Turn Signal Wiring I_icon_minitimeby Meldrew Today at 8:01 am
» Rear wheel valve stem
Turn Signal Wiring I_icon_minitimeby GHM-PM Today at 6:43 am
Turn Signal Wiring I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Turn Signal Wiring I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Turn Signal Wiring I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Turn Signal Wiring I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Turn Signal Wiring I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Turn Signal Wiring I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Turn Signal Wiring I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Turn Signal Wiring I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Turn Signal Wiring
3 posters
hbcrosby
Number of posts : 2
Registration date : 2013-11-22
Turn Signal Wiring Empty
PostSubject: Turn Signal Wiring   Turn Signal Wiring I_icon_minitimeTue Jul 07, 2020 4:34 pm
I'm looking to add a "turn signal alert" (re: beeper) to my 2008 SW.  I'm having trouble finding the wiring colors and am hoping someone may be able to assist.  Here's what I've been told:
• Ground = green/black band
• Right Signal = light blue/black band
• Left Signal = orange/black band
I've also found within this forum:
• Ground = blue/black band
• Right Signal = light blue/white stripe
• Left Signal = orange/white stripe
A unverified 600 wiring schematic:
• Ground = green
Checking the wires going to the signal switch under the handlebar tupperware, my scoot has the following (among others):
blue/black band, green/black band, light blue/black band, light blue/white stripe, orange/black band, orange/white stripe
Thoughts? Advice?
Number of posts : 403
PostSubject: Re: Turn Signal Wiring   Turn Signal Wiring I_icon_minitimeTue Jul 07, 2020 5:18 pm
You need to be picking up a signal between the flasher unit and the switchblock; the 02-07 manual shows a Grey wire from the flasher unit to the switchblock, there it splits into the L and R circuits (orange and blue). The flasher unit is integral to the instrument panel so you best bet is to tap at either the multipin plug at the instruments or the 8-pin plug leading to the left switchblock.
hbcrosby
Number of posts : 2
PostSubject: Re: Turn Signal Wiring   Turn Signal Wiring I_icon_minitimeTue Jul 07, 2020 7:52 pm
I understand. I was planning on splicing in after the switchblock using a kit made for Burgmans and Silverwings. You mentioned an orange and blue wires. Does you manual state if they have a white stripe? And what color is the ground?
PostSubject: Re: Turn Signal Wiring   Turn Signal Wiring I_icon_minitimeTue Jul 07, 2020 8:16 pm
The diagram in the service manual shows lightblue/white (R) and orange/white (L) to the front lights, and the same minus the white stripe going to the rear lights. Earth for these lights are green. There appears to be no earth wire as part of the left switchblock wiring, but you can connect to any other earth wire or the chassis if you need an earth for your beeper. There is certainly both the Gray (12V from the flasher unit) and Green (earth) wire at the back of the instrument panel that might be convenient and easy enough to access with the garnish and screen removed.
I downloaded my service manual from the Silverwing owner's page on Facebook.
PostSubject: Re: Turn Signal Wiring   Turn Signal Wiring I_icon_minitimeTue Jul 07, 2020 11:40 pm
Turn Signal Wiring 6083c810
Turn Signal Wiring E2c79110
Turn Signal Wiring
» Buzzer to Alert that Lights are ON and Engine is OFF
» Led turn signals on mirrors
» Mirror turn signal mod
» Turn signal in mirrors
» Headlight Connector
