Latest topics | » Drive belt prices by landisr Today at 11:03 am
» It's that time of year again. by MikeO Thu Nov 14, 2024 6:23 pm
» 85 and new bike second on experience by POCAHONTAS Thu Nov 14, 2024 6:05 pm
» fsc600 vs fjs600 rear shocks by terryweasely Wed Nov 13, 2024 10:48 pm
» Looking for info/Potentially selling 2004 Silverwing. by AldusFran Mon Nov 11, 2024 9:21 am
» 2003 ABS Silverwing re fresh by xwelder Sat Nov 09, 2024 3:46 pm
» Rarity for Honda, catastrophic engine failure at 35k miles by landisr Sat Nov 09, 2024 12:46 pm
» Welcome to New Admin by Dale N. Thu Nov 07, 2024 10:07 pm
» New owner…finally by Erdoc48 Thu Nov 07, 2024 8:24 am
» complete engine and transmission for sale in uk by Siataukreg Thu Nov 07, 2024 3:45 am
| Turn signal switch: Stiff in operation | |
VictorLouis Scooter Rider
Number of posts : 72 Location : Phoenix, Aridzona Points : 1771 Registration date : 2020-04-26
| Subject: Turn signal switch: Stiff in operation Tue May 05, 2020 5:49 am | |
| By that I mean it takes far more effort to push left or right than my other bikes. Ditto the push-to-cancel. More like a SHOVE-to-cancel, LOL. I only really discovered it due to a recent splinter in my left thumb causing it to be sensitive. Do you think I would be ok with a shot of evaporative lube applied there, like Ballistol? Don't worry, NO WD-40. |
Number of posts : 1999 Age : 78 Location : Princeton, MN Points : 6069 Registration date : 2014-02-13
| Subject: Re: Turn signal switch: Stiff in operation Tue May 05, 2020 5:53 am | |
| I was also having trouble with mine when I first got my SWing a few years back. I used WD-40 with no problem. I just used a small squirt instead of drowning it. I worked it back and forth a few times and it's worked great since.
P.S. I also used the "straw" so I could get it inside and not all over everything else. |
| | | Loosemarbles Site Admin
Number of posts : 1606 Age : 63 Location : South East England Points : 4750 Registration date : 2016-10-01
| Subject: Re: Turn signal switch: Stiff in operation Tue May 05, 2020 5:55 am | |
| I had exactly the same problem occur a few months ago. It felt like it was going to break if I pushed it any harder.
I put in some WD-40 and after some gentle excercising it works smooth as silk.
Something worth considering doing when servicing time comes around. |
| Subject: Re: Turn signal switch: Stiff in operation Tue May 05, 2020 9:31 am | |
| WELL THEN, if WD-40 has been done twice, LOL....than I will certainly try the Ballistol first. Glad to see that I am not imagining this. |
| | | The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4625 Registration date : 2014-11-20
| Subject: Re: Turn signal switch: Stiff in operation Wed May 06, 2020 6:21 am | |
| It happens because the grease applied to the contacts & pivots at manufacture drys out, wd40 (other lubricants are available ) is softening the hardened grease |
| | | exavid Silver Wing Guru
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8392 Registration date : 2009-07-17
| Subject: Re: Turn signal switch: Stiff in operation Wed May 06, 2020 8:56 pm | |
| It's a pain to use the turn signals on my scooter, I've tried WD40 and an electrical switch lube but may have to get into the thing yet. But I can't gripe, that's the only problem I've had the scooter so far in the 12,000 miles I've put on it in the year I've had it. I thought I'd have to change the belt but after riding the scooter like I stole it has eliminated the squawks and it's running like new now. Anyone knows you should open the throttle all the way on take offs, my flight instructor demanded it. |
| Subject: Re: Turn signal switch: Stiff in operation Thu May 07, 2020 9:18 am | |
| Yes, the Ballistol worked great for the task. My next try would've been Eezox. So, I am shocked that WD40 hasn't tackled it for your bike. |
