Rollers weight  I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Rollers weight  I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Rollers weight  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Rollers weight  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Rollers weight  I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Rollers weight  I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Rollers weight  I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Rollers weight  I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Rollers weight  I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Rollers weight  I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Rollers weight
mrseanharford1
mrseanharford1
Number of posts : 14
Registration date : 2019-01-08
Rollers weight  Empty
PostSubject: Rollers weight    Rollers weight  I_icon_minitimeTue Jan 08, 2019 1:54 pm
Is one roller better than another and what's the benefit of more weight verses less weight. I have 2008 sw 600cc and never replaced them. I just replaced the starter the other day actually. Should I leave rollers alone. What's the going rate for a
Mechanic to charge hourly?
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeTue Jan 08, 2019 3:38 pm
Have you taken note of the Introductions section on the forum home page?
mrseanharford1
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeTue Jan 08, 2019 5:08 pm
Sorry Tim, just did signed up yesterday regards Sean
Number of posts : 3313
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeTue Jan 08, 2019 7:39 pm
Why not first describe bike, miles,, service record---belt been changed?
Lots of miles, 50,000 or so maybe change rollers//sliders with OEM parts.....worked for me in over 90,000 SilverWing miles.
Can't do yourself----shop time probably $100-$150 per hour---look at belt/rollers/change belt should in done in about an hour.....by Honda shop that has done it before!
mrseanharford1
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeTue Jan 08, 2019 8:57 pm
Thanks for that, SW 600cc 2008 serviced regularly, belt changed 3 times, I have 39000 miles on clock, never done anything with sliders.
Number of posts : 2621
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeWed Jan 09, 2019 7:21 am
Sliders are after market. Honda uses rollers. So if yours is stock then you have 39K on stock rollers? That is a good record if so. I changed my belt at about 14K and the rollers were fine but I had already ordered DR Pulley sliders (28 g) so I put them in. Most people on here think sliders are better than sliced bread, I would disagree. If you want to change the weight (hence performance) then yes sliders are the way to go. DR sliders generally go for $50 plus, Honda rollers are in the $20. range and obviously last a long time. So if you are happy with stock performance like I was then Honda rollers are the way to go. There are plenty of other posts on here about rollers-sliders, just use the search function. Good luck. (putting on my flame resistant underwear)
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeWed Jan 09, 2019 9:46 am
Yeah, what Glenn said.
Even though I am a big fan of Dr Pulley sliders, there is nothing "wrong" with OEM stuff.
Re shop-time costs; why not pick up the phone, call your local shop & ask? As Mr Grinsel says, it only takes an hour, or less, to replace a belt and/or rollers. Other jobs are going to be more time consuming because everything is hidden behind the tupperware. Most shops charge whatever labor rate "the book" says. Unless they run into a problem, then the price (time) adds up
mrseanharford1
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeWed Jan 09, 2019 12:04 pm
Thanks fellas, plenty of great info here.
Number of posts : 1606
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeFri Dec 24, 2021 1:14 pm
I am replacing my 26 Dr Pulley Sliders for 28g OEM Rollers.
Rollers weight  Roller10
I replaced the rollers when I bought my SW, that's one of them on the left looking pretty tired. The new one is on the right. I assumed that the old ones were OEM from new. they certainly look the same. The old ones weigh 29g and the new ones 28g.
I just wanted to share my curiosity....we have three cats! cat
Number of posts : 580
PostSubject: Re: Rollers weight    Rollers weight  I_icon_minitimeSat Dec 25, 2021 11:51 am
From what I read on different scooter sites, etc, the OEM installed roller weights can vary from 28-30g depending on year model/markets/geography, heavier rollers are best for heavy traffic and slow speeds, vice versa, etc
Rollers weight
» Weight of original rollers
» Hello from new to silverwing600 ownership in London
» Do i need the rollers
» 21g rollers
» where to buy 22G rollers?
