
A little background behind my opinion:
In 2009 I crashed on my KLR 650. I was running +5 psi over the spec'd tire pressures and crashed because I lost traction in a turn. It just let loose, all at once, quick as a blink.
I was scraping my pegs pretty hard so it MAY not have been the tire pressure. But I have my doubts.
Add to that the fact that you'll wear a flat spot out of the center of the tire faster by running higher pressure. Lower pressure = bigger contact patch. Also, more heat, but if it's within spec, go with the bigger contact patch.
I go the other way from steve_h80: I leave it at the recommended solo pressure, even when I do the odd 2-up ride. (seems like he's 2-up often enough to leave it at the higher pressure) |
Number of posts : 230 Location : France & UK Points : 2993 Registration date : 2017-04-21
| Subject: Re: Tyre pressures Wed Sep 13, 2017 12:05 pm | |
| Aren't tyre pressures subjective to the equipment used to inflate and measure. Years ago they slated garage forecourt machines for inaccuracy (think little has changed) I use a simple pressure bar and cheap air pump and believe it's as accurate as I can get.
| Subject: Re: Tyre pressures Wed Sep 13, 2017 3:14 pm | |
| There is that Scootypuff, gauges canbe notoriously inaccurate. I have a single gauge that I use to ensure consistency and avoid garage machines if at all possible. |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9418 Registration date : 2010-11-16
| Subject: Re: Tyre pressures Wed Sep 13, 2017 4:20 pm | |
| I've never seen the point of using a garage/filling station to use the air lines. You're putting heat in the tyres on the ride there so there's bound to be inaccuracy in any tyre pressure checks you make inflating them. |
Number of posts : 1998 Age : 78 Location : Princeton, MN Points : 6050 Registration date : 2014-02-13
| Subject: Re: Tyre pressures Wed Sep 13, 2017 11:21 pm | |
| When I check my tire pressure it's been sitting in the garage. I use the same gauge to check them with all the time. I figure that any gauge can be off by a pound or two so that's why I use the same one all the time. At least this way the tire pressure is constant even if the gauge is a pound or two off.
I never check it after I've been riding for any length of time due to heat in the tire making the pressure go up. |
Jolly Bodger Maxi-Scooter Rider
Number of posts : 105 Age : 71 Location : Lancashire, UK. Points : 3087 Registration date : 2016-10-05
| Subject: Re: Tyre pressures Thu Sep 14, 2017 10:01 am | |
| Reading this, I thought to myself - "it's a while since I last checked my tyre pressure"
Rear 28 psi Front 20 psi
Oops - now back to 35 and 29
Don' know how long they've been that low but I'll make sure I check again before next ride
JB |
Number of posts : 3830 Age : 75 Location : Seaham, Co Durham, UK Points : 9675 Registration date : 2009-06-29
| Subject: Re: Tyre pressures Thu Sep 14, 2017 3:47 pm | |
| I have a rather tasty electric pump on which I can pre-set the pressure; it switches off when the tyre is at that pressure. It can be set in Bars, ft/lbs and something else I can't remember.
My COPD prevents me doing anything too strenuous so it's a god-send.
I also have a flexible extension which makes connecting pump to valve so much easier. |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4819 Registration date : 2012-04-05
| Subject: Re: Tyre pressures Thu Sep 14, 2017 4:10 pm | |
| 35 38 for me.More stable,better braking,lighter handlebars, less cosumption,worse feel in bumpy roads though.Try it ,the improvement is amazing.All my vechicles have higher pressure than suggested |
| Subject: Re: Tyre pressures Thu Sep 14, 2017 4:54 pm | |
| I've had no problems whatsoever since buying my Silver Wing using the recommended tyre pressures and suspension settings for a solo rider. They work for me all year round whatever the weather conditions and whatever road surface I have to ride on. I also use the recommended tyre and suspension setting for carrying a passenger, they work fine and Mrs M has no complaints.
