SteveSilverWing Maxi-Scooter Rider
Number of posts : 133 Age : 69 Location : Los Angeles, California Points : 3676 Registration date : 2015-04-17
| Subject: Oil Leak at Oil Filter? Tue Nov 28, 2017 6:17 pm | |
| First topic message reminder :
Hi all Swing folks!
I'm experiencing yet another oil leak that has me confounded to say the least. I seem to be leaking oil from where the oil filter fits on. It is a minor oil leak. I am 150 miles past due for the usual oil change -- odometer is at 16,150. The oil and filter are on their way from Partzilla.com.
I check the oil at least once per month since I had an oil leak last year from a leaky stator cover silicon seal. I follow the maintenance schedule per the Honda Service Manual.
When I checked on the oil filter last week, I found that it was not tightly in place. I was able to tighten it a good ¾ turn or maybe a little more. In order to see things better, I took off the lower left side panel. The leak seems to be coming from where the oil filter seats, or perhaps the surface of the oil cooler. I used a flashlight and found no leak coming from above the oil filter area.
Have any of you had this type of oil leak issue caused by perhaps an older filter or perhaps the mounting surface it adheres to? The O-ring worn out? I’ll not be able to check until I receive the new oil and filter on Thursday.
As always, any help or advice would be greatly appreciated!
Steve in Los Angeles, California
