Brake lever modification I_icon_minitimeby MikeO Yesterday at 6:23 pm
Brake lever modification I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Brake lever modification I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Brake lever modification I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Brake lever modification I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Brake lever modification I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Brake lever modification I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Brake lever modification I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Brake lever modification I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Brake lever modification I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
lawnfan
Number of posts : 3
Registration date : 2017-10-07
Brake lever modification Empty
PostSubject: Brake lever modification   Brake lever modification I_icon_minitimeSat Oct 07, 2017 8:38 am
I have a 2005 FSC600D/A (?). My fingers do not reach/rest on the brake levers comfortably and therefore tend to rest on the grips. Can I bring the lever closer to the grips or replace them with levers that rest closer to the grips? And where can I find such replacement parts, I couldn't find any but I'm not to good at these things (bikes, computers).
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeSat Oct 07, 2017 9:00 am
While I don't recall any mention of adjustable levers here on this forum you might try Revzilla.com for adjustable brake & clutch levers. Keep in mind that the left lever on a Silverwing is not the same as a typical clutch lever though. Silverwing left levers also activate the brake/start switch.
Here is a link to a manufacturer of custom levers: http://asvinventions.com/Unbreakable-Levers
Hope this helps
lloyd193
lloyd193
Number of posts : 327
Registration date : 2017-05-13
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeSat Oct 07, 2017 2:14 pm
Hope this helps
From time to time I service Silverwing's and other bikes for small handed Female Riders, They have a problem reaching the brake levers. By removing the Shoulder fastener, The lever will come off the Master cylinder. Apply a small piece of sticky tape to the stop area on the master cylinder after cleaning it.
This will prevent the lever returning to it's outermost position, Carefully of the switch lever arm.
Make sure that the sticky tape is not so thick that it holds the switch on and activates the stop light.
A second method I use is to drill the lever at the high area where it contacts the stop, Tapping the hole for an 8/32 machine screw allows for adjustment.
A 8/32 machine screw nut serves as a jam nut against the foreword portion of the lever.
Adjusting the machine screw in causes the handle to stop nearer the handlebar grip.
Again be sure that the adjustment does not cause the stop light to remain on, Sometime I find it necessary to carefully bend the Brake Light switch arm so that I can get the proper adjustment.
Be sure you do not adjust to the point that the Brakes are dragging.
Happy motoring Lloyd 193.
Number of posts : 1036
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeSun Oct 08, 2017 4:29 am
The sw levers have a lot of travel anyway so treat any modification with extreme care, you don't want to be in a situation where the lever hits the bar before applying full braking effect.
lawnfan
Number of posts : 3
PostSubject: THANK YOU   Brake lever modification I_icon_minitimeSun Oct 08, 2017 11:51 am
THANK YOU.
ChrisPsw
ChrisPsw
Number of posts : 11
Registration date : 2017-09-04
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeWed Oct 18, 2017 2:37 am
Webike.com has adjustable lever for silverwing I bought some waiting for them to come in.
ChrisPsw
ChrisPsw
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeWed Oct 18, 2017 2:39 am
Brake lever modification Img_0014
ChrisPsw
ChrisPsw
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeWed Oct 18, 2017 5:07 am
I'm sorry guys the website is called Japan.webike.net
ChrisPsw
ChrisPsw
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeThu Nov 02, 2017 1:12 am
Brake lever modification Cffd1510
Brake lever modification 457a7610
Brake lever modification 960ceb10
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeThu Nov 02, 2017 12:59 pm
Nice looking levers. Nice photos too. Do those levers have any advantage other than to adjust them to more finger friendly position?
What's the story on the mirrors? Kind of unique.
ChrisPsw
ChrisPsw
PostSubject: Re: Brake lever modification   Brake lever modification I_icon_minitimeThu Nov 02, 2017 1:27 pm
Hey Tim!
The levers are mainly. For finger positions other then that and looks. I believe that’s all. Lol. And the mirrors I got awhile back for my cbr250r. Since I’m selling the cbr250r I put the stock mirror back on it. Figured I would try them out on the silverwing. So far I really like em. And the levers.
» Brake Lever Change
» Parking Brake Lever
» Brake lever feels like air in lines
» HELP - Front brake lever locking up!
» Brake light only working on one lever
