What if I overfill the gear oil? I_icon_minitimeby zrx212 Yesterday at 4:40 pm
What if I overfill the gear oil? I_icon_minitimeby Meldrew Yesterday at 4:37 pm
What if I overfill the gear oil? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
What if I overfill the gear oil? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
What if I overfill the gear oil? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
What if I overfill the gear oil? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
What if I overfill the gear oil? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
What if I overfill the gear oil? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
What if I overfill the gear oil? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
What if I overfill the gear oil? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
4 posters
CnR
Number of posts : 36
Registration date : 2014-06-27
What if I overfill the gear oil? Empty
PostSubject: What if I overfill the gear oil?   What if I overfill the gear oil? I_icon_minitimeFri Jul 10, 2015 12:28 pm
Good morning again all.
Wow, I am finding a ton of helpful information here. Thanks to all who have contributed time, and many wrenching hours on their SWings.
I have a little concern this morning. I changed my engine oil, and then changed my final drive oil. I went by the pictorial maintenance pictures (Thanks JeffR!!). As I was filling the final drive case, I noticed oil coming from the back side of the case. Right after i noticed that, the oil started coming out of the fill hole. Did I overfill it? Should I be concerned?
Please help, and thank you!!
CnR
NWSSC
NWSSC
Number of posts : 418
PostSubject: What if I overfill the gear oil?   What if I overfill the gear oil? I_icon_minitimeFri Jul 10, 2015 1:10 pm
It depends on how much the case is overfilled. Normally I let the oil run out until it stops.Although the final drive is quite small (to much lube causing foaming)I do not believe it is a concern.Some times when you over fill, the oil will drain out the fill hole and can leak between the cover and case and seep in to the belt area.To be on the safe side you could remove the drain bolt slightly and let some oil drain out. Howard
oldgwingguy
Number of posts : 247
PostSubject: Re: What if I overfill the gear oil?   What if I overfill the gear oil? I_icon_minitimeFri Jul 10, 2015 3:12 pm
When I saw one method I thought what the heck????? BUT putting new in the DRAIN hole makes some sense, squeeze it in there until it flows out of the TOP hole, quickly insert the DRAIN plug and you are good, a lot less messy and it beats pumping it in with an oil can IMHO.
PostSubject: Re: What if I overfill the gear oil?   What if I overfill the gear oil? I_icon_minitimeFri Jul 10, 2015 4:49 pm
Yep, that is the preferred method for filling the angle drive on outboard motors
» Which rain gear?
» Rain gear recommendations
» gear oil change
» LDComfort gear
» final gear oil