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3292 Registration date : 2017-05-13
| Subject: Re: Tyre pressures Fri Sep 15, 2017 11:11 am | |
Best SWD Fully inflated tires increase wet weather traction, Under-Inflated tires decrease wet weather traction. A hard small foot print with its higher pounds per sq. inch pressure forces out the water allowing contact with the road surface, A soft large footprint does not force the water out and does not allow road contact, Result Hydroplaning. Safe wet weather operation is an art, Requiring practice and experience, Also running hi pressure in your tires. Never mind the belief of some that hi tire pressure wears out the center of the tire faster. I prefer buying Tires more often than waiting for the road rash on my Butt to heal. Happy motoring Lloyd 193. |
| Subject: Re: Tyre pressures Sun Sep 17, 2017 7:30 pm | |
| - micbusathens wrote:
- 35 38 for me.More stable,better braking,lighter handlebars, less cosumption,worse feel in bumpy roads though.Try it ,the improvement is amazing.All my vechicles have higher pressure than suggested
Micbustathens, You are absolutely correct, 35 front 40 rear cold, Absolutely best pressure with a 240 pound rider. These light weight guys can get by a pound or two less. A half million miles on silver wings with Bridgestone Hoop tires does not leave any doubt. Tires at these pressures do not cup, Get out of round, Do not require rebalancing, Handle superbly and do not shake. Happy motoring Lloyd 193. |
Number of posts : 3309 Age : 85 Points : 9435 Registration date : 2009-08-18
| Subject: Re: Tyre pressures Sun Sep 17, 2017 7:57 pm | |
| Who has ridden a SilverWing half a million miles? I stick with Honda recommended pressures and have no trouble---Note: Michelin Power Pure SC tire is rated max capacity at 33 psi...I tend to run with that with the Michelin on rear. As to Bridgestone scooter tires....I try to stay away from them...had 1 failure on Helix, 3 on ReFlex....all rear. My bikes are not overloaded My first SilverWing came with Hoops, don't remember anything special about them, but didn't buy them as replacements. |
Hondafreak Scooter Rider
Number of posts : 17 Location : San Antonio, Tx Points : 3140 Registration date : 2016-04-15
| Subject: Re: Tyre pressures Sun Sep 17, 2017 8:15 pm | |
| Look at your tire sidewall and see max pressure listed for that tire. Something a little under that will work. Most mc tires list max at 44 I use 41-42 psi for rear and 38-39 front. |
| Subject: Re: Tyre pressures Sun Sep 17, 2017 10:34 pm | |
| - john grinsel wrote:
- Who has ridden a SilverWing half a million miles? I stick with Honda recommended pressures and have no trouble---Note: Michelin Power Pure SC tire is rated max capacity at 33 psi...I tend to run with that with the Michelin on rear. As to Bridgestone scooter tires....I try to stay away from them...had 1 failure on Helix, 3 on ReFlex....all rear. My bikes are not overloaded My first SilverWing came with Hoops, don't remember anything special about them, but didn't buy them as replacements.
Hi John, I have put more than 500,000 miles on the 15 Silverwings I have owned, In the last 16 years. All have been equipped with Bridgestone Hoop tires, It has been my experience after installing about 1,000 Scooter tires that Bridgestone has no equal, Some people will not pay the price to have the best tires, They prefer to spend less. Today I own 16 Motor scooters mostly Honda and have owned and rebuilt bikes for more than 60 years, I am not some newbie posting on this sight. Lloyd 193. |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 5:13 am | |
| I get a kick out of this tire pressure thing. The PSI number written on side of tire==at what pressure the tire has its maximum load capacity, not its max. pressure.
