Turn signal in mirrors I_icon_minitimeby JohnyC Today at 5:39 am
Turn signal in mirrors I_icon_minitimeby JohnyC Yesterday at 10:04 am
Turn signal in mirrors I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Turn signal in mirrors I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Turn signal in mirrors I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Turn signal in mirrors I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Turn signal in mirrors I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Turn signal in mirrors I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Turn signal in mirrors I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Turn signal in mirrors I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
DaveR
Number of posts : 440
Turn signal in mirrors Empty
PostSubject: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeWed Mar 21, 2012 7:07 pm
I received my mirrors with the turn signals in them today. I think they will work fine. Has anyone installed these on their Silverwing? I just need a suggestion on where the best place to hook into the wireing. Is there an easy way to get to the turn signal on the bike so I don't have to disturb any original wireing or harness? They are simple LED's so should not take much power. Any suggestions?
Smile Old Dave
Number of posts : 2778
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeWed Mar 21, 2012 7:13 pm
Hi Dave,
I can make you a turn signal headlight plug....For heavens sake...That's what I do!!!
Give me a PM if you are interested. sunny
stew1300
stew1300
Number of posts : 15
Registration date : 2012-03-03
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeWed Mar 21, 2012 9:59 pm
Just installed my lighted turn signals. They use the dual voltage supplied to the regular signals, I.E.they are on low all the time then get bright when left or right are selected . I connected to the wiring harness under the left side handle bar cover.
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeWed Mar 21, 2012 10:01 pm
You can tap into the wire harness off the left side handlebar switches. Look for the Light Blue (not blue w/ white stripe) and Orange wires. Orange = left turn signal; Light Blue = right.
DaveR
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 3:31 pm
When you say left side are you talking about by the switch?
DaveR
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 3:54 pm
I assume you have to go through the shrouded wiring harness to get to those wires. Is that correct. If so it means I have to carefully cut into the shroud and find the orange and light blue wires. Is that correct? Then splice into the wires.
Old Dave
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 4:42 pm
Old Dave
Or Posi-tap ( http://www.posi-lock.com/posiplug.html ) the wires.
DaveR
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 4:53 pm
These mirror wires have two wires where do you ground to? As you can tell I am not an electrician.
Dave
DaveR
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 7:44 pm
Cannot find the Posi-taps here in this area. They look like they would be the deal though. I still need to know where to connect the ground wire and in that loop what color is it . Black?
Also in that harness there are 2 orange wires. One looks like it has a stripe on it.
Thanks alot!
Old Dave
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 8:26 pm
Hi Dave,
Just run your new lights "ground wires" to the and then under the bolt heads of the Honda handelbar cover bracket. That's a good grounding point.
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 11:00 pm
Yes, you've got to carefully cut into the wire harness sheathing to expose the wires.
And yes too, that would be solid Orange (no stripe) and Light Blue (no stripe)
Dunno if there is a ground wire in that harness but, traditionally, Green would be a ground wire. But, as Dennis stated, you can use the handlebar bracket bolts as a ground.
If you can locate them (try your local NAPA parts house), Posi-Taps are definitely the way to go. Use the Blue Posi-Taps as they are the best size for the ~20 ga wires in the harness.
When in doubt check the Wiring Diagram in the Service Manual.
DaveR
PostSubject: Re: Turn signal in mirrors   Turn signal in mirrors I_icon_minitimeThu Mar 22, 2012 11:14 pm
Thank you very much. I tried NAPA parts but they did not have the "Posi-Taps" and yes I agree that is the way to go. I do not like to tap the factory wires it I can keep from it.
Old Dave
» Turn Signal Wiring
» Led turn signals on mirrors
» Mirror turn signal mod
» left signal turn
» Headlight Connector
