Battery Change I_icon_minitimeby Hop Today at 7:30 am
Battery Change I_icon_minitimeby xwelder Today at 3:57 am
Battery Change I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Battery Change I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Battery Change I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Battery Change I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Battery Change I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Battery Change I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Battery Change I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Battery Change I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Battery Change
4 posters
Mike G
Number of posts : 1
Registration date : 2020-06-29
Battery Change Empty
PostSubject: Battery Change   Battery Change I_icon_minitimeMon Jun 29, 2020 12:34 pm
this is my Brother-in-Law's 2002 Silverwing 600, scooter, we replaced the battery, battery check as good, but nothing is working, checked all fuses,
Wondering if there is a switch or reset needed when battery is disconnected?
Thanks
Number of posts : 933
PostSubject: Re: Battery Change   Battery Change I_icon_minitimeMon Jun 29, 2020 12:42 pm
Hi and welcome to the Silverwing 600 Forum Mike G. From the top of this page ... "We ask that you be polite and also introduce yourself on your 1st post. The members are friendly and helpful so just have fun."
To answer your specific question, there is not a switch or reset needed when swapping out batteries. My first guess might be perhaps your ground to chassis was pulled on too strongly and has become loose or disconnected. I already make the assumption your polarity is correct.
Number of posts : 1013
PostSubject: Re: Battery Change   Battery Change I_icon_minitimeMon Jun 29, 2020 2:36 pm
If you mistakenly crossed the polarity when connecting the cables, you probably blew the main fuse. The fuse is located under the left side plastic cover. You should obtain a Silverwing service manual if you plan to do your own maintenance.
Possible problems:
1- It could be that the side stand is still down.
2-Check the emergency kill switch on right handle.
3- Pull harder on the left brake handle when trying to start bike.
Good luck!
PostSubject: Re: Battery Change   Battery Change I_icon_minitimeMon Jun 29, 2020 3:35 pm
Easyrider wrote:
... snipped ...
Possible problems:
Totally agree with you.  However, since he said "nothing was working", I assume he's totally dead and not even getting any idiot lights when turning the key to "ON" ... let alone trying to crank it over.
Donie
Number of posts : 80
Registration date : 2013-04-07
PostSubject: Re: Battery Change   Battery Change I_icon_minitimeMon Jun 29, 2020 5:23 pm
Hello Mike G,
Welcome to the site.
You don't mention what way things were prior to replacing the battery.
Was everything working well, and the battery simply wouldn't hold a charge, or had the battery been totally flat for some time?
Battery Change
» change battery ?
» New battery - trip meters gone, clock won't change!
» Dead battery ???
» oil change erronious washer change
» Original Battery/ New Battery.
