final gear oil I_icon_minitimeby sonuvabug Today at 4:19 pm
final gear oil I_icon_minitimeby sonuvabug Today at 4:17 pm
final gear oil I_icon_minitimeby sonuvabug Today at 4:06 pm
final gear oil I_icon_minitimeby JohnyC Yesterday at 10:04 am
final gear oil I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
final gear oil I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
final gear oil I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
final gear oil I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
final gear oil I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
final gear oil I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 final gear oil
Slick-Tenn
final gear oil Empty
PostSubject: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 8:52 am
Where do I find the drain and fill plug on my newly purchased used silverwing?
Also, what type of oil or lube is specified?
Also, why is this not in the owners manual?
Number of posts : 2778
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 9:13 am
Hi mle,
Welcome to the forum.
Here is the information you requested: https://www.silverwing600.com/pictorials-how-to-perform-maintenance-f21/changing-the-final-drive-oil-pictorial-t200.htm#943
and as far as what type of oil to use...I just use the same oil I use in the motor.
Number of posts : 2598
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 12:23 pm
mle,
Welcome to the site and hope you enjoy it. If you follow the link that Dennis gave you won't have to remove any covers at all and it is very simple. Just get some type of oil can with a long nozzle to fill your oil through the small hole. I have gear oil in it now but I think I will be putting the motor oil back in. If you read some of the posts about the final drive oil I'm thinking that syn motor oil may be better. Again welcome.
Slick-Tenn
Number of posts : 47
Registration date : 2010-07-19
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 1:25 pm
I too recently purchased an 03. I called my local Honda dealer and he said they use "Honda Gear Oil" - whatever that is. I drained out the old and it smelled like gear oil, so replaced it with 10 oz (the exact same amt I drained out) of Amsoil Severe Gear 80W90.
Number of posts : 2387
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 1:32 pm
My Honda dealer just uses whatever the service manual suggests, and that's Honda 10W-30 motor oil.
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 1:45 pm
Hi All,
This is what the Honda shop manual says:
Recommended final reduction oil.
Pro Honda GN4 or HP4 (Without molybdenum additives)
4-stroke oil or equivalent motor oil
API service classification: SG or Higher
JASO T903 standard: MA
Viscosity: SAE 10W-40
That's right from Honda, use anything you want....It's your bike but the manual is pretty straght forward about this!
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 2:01 pm
DennisB wrote:
Hi All,
That's strange, Dennis.
My factory service manual specs are:
Pro Honda GN4 4 stroke oil (USA and Canada) or equivalent
API: SG or higher
Viscosity: SAE 10W-30
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 2:16 pm
Hey bigbird, That's not strange...You must have a newer Honda shop manual then I have. Mines 2002 thru 2006.
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 2:36 pm
Well what's strange is that my manual applies for all years of Swing, 02-10. If something is specific to older models it's mentioned. So I assume that sometime after '06 Honda decided to spec 10W-30 for all Swing final drives.
Number of posts : 3837
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 3:47 pm
I think it's the same for other manufacturers; Piaggio have the same handbook for all X9s.....I think there were up to nine variants.
This resulted in customers being ripped off on occasions as service intervals were different on some models - the dealers always went for the shortest!
The last ones had service intervals stretched from 4000 to 6000 miles but the books didn't change.
buddy19520
buddy19520
Number of posts : 378
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeSun Aug 01, 2010 9:50 pm
bigbird wrote:
DennisB wrote:
Hi All,
API: SG or higher
Could your manual be specific to Canada? A lower viscosity could be fine in cooler temperatures, just like with engine oil.
BTW, my 2002-2003 FSC600 Honda Service Manual calls for 10w-40 for both the engine and final reduction.
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeMon Aug 02, 2010 12:21 am
No, I got it from Helm in the US.
I think that the newer Swing's have a different spec for oil, for whatever reason.
GaryL
GaryL
Number of posts : 237
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeMon Aug 02, 2010 1:27 am
My dealer told me that in 2006, Honda decided that the lighter weight oil provided 'sufficient' lubrication, so changed their recommendations to 10W-30 from 10W-40, although 10W-40 is still listed in the Service manual as acceptable under all conditions, just like 10W-30. This was also true with the GoldWing. Honda cars now use 5W-20 oil. The thinner oil makes for a slight improvement is gas mileage, all else being equal, or so they tell me.
PostSubject: Re: final gear oil   final gear oil I_icon_minitimeMon Aug 02, 2010 8:47 am
Finally, a dealer who appears to know something about the products they sell. A rare bird these days, it seems.
final gear oil
» Final drive Gear issue
» gear oil in final drive with out a picture
» LDComfort gear
» What if I overfill the gear oil?
» Baby's got Gear
