Maintenance on my air filter I_icon_minitimeby JohnyC Today at 5:39 am
Maintenance on my air filter I_icon_minitimeby JohnyC Yesterday at 10:04 am
Maintenance on my air filter I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Maintenance on my air filter I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Maintenance on my air filter I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Maintenance on my air filter I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Maintenance on my air filter I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Maintenance on my air filter I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Maintenance on my air filter I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Maintenance on my air filter I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
Number of posts : 2598
Maintenance on my air filter Empty
PostSubject: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeWed Jan 07, 2009 12:53 am
Hi,
Even though I have the K&N air filter I forgot to buy the cleaner for it, so I had to put an OEM filter on. It only took me about 20mins and is really easy. I have a pictorial here too if you have never done this. The K&N was dirty which is why I put in the clean OEM I have. I am going to order some cleaner for it tonight.
Has anyone ever installed a K&N air filter and also had to clean it? And did you order the filter cleaner they usually sell that goes with it? I was just wondering the best why to clean them since I haven't done it yet. Thanks.
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeWed Jan 07, 2009 8:31 am
Jeff,
i have a K&N air cleaner on my other bike and truck. You can buy a kit
at Wall Mart, it comes with the spray cleaner and spray oil. But on their site they used to say you can clean it with a mild dish washing soap. Pump the soap onto the outside of the filter and let it sit for half hour. Then run warm water through it from the inside out. Do this 2 or 3 times until the water runs clean then let it air dry, do NOT blow air through it. After it is dry use the K&N reddish spray oil to recover the outside.
Paul
DaveR
Number of posts : 440
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeSat Mar 21, 2009 11:24 pm
How do you get to the Air Filter? I'm thinking about switching to a K N but am now wondering if it's worth it....I someone can post some pictures on where and how to get to it I would appreciate it...Just "Old Dave"
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeSun Mar 22, 2009 1:11 am
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeSun Mar 22, 2009 1:25 am
I cleaned my K&N air filter with the K&N spray kit.
The instructions say not to use high pressure water, so I cleaned the air filter (opposite flow direction) with water from a hose.
Then I used the K&N spray and let it drip (opposite flow direction), I could not believe how much grime came off the filter - even after using a lot of water. I let the filter drip for awhile.
Then I cleaned the filter again with the water from a hose. I let it dry overnight laying next to a low spead fan overnight to ensure it was dry.
I then used the K&N red oil which made it very easy to spot dry or uneven oiling. I let the oil drip onto a paper towel overnight (opposite flow direction) and then reinstalled the air filter.
The filter looked brand new Smile
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeSun Mar 22, 2009 1:35 am
Somehow duplicated post.
DaveR
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeMon Mar 23, 2009 12:04 pm
Jeff R
I could not get the link up on the Air Filter and how to change it etc. Guess I am a computer illiterate....Is there an access door or do you have to remove the tupper panel?
Thank's for the help...
Dave
PostSubject: Re: Maintenance on my air filter   Maintenance on my air filter I_icon_minitimeMon Mar 23, 2009 4:03 pm
DaveR,
I emailed you 2 versions of the file, 1 in Word, and 1 in a .pdf file. It is about 3.5 mbs so if that is too big you can also go to www.scootertrap.com and go to the Silver Wing 600 section. Matt has placed quite a few of my Pictorials on his site too. Thanks.
» Is it me or the K&n filter does not fit right
» Air Filter
» Air Filter Again
» Air Filter
» Air filter mod
