Final drive Gear issue I_icon_minitimeby sonuvabug Today at 4:19 pm
Final drive Gear issue I_icon_minitimeby sonuvabug Today at 4:17 pm
Final drive Gear issue I_icon_minitimeby sonuvabug Today at 4:06 pm
Final drive Gear issue I_icon_minitimeby JohnyC Yesterday at 10:04 am
Final drive Gear issue I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Final drive Gear issue I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Final drive Gear issue I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Final drive Gear issue I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Final drive Gear issue I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Final drive Gear issue I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
RazorbackUofA
RazorbackUofA
Number of posts : 85
Registration date : 2017-04-23
Final drive Gear issue Empty
PostSubject: Final drive Gear issue   Final drive Gear issue I_icon_minitimeSun May 27, 2018 5:32 pm
Short story: was on a day trip and ABS light came on, chked axle nut and was loose again... 2nd time in 6 mons.
i carry most tools to do most anything so out comes torgue and tighten nut to 106 foot pounds and a little extra... nut not gonna do that again..... OPPSEY   heard a not good crunch sound,  affraid  short story is hauled it back home on a pals trailer dissembled the rear end and gear box and found a destroyed wheel axle bearing ... Mad  what i get for well nm learned my expensive lesson, and yes somewhere in the past i forgot to use lock nut. Evil or Very Mad
so took the down time to replace all seals in forks and bearings in front and rear, oil/air filter, plugs, added more led lights and new paint job.
resembled and noticed a distinct grinding noise took gear cover back off and inspected ... i had already cleaned and removed all debris from the destroyed bearing... a few very minor blemishes on 2-3 gear but not enough to make the noise it made. so resembled after determining  there was nothing major wrong in gear box,  then after turning wheel .. with gear cover and gears off i noticed the break caliper was moving left and right.... now am thinking might have bent wheel axle, BUT i put a center point on axle as wheel turned and axle stayed centered, no play left and right of wheel.
on the oil lvl in the final drive what keeps all the oil 1 1/2 cups from eventually leaking out the over flow hole next to the wheel axle bearing ring lock?
a collection of of pics, the above you guys might like the info for your own issues.
used light shot as it saves the forum space.
http://prntscr.com/jnchz8
http://prntscr.com/jncill
http://prntscr.com/jncj3c shock seal
http://prntscr.com/jnck2o bearing distroyed
http://prntscr.com/jnclqi gears
http://prntscr.com/jncm7r
http://prntscr.com/jncnkz where bearing gous
http://prntscr.com/jncmyh
RazorbackUofA
RazorbackUofA
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeSun May 27, 2018 5:44 pm
http://prntscr.com/jncr36
anyway i found the whole think on ebay .. so will have all the extra parts i need to find the issue.
http://prntscr.com/jncrxm
RazorbackUofA
RazorbackUofA
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeSun May 27, 2018 7:02 pm
slow delivery but great parts selection for the wings
https://www.hondapartshouse.com/oemparts/l/hon/5053f2eef870021c54be6c91/2008-fsc600a-ac-parts
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeMon May 28, 2018 5:18 am
That's a bugger, personally, I'd change the complete unit, you've already done most of the work, simply take off the variator, undo 6 bolts & the shock absrorber bottom bolt & you're good to go.
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeMon May 28, 2018 5:29 am
RazorbackUofA wrote:
.../snipped/ ...
Turning that upside down, there is/should be an oil seal inside the gearbox housing between the final bearing & the final drive gear that keeps the oil from draining.  If you have not fitted that seal you may well find the helix on the gears can force the shaft to move laterally & cause the gear teeth to touch the casing.
Oil seal is item #20 in your componants photo
RazorbackUofA
RazorbackUofA
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeMon May 28, 2018 12:54 pm
https://www.ebay.com/str/borescycle
thats the ebay seller. he scraps 2 wheelers for parts and thank you bern.
have discovered why the wobble..... apparently during the short distance i rode the bike before I determined i had a major issue .. about 1 mile it wore the splines out on the wheel hub splines look ok on the axle but wheel splines on 1 side look wore.
http://prntscr.com/jnony7 new seal outside view
http://prntscr.com/jnoomy new seal inside view red arrow points to over flow vent
how does the oil stay in seams like it would eventually leak out though that??
Number of posts : 1013
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeMon May 28, 2018 3:56 pm
Razor,
When I purchased my 2004 Swing I noticed rear wheel wobble. Discovered that the previous owner did not re-install the outer axle spacer after changing the tyre. This made it impossible to torque the axle nut to spec. I will be replacing both rear calipers and installing the missing spacer. Had to replace the rear wheel also. The splines were worn in the hub.
RazorbackUofA
RazorbackUofA
PostSubject: Re: Final drive Gear issue   Final drive Gear issue I_icon_minitimeMon May 28, 2018 5:27 pm
Easyrider wrote:
Razor,
ty ... good info i was concerned about the splines on if that was a rare issue
» Final Drive Oil
» final gear oil
» FINAL DRIVE OVERFLOW
» Final face squeal
» Final Drive Oil
