Speedometer keeps going out  I_icon_minitimeby GHM-PM Today at 6:19 am
Speedometer keeps going out  I_icon_minitimeby xwelder Today at 3:57 am
Speedometer keeps going out  I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Speedometer keeps going out  I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Speedometer keeps going out  I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Speedometer keeps going out  I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Speedometer keeps going out  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Speedometer keeps going out  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Speedometer keeps going out  I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Speedometer keeps going out  I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
RazorbackUofA
RazorbackUofA
Number of posts : 85
Registration date : 2017-04-23
Speedometer keeps going out  Empty
PostSubject: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeFri Aug 10, 2018 8:27 am
lately the speedometer keeps going out and will start working has a wire short somewhere and 2 times in the last 6 mons the engine has cut out but only for 1-2 seconds leads me to think theres a bad connection in the ignition circuit somewhere, not sure if the 2 are related as they dont happen at same time.
so my Question is where is the speed sensor located? and any thoughts on why the motor had 2 flutters
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeFri Aug 10, 2018 8:51 am
Speedometer sensor is located at the rear wheel and is mounted on the final drive housing. Check for a frayed wire along the top of the belt case.
Check the ignition coil, high tension wires, and spark plug caps.
RazorbackUofA
RazorbackUofA
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeSat Aug 11, 2018 1:50 pm
ty i think you are talking about the very rear of the gear housing in the FD its bolted on i remember seeing it when i replaced the bearing .. and that wire i found it shorted out when i did all that work and repaired the fray will look at it again i did not put it back where it was inside the belt housing i laid it across the top and used zip ties. as for the flutter will do as you suggested it did it again a bit ago under acceleration so i paid close attention to its action it did not stop till i decelerated and hit the gas again ... so your suggestion that it could be plugs or ignition wires sounds well founded will let you all know.
craigory
craigory
Number of posts : 120
Registration date : 2011-06-25
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeTue Jun 04, 2019 5:48 pm
Hi Cosmic_Jumper,
Thanks for the tip about the frayed wire. Thanks to you I just finished replacing two of the three wires which had frayed all the way through, and now I have my speedometer back! The wiring had completely come out of the channel along the outside of the belt cover and wandered where it shouldn't (I think it was brushing the tire). After replacing sections of two of the wires I carefully ran the wiring back in the channel, but I couldn't find any way to secure it there. Apparently the outer cover is supposed to hold it in place by pushing up against it but, obviously, it can't be trusted because the wiring fell out once already. Any suggestions on ways to make it more secure? Thanks!
Number of posts : 1384
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeTue Jun 04, 2019 7:53 pm
Gorilla tape. Good stuff just clean all oils off first if any.
EvilTwin
EvilTwin
Number of posts : 190
Registration date : 2017-05-30
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeTue Jun 04, 2019 9:29 pm
I ran into this same issue. There is a plastic "H" molding that holds the wire in a cast recess that is then covered by the belt housing. Easy enough to miss it and let the wire hang free (DAMHIKT). Here is mine just after I spliced it back together:
Speedometer keeps going out  PpAsxhM
craigory
craigory
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeTue Jun 04, 2019 11:17 pm
Thanks EvilTwin. That's exactly how I left it when I was done, but not how I found it when I first removed the outer cover. It was completely loose from the channel and hanging in the breeze near the tire. I haven't had that cover off before, so it must have been left that way when it was last serviced at the shop a few months ago. A bit disappointing to say the least.
What year is your SWing? It is AMAZINGLY clean! Certainly not what my old 2002 looked like. Sad
craigory
craigory
PostSubject: Re: Speedometer keeps going out    Speedometer keeps going out  I_icon_minitimeTue Jun 04, 2019 11:18 pm
Thanks for the tip Mech 1 twa!
» new speedometer
» speedometer
» Speedometer correction
» Speedometer check.
» GPS vs indicated speed