SilverWing rides hard in best conditions---so I think, why make it worse by running higher than Honda recommened pressures. |
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4607 Registration date : 2014-11-20
| Subject: Re: Tyre pressures Mon Sep 18, 2017 6:48 am | |
A hard small foot print with its higher pounds per sq. inch pressure forces out the water allowing contact with the road surface, A soft large footprint does not force the water out and does not allow road contact, Result Hydroplaning. You're wrong bud, hydroplaning is not caused by over or under inflated tyres, it's caused by water pressure that happens between the road surface & the tyre surface, it occurs when the tyre cannot clear the water fast enough, which is caused by, going too fast, worn tyre tread, or a combination of both. Even with totally worn treads you can avoid hydroplaning by going slow enough for the weight of the vehicle to displace the water under the tyres. Secondly, for our UK readers, the construction & use regulations require .... "Tyres must be suitable (of the correct type and size) for the use to which the vehicle is being put, and must be inflated to the vehicle or tyre manufacturers’ recommended pressures." The police &/or VOSA can (& do) check tyre pressures (generally in the event of an accident) so think on before overinflating them as has been reccomended by some members ... "The penalties for offences related to the use of faulty tyres on vehicles can be quite severe." ..... // ..... "for every offence there is a fine at level 4 of the standard scale with discretionary disqualification and compulsory driving licence endorsement with 3 penalty points." .... // .... "Level 4 is currently £2500 and each faulty tyre is considered as a separate offence." From the above you can deduce that a) correct tyre inflation is tacken seriously b) a bad day could suddenly get a whole lot worse (particularly if the policeman is low on ticket handouts) |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 8:59 am | |
From the above you can deduce that a) correct tyre inflation is tacken seriously b) a bad day could suddenly get a whole lot worse (particularly if the policeman is low on ticket handouts)[/quote Bud, You should re take your Physics Classes! More comments from over yonder. Lloyd193 |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 12:16 pm | |
| Nah, don't think so bud, apparently ..................
"The term hydroplaning is commonly used to refer to the skidding or sliding of a cars tires across a wet surface. Hydroplaning occurs when a tire encounters more water than it can scatter. Water pressure in the front of the wheel pushes water under the tire, and the tire is then separated from the road surface by a thin film of water and loses traction. The result is loss of steering, braking and power control."
That is a comment from your side of the pond, taken from ... http://www.safemotorist.com/articles/Hydroplaning_Basics.aspx ... Please note well, that, that page is ...... Presented by the American Safety Council, maybe they are better educated than your physics teacher
Also please note ....
How do I Avoid Hydroplaning?
The following are important tips to avoid hydroplaning:
1. Keep your tires properly inflated
...... NOT overinflated or underinflated, properly, I read as vehicle manufacturers specification |
greenspam Scooter Rider
Number of posts : 9 Location : Chicago Points : 2649 Registration date : 2017-08-17
| Subject: Re: Tyre pressures Mon Sep 18, 2017 12:28 pm | |
| just go with the recommended tire pressure for original tires and follow the manufacturer's recommendation if you switch tire brand. |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 4:54 pm | |
| - The Bern wrote:
- Nah, don't think so bud, apparently ..................
...... NOT overinflated or underinflated, properly, I read as vehicle manufacturers specification The Bern, I have given you information learned from 65 years of motorcycle-motorscooter experience and maintenance, If you choose to ignore my information, Join your associates over yonder. Lloyd 193. |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 5:23 pm | |
| But in US we really have no safety rules/Inspections on what you can do/modify to your bike--- and there is lots of junk running around. I spent over 40 years overseas and really see the sense in EU/UK/Japan rules on bike/tire pressures, etc Also have BSc Safety degree/worked with military motorcycle/operator issues for over 40 years. Hydro Planing as operator=not fun,,,,at least twice it almost got me....Iowa, SR500, caused me to cross 2 lanes with no control, Knoxville TN, Helix, deep ridges/heavy rain--survived upright. Germany posts roads with standing water possibility at 80kph/50mph about the speed where danger starts. Too fast for conditions can get you. |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 5:30 pm | |
| As you claim you've owned 15 Silver Wings and clocked up 500,000 miles on them in the last 16 years, have you ever thought of taking it up with Honda that the tyre pressure information printed in the Silver Wing Owners Handbook and the Factory Service Manual are so obviously incorrect and misleading? Or contacted Bridgestone and IRC informing them that Silver Wing riders are riding round on their tyres under inflated.
You've obviously clocked up more miles than the original Honda Development Engineers and Test Riders, the equivalent to riding round the world a few times, and you're 200,000 miles ahead of Mr Grinsel on maxi mileage given he had a ten year start.
