| problems getting the key in the hole | |
+6DickO exavid MikeO Waspie honda_silver tankyuong 10 posters |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6291 Registration date : 2009-07-12
| Subject: problems getting the key in the hole Thu Dec 03, 2009 11:37 pm | |
| Am I the only one who has the key problem in the ignition, I end up flipping the key around thinking it would be better but no so it takes me at least a minute.The key wold go in but not all the way. |
Number of posts : 2453 Location : Georgetown, Tx Points : 8365 Registration date : 2008-12-23
| Subject: Re: problems getting the key in the hole Thu Dec 03, 2009 11:57 pm | |
| - tankyuong wrote:
- Am I the only one who has the key problem in the ignition, I end up flipping the key around thinking it would be better but no so it takes me at least a minute.The key wold go in but not all the way.
Use graphite powder to lubricate the lock and the key, then work the power in ... both will slide much easier.
Last edited by honda_silver on Fri Dec 04, 2009 10:09 am; edited 1 time in total |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8141 Registration date : 2009-07-26
| Subject: Re: problems getting the key in the hole Fri Dec 04, 2009 5:24 am | |
I had the same problem and did as you did, rotating the key. (That was from new). By new I mean I obtained the bike in September this year, (09), but in fact the bike is a 07 model so in reality it may have sat in storage for two years. However I have since lubricated the key and worked the key in and out of the key hole several times. Worked for me, not a problem any more. |
Number of posts : 3837 Age : 75 Location : Seaham, Co Durham, UK Points : 9699 Registration date : 2009-06-29
| Subject: Re: problems getting the key in the hole Fri Dec 04, 2009 5:32 am | |
| Same here - just sliding the key in. I must lubricate it. |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8391 Registration date : 2009-07-17
| Subject: Re: problems getting the key in the hole Fri Dec 04, 2009 8:46 pm | |
| My 2004 SW is also touchy about accepting the ignition key. It really wants the key inserted at the right angle and doesn't care which side of the key goes up or down. The glove box and seat lock isn't nearly as particular. |
| Subject: Re: problems getting the key in the hole Fri Dec 04, 2009 10:52 pm | |
| - exavid wrote:
- My 2004 SW is also touchy about accepting the ignition key. It really wants the key inserted at the right angle and doesn't care which side of the key goes up or down. The glove box and seat lock isn't nearly as particular.
So did you lube it described? I wonder if wd40 works |
DickO Founding Member
Number of posts : 1020 Age : 79 Location : Atchison, KS Points : 6957 Registration date : 2008-12-23
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 12:08 am | |
| Hi "Tank", You can use WD-40 and it will probably work okay but will be much less of a long term fix. Your best bet is to get the graphite powder for locks that honda_silver recommended. The WD-40 will tend to 'collect' dust and dirt wherever it settles in that lock mechanism, whereas the graphite serves more as a cleaner and polisher of all the metals in there. That's not very scientific but I think it's the gist of the matter. |
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 12:09 am | |
| - tankyuong wrote:
- So did you lube it described? I wonder if wd40 works
WD40 is not a lubricant. http://www.masterlock.com/general/faqs_careandservice.shtml 6. We suggest that you do not use WD40 on your lock because dust particles may clog the pins when WD40 is sprayed inside the lock. |
skiwoods Maxi-Scooter Rider
Number of posts : 179 Age : 63 Location : NW Suburbs of Chicago Points : 5962 Registration date : 2008-12-29
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 1:05 pm | |
| Way too many jokes come to mind while reading this thread... |
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 2:04 pm | |
| - DickO wrote:
- Hi "Tank",
You can use WD-40 and it will probably work okay but will be much less of a long term fix. Your best bet is to get the graphite powder for locks that honda_silver recommended. The WD-40 will tend to 'collect' dust and dirt wherever it settles in that lock mechanism, whereas the graphite serves more as a cleaner and polisher of all the metals in there. That's not very scientific but I think it's the gist of the matter. Where can one get graphite lube? |
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 2:10 pm | |
| - tankyuong wrote:
- Where can one get graphite lube?
Automotive parts store will have. |
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 5:14 pm | |
| Whenever I park my SWing I always lock the handlebars.
After I came out of the store this morning, the key was hard to slide into the ignition about half-way and would not fit anymore. When I tried to position the handlebars to ease the key ... the handlebars were not locked ... but the key was in the locked position. I have never seen this happen before.
So I had to keep fidgeting with the handlebars till I could get my key to slide the rest of the way ... I was wondering if I was going to be able to free up the ignition. With a little time 1-2 minutes and patience I was finally able to fit the key and move it to the unlocked position.
Since I have the extended Honda warranty, I drove straight to my Honda dealer in Georgetown, Tx. They took my SWing right away into the shop area to check the ignition. They lubricated the ignition and did not find any problems with the ignition .... I did not expect them to ... but I wanted to make sure it was documented. They did document the problem in my history if the problem keeps reoccurring.
