| Fuel Guage | |
GoonerKev Silver Wing Rider
![GoonerKev](https://2img.net/u/3413/63/00/33/avatars/5164-56.jpg)
Number of posts : 409 Age : 70 Location : Reigate, Surrey, UK Points : 2440 Registration date : 2019-04-09
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Fuel Guage Tue May 05, 2020 1:09 am | |
| Received my can of Seafoam late yesterday evening, so hopefully that may do the trick of sorting out dodgy fuel gauge not working right, recommended by you guys over the water, bloody expensive £15, so hopefully it will do the trick. Does not say how much to put into tank!! Kev ![Fuel Guage Img_2082](https://i.servimg.com/u/f36/20/05/71/55/img_2082.jpg) |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 2:00 am | |
| I've read numerous posts on here over the years about recommending and using Sea Foam cleaner. I'd say Kev is the first Brit who's bought a can of this engine cure all to try. Good luck with it. |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 2:55 am | |
![Dale N.](https://2img.net/u/3413/63/00/33/avatars/3360-93.jpg)
Number of posts : 1995 Age : 78 Location : Princeton, MN Points : 5996 Registration date : 2014-02-13
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 5:48 am | |
| For what it's worth. I've been using Seafoam for years on various vehicles including all of my motorcycles and small engines with good results. My 5 gallon gas can for my snowblower and lawn mowers sometimes lasts 2-3 years before I have to refill it. I've never had a problem with any of them starting. I'd dump 1/2 of the can in on your first and second fill GoonerKev. |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 6:13 am | |
| Many thanks Dale, appreciate your advice. I will let you know the outcomeThumbs Up Kev |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 9:25 am | |
| GoonerKev, you’re going to need more than one can of SeaFoam to rid your tank of all the varnish, etc. But at the cost you paid to import that stuff you can probably find something similar on your side of the pond for less.
You could Google SeaFoam’s Material Safety Data Sheet (MSDS) to find out the active ingredients then search for a similar product locally available.
Or you could brew up your own knock off. Here’s a link: https://www.instructables.com/id/Homemade-Seafoam-Knockoff/ There is actually lots of info about DIY SeaFoam, Techron and similar products on line.
While SeaFoam is a great product don’t expect a miraculous overnight cure. As others have advised: Be patient. You really don’t want to pull the tank unless it’s absolutely necessary. BTDT
Last edited by Cosmic_Jumper on Tue May 05, 2020 10:23 am; edited 1 time in total |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Tue May 05, 2020 9:39 am | |
| Hi Tim Thanks for the info, I will take a look. Yes I couldn't believe what they charged. |
![Siataukreg](https://2img.net/u/3413/63/00/33/avatars/3657-55.jpg)
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3957 Registration date : 2014-08-24
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 1:06 pm | |
| if you need a fuel sender unit i have just one left |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6055 Registration date : 2011-11-29
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 4:02 pm | |
| my gas gage indicator goes from full to empty when when a have a fuel tank full then back to full 40 miles later then back down sill seafoam correct my problem or is there something stronger i can use instead that wou't affect the motor 129 k kl on my scoot |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 4:22 pm | |
| According to the Wisdom of the List: One full can in each of the next two tanksfull, then 1/2 can in each of the next two tanksfull. Probably best to run each tank down to well below flashing (say 20 miles after it begins flashing) before you add SeaFoam to the new tank.
If you are going to have the scoot sit for an extended period of time please be sure to fill the tank and add at least 1/2 can of SeaFoam.
Last edited by Cosmic_Jumper on Wed May 06, 2020 8:43 pm; edited 1 time in total |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 5:10 pm | |
| thank you i have not been able to connect on this forum i had lost my pass word and could not participate a i had 2 reverse shoulder replacement and did not ride the pass 2 years i will try your recommendation on seafoam and post the results of my finding have a nice day |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 6:50 pm | |
| Good to see you back, Tinny |
![Fuel Guage Empty](https://2img.net/i/empty.gif) | Subject: Re: Fuel Guage Wed May 06, 2020 7:09 pm | |
| Siataukreg Thank you for your off, I have a spare one as it was given to me when I got the Silverwing, not sure if it works. I will see if this seafoam does the trick, if not I will look at the spare sender unit, if that i faulty I will PM you if ok. Thank you |
| Fuel Guage | |