All this knowledge and experience, yet it's taken you 16 years to find this website. |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 5:54 pm | |
| - lloyd193 wrote:
The Bern, I have given you information learned from 65 years of motorcycle-motorscooter experience and maintenance, If you choose to ignore my information, Join your associates over yonder. So basically nothing you have written thus far can be substanciated from any official source, tbh I couldn't give a flying one how long you have been riding or how many miles you think you have travelled, please stop trying to pass off your opinion as scientific fact when clearly it is not. What exactly do you mean by .............. "Join your associates over yonder." ...?? |
| Subject: Re: Tyre pressures Mon Sep 18, 2017 7:14 pm | |
| - The Bern wrote:
What exactly do you mean by .............. "Join your associates over yonder." ...?? The Bern, Even your Avatar is Silverwing incorrect. Happy motoring Lloyd 193. |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3158 Registration date : 2017-09-07
| Subject: Re: Tyre pressures Mon Sep 18, 2017 10:14 pm | |
| - Smaug wrote:
- My advice is to follow the manual, unless you a re REALLY big. (and 200 lbs. isn't)
I go the other way from steve_h80: I leave it at the recommended solo pressure, even when I do the odd 2-up ride. (seems like he's 2-up often enough to leave it at the higher pressure) Smaug, you are correct. I am a conservative rider, and go for reasonable speed and high MPG. But my high tire pressures for high MPG backfired on me. I had a slow speed spill on my BMW F800 ST that happened exactly as you describe yours. I felt like I hit wet glass while riding downhill on a blacktop country road that had some residual slime from the previous day's rain. I tired to analyze the cause and found the following: 1. Speed was not the issue (about 25 MPH) 2. Too much pull on the front brake, even on a mild turn. (pilot error) 3. Tire pressures way too high: about 50 in the back and about 40+ in the front. |
Number of posts : 2598 Age : 65 Location : Bay Area, Ca Points : 8645 Registration date : 2008-12-19
| Subject: Re: Tyre pressures Mon Sep 18, 2017 10:30 pm | |
| I have been reading this topic, as have the other mods, and I feel I need to chime in on this topic. Everyone can post how they view the topic of 'air pressure', but for safety reasons, we "Mods" want to impress on everyone that the Tire manufactures psi should be taken seriously. .
If anyone decides to 'not follow the tire makers' recommendations, please do not hold this site responsible. We just don't want 'new riders' to follow the wrong recommendations and then something happens to them. Safety is very important to the majority of us on this site. |
| Subject: Re: Tyre pressures Tue Sep 19, 2017 5:54 am | |
| - lloyd193 wrote:
:lol!: :lol!: :lol!: Oh dear, cannot find fault in my writing, results to finding fault in my avatar, gosh I'm upset, that was really hurtful :lol!: :lol!: :lol!: |
| Subject: Re: Tyre pressures Tue Sep 19, 2017 10:40 am | |
| Lloyd
I've assigned you the Silverwing image as an avatar. You can please stop adding the Silverwing image to the sig line of your posts. It does tend to eat into the (costly) bandwidth of the forum.
If you'd rather not have that avatar please let me know and it will be removed
| Subject: Re: Tyre pressures Tue Sep 19, 2017 3:15 pm | |
| Wow, this thread is almost as entertaining as a darkside thread |
| Subject: Re: Tyre pressures Tue Sep 19, 2017 3:44 pm | |
| - Meldrew wrote:
- As you claim you've owned 15 Silver Wings and clocked up 500,000 miles on them in the last 16 years, have you ever thought of taking it up with Honda that the tyre pressure information printed in the Silver Wing Owners Handbook and the Factory Service Manual are so obviously incorrect and misleading? Or contacted Bridgestone and IRC informing them that Silver Wing riders are riding round on their tyres under inflated.
All this knowledge and experience, yet it's taken you 16 years to find this website. Mildew, Thanks I have only had time recently for Comic relief. |
| Subject: Re: Tyre pressures Tue Sep 19, 2017 4:40 pm | |
| - lloyd193 wrote:
- Mildew, Thanks I have only had time recently for Comic relief.
