Main beam problem? I_icon_minitimeby JohnyC Today at 5:39 am
Main beam problem? I_icon_minitimeby JohnyC Yesterday at 10:04 am
Main beam problem? I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Main beam problem? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Main beam problem? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Main beam problem? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Main beam problem? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Main beam problem? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Main beam problem? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Main beam problem? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Main beam problem?
4 posters
Number of posts : 921
Main beam problem? Empty
PostSubject: Main beam problem?   Main beam problem? I_icon_minitimeWed Apr 18, 2018 1:44 pm
On Sunday I was out riding and got caught in a thunderstorm, when I pulled over to change gloves I stopped the engine. When I started up again I noticed main beam light on I pressed the passing switch several times and nothing happened, it stayed on. Going about a hundred yards main beam light went out, but came on once or twice, on the way home. When I got home I though water had gotten into the handlebar switch, so sprayed WD 40 into it. Today I went to fill up with fuel for my ride out, after putting fuel in, on starting up main beam light on again stayed on till I went over a bump in the road then went out and all was back to normal. I thought wiring was just from switch to headlight, is there another connection elsewhere I should check ? anyone had this problem?
PostSubject: Re: Main beam problem?   Main beam problem? I_icon_minitimeWed Apr 18, 2018 5:01 pm
There are several wire harness connections for the lights. The main headlight / front turn signal harness has a brown 9 pin connection. It's the one which you disconnect when you remove the Front Cover (fairing).
There are two connections for the left handlebar switches; one black 9 pin, and one red 6 pin. They are inconveniently tucked in under the handlebar covers and below the Combination Meter
There is one red 9 pin connection for the right handlebar switches --also below the CM
Best suggestion I have is to check continuity on the B/R to Bu/W wires of the red 9 pin connector for the right handlebar switch harness. That circuit should be CLOSED when the push to Start switch is in the rest position, and the circuit OPEN the Start switch is activated. When the Start switch is activated the OPEN B/R Bu/W circuit kills the current to the headlight.
It is possible that the Start switch terminals are dirty or corroded and that is what is causing the headlight to act erratic.
But first try a 'quick 'n dirty' test; give the right handlebar switch a good whack with a screwdriver handle when the headlight craps out. If the light comes back ON then...
My 2¢ opinion. HTH
EDIT: I should note that our North American FSC models don't have the "flash to pass" circuit like the UK FJS models.
Number of posts : 3314
PostSubject: Re: Main beam problem?   Main beam problem? I_icon_minitimeWed Apr 18, 2018 5:15 pm
Keeping it simple---try another standard bulb.
Number of posts : 1384
PostSubject: Re: Main beam problem?   Main beam problem? I_icon_minitimeWed Apr 18, 2018 5:55 pm
I'm working from Honda CAR experience here. Headlamp is always powered and works through the ground side. Needs to ground to come on. Try a bulb first filaments could be shorting making that ground.
PostSubject: Re: Main beam problem?   Main beam problem? I_icon_minitimeThu Apr 19, 2018 4:30 am
Thanks for all advice, will try new bulb first as suggested. Tinkering later today. Must admit i would not have thought bulb was the problem.
PostSubject: Re: Main beam problem?   Main beam problem? I_icon_minitimeFri Apr 20, 2018 4:17 am
I changed the main beam bulb as suggested, the old bulb appears okay but, that does not mean it is, time will tell if that was the problem, thanks again for all advice.
Main beam problem?
» HID low beam off when switched to high beam
» Headlight low beam
» Hi Beam Break Out Connector
» High Beam Usage
» control or narrow the beam of an LED light
