| Subject: Speedometer check. Wed Oct 21, 2009 6:41 pm | |
| I made a bracket today so I could mount my Magellan 2200T GPS on my Silverwing. I've been curious to see how much difference there would be between the SW's speedometer and the GPS. I was pleasantly surprised to find the error between them was no more than 3mph up to 70mph. In the 20-50mph range the difference seemed to be around 2.5mph or at least a bit more than 2mph but not quite 3mph. My SW has IRC tires which may produce a different error rate than other brands. |
jdeereanton Silver Wing Guru
| Subject: Re: Speedometer check. Thu Mar 11, 2010 12:41 pm | |
| Wow - no one responded to this?? 'sup crew?
Actually I am surprised no one joined in the great intentionally designed faulty OEM Speedometer vs. the all powerful infallible GPS dust up. Of course this may get it going...
Although exavid brought a new variable to the fore - tires. |
dspevack Silver Wing Guru
| Subject: Re: Speedometer check. Thu Mar 11, 2010 1:00 pm | |
| Yep. Speedometers average 10% over GPS readings. Some less. Some more. But thats the average. |
| Subject: Re: Speedometer check. Thu Mar 11, 2010 2:31 pm | |
| "Whoomp - there it is!"
I'm not sure about the averaging thing though. And I'll add an additional wrinkle - my wife and I travel together and ride the same route. I invariably accumulate 1.5 to 2.2 miles more on the odometer each tank full. I replace the tires on each bike at the same time and run the same pressures in each set of tires. Granted gravity has more effect on me (mass is greater).
What's that all about? |
| Subject: Re: Speedometer check. Thu Mar 11, 2010 2:50 pm | |
| Had to validate my ol' buddy Dale.
Gravity is an illision perpetrated by skinny people to make big people look bad. --Jackie Gleason |
DickO Founding Member