Mildew! You think that's original? You're the tenth person to say that since 2011. |
| Subject: Re: Tyre pressures Tue Sep 19, 2017 8:02 pm | |
Best SWD I'm a Mother Honda fan. As a result I go by the book on my tire pressures. I figure somewhere Honda is paying a very large salary to someone with a lot more education than I have to keep Honda out of class action lawsuits. By golly if they specify a pressure, that's what I'm going with. I'm not about to arm chair quarterback their decisions. Honda does not manufacture any tires, The tire pressure stated by Honda is a starting point. Using Bridgestone tires the best pressure cold is 35 Front 40 Rear. We are talking a 550 pound bike 200 pound rider and with a passenger a 1000 pound load on your tires. Happy motoring Lloyd 193. |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 4:31 am | |
Happy motoring Lloyd 193. And still he continues, you lost this one at the top of the page bud, just to remind you ..... - The Bern wrote:
- lloyd193 wrote:
The Bern, I have given you information learned from 65 years of motorcycle-motorscooter experience and maintenance, If you choose to ignore my information, Join your associates over yonder. So basically nothing you have written thus far can be substanciated from any official source, tbh I couldn't give a flying one how long you have been riding or how many miles you think you have travelled, please stop trying to pass off your opinion as scientific fact when clearly it is not. As far as I can see since those post, all you have managed to do is attempt to take the piss out of an avatar & a member name, :lol!: :lol!: |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 5:37 am | |
| Show some respect bud, he's 77 and has 65 years of motorcycle and motorcycle experience. He's also owned 15 Silver Wings, and despite fitting hundreds of new tyres, needed someone to install an avatar for him. I'm quite intrigued as to what a 12 year old boy would be legally allowed to be ride on US roads way back in 1951. The stock go to fib and get out clause 'over yonder' is to say it was on a farm or ranch land on an old Cushman scooter. A variation on the Cushman theme is an old barn find Indian, an ex WW 2 Harley, or whatever bike that Jim Bob in 'The Waltons' TV series use to ride. There's not a lot of forum cred saying it was actually one of those Schwinn push bikes that they used to advertise in the 1950’s American comics. |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 9:22 am | |
| - Meldrew wrote:
- Show some respect bud, he's 77 and has 65 years of motorcycle and motorcycle experience. He's also owned 15 Silver Wings, and despite fitting hundreds of new tyres, needed someone to install an avatar for him.
There's not a lot of forum cred saying it was actually one of those Schwinn push bikes that they used to advertise in the 1950’s American comics. Hi Mildew, No it was a used Whizzer sold by Auto Lec Auto supply stores, I bought it in cardboard boxes and reassembled it for use on my first newspaper route. I wasn't able to buy my first Cushman Highlander until I was 12 the following year. I was forced to operate illegally until my Civil Air Patrol Identification papers arrived, At that time CAP was a United States Air Force Auxiliary and my ID served as my drivers license. Once I had my Pilot License and my Chief Master Sargent Stripes accompanied by USAF certificate of proficiency with Nathan Twining's letter and signature at 13 and had accumulated about 600 hours by 14, The cops were too embarrassed to question me again, Since I had moved up to my Cushman Eagle with its Aircraft landing headlight and had acquired the Evening Newspaper route to go along with my morning route. At that time I had more money in my pocket than most grown ups, I have been blessed by the Lord Jesus my entire life and have been given knowledge, Ability and huge success. Many have shown contempt and jealousy for my lifelong accomplishments, I simply ignore them and continue moving ahead helping all who will accept my help. Happy motoring Lloyd 193. |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 9:57 am | |
| - lloyd193 wrote:
- Once I had my Pilot License and my Chief Master Sargent Stripes accompanied by USAF certificate of proficiency with Nathan Twining's letter and signature at 13
So if my math's are right (2017-77+13) you got your Chief Master Sargent Stripes in 1953 ?
| Subject: Re: Tyre pressures Wed Sep 20, 2017 9:59 am | |
| How could you have had chief master sgt stripes at 12?-----the rank did not come along until 1959. |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 10:09 am | |
| Similar thought to me John, a quick search reveals ....
"By LAW, one must have ten years enlisted service to be promoted to E-9 in any of the armed forces. By regulation (Air Force Instruction 36-2502), the Air Force requires a minimum of 14 years service (thus going beyond the law).
Since one cannot legally enlist before one's 17th birthday, one could not legally be a CMSgt before age 27...but the AFI makes the person wait until at least age 31. Source(s): MSgt, USAF (Retired) Judge Advocate General's Corps "
Taken from a discussion here .... https://uk.answers.yahoo.com/question/index?qid=20071023085054AAboxeI |
| Subject: Re: Tyre pressures Wed Sep 20, 2017 10:23 am | |
| Now that everyone has made their off-topic point; no win or lose.
Topic locked.
| Tyre pressures | |
