| What is it? Bolt holes in belt case | |
Ze'ev Scooter Rider
Number of posts : 24 Location : Israel Points : 3502 Registration date : 2015-03-14
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: What is it? Bolt holes in belt case Sat May 26, 2018 12:01 pm | |
| somebody knows what these 2 holes are for? i can see threadings inside but i dont remember taking something apart over there. ![What is it? Bolt holes in belt case Img_2010](https://i.servimg.com/u/f62/19/91/81/63/img_2010.jpg) |
Pastor Ron Silver Wing Rider
Number of posts : 400 Age : 72 Location : Asheville,NC Points : 4697 Registration date : 2013-02-24
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sat May 26, 2018 2:04 pm | |
| I am not sure...to screw in puller? |
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sat May 26, 2018 2:39 pm | |
| Some kind of puller a bit more "official" than this puller by the legendary Stephano Bonacasa. But you'll get the idea. https://m.youtube.com/watch?t=482s&v=I1ScWKkpZHo
Tim, |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sat May 26, 2018 4:08 pm | |
| No mention of a puller in the WSM, I wonder if they're for holding the casing to a fixture during a machining operation |
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sat May 26, 2018 6:45 pm | |
| - The Bern wrote:
- No mention of a puller in the WSM, I wonder if they're for holding the casing to a fixture during a machining operation
I'd have to agree with you. That bearing could be pulled with a expandable tool no need for for threaded holes there for a puller. Large center hole for centering outer case on a fixture. Video not in english so who knows. Made his own bearing puller from a few bolts good idea. If he threaded center hole and used a small slide hammer would have pulled bearing. Maybe a little heat it would come out better. |
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sat May 26, 2018 10:23 pm | |
| What I remember doing (if my memory serves me correctly), when I had a Burgman, I used those two holes to screw in two bolts ( a little at a time) left side then right side a 1/4 turn , left side then right side until inner contact was made that popped off cover for me to get to the belt. |
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sun May 27, 2018 4:03 am | |
| - Mech 1 twa wrote:
I'd have to agree with you. That bearing could be pulled with a expandable tool no need for for threaded holes there for a puller. Large center hole for centering outer case on a fixture. Video not in english so who knows. Made his own bearing puller from a few bolts good idea. If he threaded center hole and used a small slide hammer would have pulled bearing. Maybe a little heat it would come out better. Indeed bud, WSM says to warm the casing with a heat gun sufficient for the bearing to drop out & to fit new bearing with a drift. |
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sun May 27, 2018 4:05 am | |
| - Pastor Ron wrote:
- What I remember doing (if my memory serves me correctly), when I had a Burgman, I used those two holes to screw in two bolts ( a little at a time) left side then right side a 1/4 turn , left side then right side until inner contact was made that popped off cover for me to get to the belt.
:Happy Holiday: That sounds good bud, very similar to ejecting brake drums on a car :Happy Holiday: |
RazorbackUofA Scooter Rider
![RazorbackUofA](https://2img.net/u/3413/63/00/33/avatars/4728-69.jpg)
Number of posts : 85 Age : 68 Location : Arkansas Points : 2818 Registration date : 2017-04-23
![What is it? Bolt holes in belt case Empty](https://2img.net/i/empty.gif) | Subject: Re: What is it? Bolt holes in belt case Sun May 27, 2018 4:59 pm | |
| yes its to pull that cover off as sometimes its stuck and easy to break if ya try to pry it off |
