| Wiring Fault finally found | |
+3Dale N. Cosmic_Jumper Old Limey 7 posters |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6296 Registration date : 2010-06-09
| Subject: Wiring Fault finally found Tue Apr 09, 2019 1:27 pm | |
| Some months ago I posted about a problem with my 15 amp fuse ( covering ign/fuel pump) keep blowing. I thought it had something to do with the tilt sensor. I have not bothered getting it sorted as I had another scooter to use. Today I got an auto electrician in to investigate. He traced the fault to a short in the wiring loom. He had to cut into the loom to trace the wire. It was shorting out because it was rubbing against the water pump housing, he said it looked like someone at Honda had forgotten to use a cable tie to keep the wiring away from the pump housing. This information may be of use to other members should anyone else ever have the same problem. See original post: https://www.silverwing600.com/t10858-angle-sensor#111109 |
| Subject: Re: Wiring Fault finally found Tue Apr 09, 2019 1:33 pm | |
| Woo hoo! Glad to hear that you finally got it sorted. Thanks for letting us know where the problem was.
| Subject: Re: Wiring Fault finally found Tue Apr 09, 2019 2:10 pm | |
| Glad you got it sorted out. I HATE electrical problems. Probably because I don't know a thing about them and they are so hard to find. But looking at the bright spot you now have two scoots to ride. Now comes, "Do I want to ride this one or that one?" Decisions Decisions... |
| Subject: Re: Wiring Fault finally found Tue Apr 09, 2019 8:46 pm | |
| Glad you found it and more so that you posted the answer. Things like this can be preventative too, now we can look and make sure others are not touching in that area. |
Michel Vachon Maxi-Scooter Rider
Number of posts : 142 Age : 67 Location : Granby, Québec, Canada Points : 2219 Registration date : 2019-03-26
| Subject: Re: Wiring Fault finally found Wed Apr 10, 2019 10:51 am | |
| Thank for giving us the info. I surely will take a close look at it.
Michel
Number of posts : 179 Location : Lanark, UK Points : 3947 Registration date : 2014-09-27
| Subject: Re: Wiring Fault finally found Wed Apr 10, 2019 1:52 pm | |
| After spending three weeks stripping all the body work to find my wiring fault I can appreciate your problem, like me at least you found it, ive been enjoying three days of dry commute since hte rebuild and looking for lots more, 2 weeks ago it was close to spares or repair for sale. |
| Subject: Re: Wiring Fault finally found Wed Apr 10, 2019 2:16 pm | |
| You are right about that phil. I went through at least twenty fuses looking for the fault. I got so fed up I called the wing all the names under the sun, fortunately I had bought another bike in May last year so, I have been using that. I am used to the Cruisym 300 now and prefer the less weight with hardly any loss of power as I cruise at 50/60 mph, and it returns 90mpg. The Silverwings days are numbered I think, I bought it new in 2014 and now at 40,300mls it might be time to say goodbye. |
Number of posts : 1607 Age : 63 Location : South East England Points : 4757 Registration date : 2016-10-01
| Subject: Re: Wiring Fault finally found Thu Apr 11, 2019 1:04 pm | |
| Thanks for an extremely piece of useful information. That's what's great about this forum, unravelling the mysteries of this wonderful machine! |
| Subject: Correction on fault found Fri Apr 12, 2019 11:36 am | |
| When I posted originally about the fault find, I was going off what the auto electrician said. On checking in the Workshop manual I find the cable was actually rubbing on the thermostat housing Not the water pump housing. Sorry for giving wrong info. |
| Subject: Re: Wiring Fault finally found Fri Apr 12, 2019 11:51 am | |
| thanks. |