I would be curious if this happened to anyone else? |
crahar Super Scooter Rider
Number of posts : 283 Age : 76 Location : Beaumont, Texas Points : 5850 Registration date : 2009-08-31
| Subject: Re: problems getting the key in the hole Sat Dec 05, 2009 10:22 pm | |
| Had a problem with mine, stoped to get gas and when I was ready to leave the key would not go all the way into ignition switch. Could not get graphite or wd40 at the store I was at but they did have rubbing alcohol which I poured about 2 teaspoons in the slot while trying to work the key in and it started working. Next stop was auto parts store where I picked up graphite and lubed the slot.I think that dust settles on top of the switch and gets in when the key is inserted which causes thinks to start sticking. |
KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8151 Registration date : 2009-01-19
| Subject: Re: problems getting the key in the hole Sun Dec 06, 2009 3:54 am | |
| Quote... Skiwoods "Way too many jokes come to mind while reading this thread... " Man, I've been fighting the urge to answer this, but?????? Thanks for the lead.... Maybe the Wylie E Coyote's ACME Hair Restorer could work. It worked on that pesky rabbit! |
| Subject: Re: problems getting the key in the hole Fri Dec 25, 2009 1:21 pm | |
| I've had the same trouble from day one of my new '03. Locksmith said this wasn't the usual Honda quality and was a POS.
I used some 180 grit sandpaper to smooth the key's edges and graphite which did help some, but still have to make a conscious effort to make sure and insert the key squarely into the keyway. Doesn't like any offset. Also make sure your key is still straight, any slight bend from pissed off torqueing will add to the problem.
Also the weather cap on the keyway can turn independantly of the keyway itself, which will block the key from entering if the two aren't aligned. This is a defect, but Honda doesn't seem to care. Their attitude seems to be "well you can keep diddling with it and it'll eventually go in." An $8,000 machine shouldn't need to be "diddled with"
WhitSTer |
| Subject: Re: problems getting the key in the hole Fri Dec 25, 2009 4:36 pm | |
| That sounds like the same problem my SW has but not quite as bad as that. It requires a careful lineup before trying to insert the key. It's not the key itself but the entry into the warding of the lock. Apparently it was manufactured with no lead in at all just square cut at the entry, normally there's a bit of taper to the input side of the wards to help guide the key but mine doesn't have any at all. The other two locks on the bike work quite easily and will allow a little misalignment of the key when inserting it. It really isn't much of a problem, more like a small irritation about every fourth time I put the key in. |
| Subject: Re: problems getting the key in the hole Fri Dec 25, 2009 9:34 pm | |
| I am having problems restraining myself!!!!!! |
| Subject: Re: problems getting the key in the hole Fri Dec 25, 2009 11:02 pm | |
| - KurtPerthWA wrote:
- I am having problems restraining myself!!!!!!
Yep. Giggling like a high school freshman here... |
jimjotel Scooter Rider
Number of posts : 77 Age : 74 Location : atlanta ga. Points : 5550 Registration date : 2009-12-01
| Subject: Re: problems getting the key in the hole Sat Dec 26, 2009 11:02 pm | |
| yep, same problem here and i just bought my 2008 this year in march, i used graphite powder and have not had much trouble since. |
| Subject: Re: problems getting the key in the hole Mon Feb 08, 2010 6:27 am | |
My name is Roberto, I live in Florence, Italy. I have the same key problem all the time. Is there a solution? |
| Subject: Re: problems getting the key in the hole Mon Feb 08, 2010 7:26 am | |
| Hello Roberto and welcome! Solutions? Only what's in the thread, I fear. |
| Subject: Re: problems getting the key in the hole Mon Feb 08, 2010 7:34 am | |
| thank you for answering. But on the chat I found somebody putting some graphyte powder in the hole. It may help a bit. |
| Subject: Re: problems getting the key in the hole Tue Feb 09, 2010 3:20 pm | |
| - skiwoods wrote:
- Way too many jokes come to mind while reading this thread...
In that context a tight fit is preferable. |
| Subject: Re: problems getting the key in the hole Tue Feb 09, 2010 3:21 pm | |
| Ditto the dry graphite suggestions. Don't use anything liquid or it'll just make the problem worse when it attracts dirt. |
| Subject: Re: problems getting the key in the hole Tue Feb 09, 2010 3:32 pm | |
| - mickey wrote:
- Ditto the dry graphite suggestions. Don't use anything liquid or it'll just make the problem worse when it attracts dirt.
There are problems for and against grease as well as liquids. Grease can harden in certain conditions making the insertion difficult, in high temps grease can liquify! There is a key guard that will protect the keyway from ingress of dirt so grease or a liquid lubricant would be preferable to a dry keyway. |
| Subject: Re: problems getting the key in the hole Tue Feb 09, 2010 8:37 pm | |
| Subject: Re: problems getting the key in the hole Tue Feb 09, 2010 8:38 pm | |
