| Left (back) brake handle Still spongy after MULTIPLE bleeds | |
XDM© Maxi-Scooter Rider
Number of posts : 125 Location : Philly, Pennsylvania Points : 2031 Registration date : 2019-10-20
| Subject: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 6:58 pm | |
| So earlier in the year i had a leaking right brake master cylinder handle so i replaced BOTH cylinders just to make things even. the new right brake is WONDERFUL, super stiff and a light press activates brake light and stops the bike. but this left one even being brand new was always a little issue. when i bleed it, it acts Great for the FIRST day or maybe 2 days. Then it gets spongy and sticky with a BIG deadzone in the handle. (this gap the pump isnt even touching the handle) and because the handle is "in the air" its making the brake light stay on unless i push the handle forward. and also the left cylinder brake fluid gets REALLY dirty like it was exposed air or something. Now the old factory LEFT cylinder wasnt broken but i just replaced both to be safe (the handle was bent) the nest thing ill try is to put the old one back or take out the pump from it and try that. its a new cylinder so i dont know whats the issue, the line, the pump or caliper? i doubt the caliper is bad because when i changed the brake pads last year it was food, and even now despite how spongy the back break is it still stops on a dime. |
Number of posts : 1935 Location : Hocking Hills U.S.A. Points : 5353 Registration date : 2016-01-29
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 8:42 pm | |
| Strange it should get dirty so quickly, maybe a rubber brake line deteriorating? |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 8:53 pm | |
| - oldwingguy wrote:
- Strange it should get dirty so quickly, maybe a rubber brake line deteriorating?
And on top of that ONLY the left gets dirty, the right line that is tight is as clean as the day i put it in a couple months ago. correct me if im wrong but aren't both Lines connected in a way, when you press one brake it slightly presses the other one too no?
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10739 Registration date : 2009-06-12
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 9:33 pm | |
| The left brake activates the rear brake caliper and only one piston (of 3) in the front caliper —thereby linking the front & rear brakes. The right brake activates only the other two front caliper pistons. So the right brake isn’t linked to the rear brake. There is only one piston in the rear caliper. |
Number of posts : 1384 Location : Allentown PA. Points : 4723 Registration date : 2016-01-02
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 9:56 pm | |
| I made the same error once rear caliper has 2 pistons but has nothing to due with OP's problem.
Sound like left brake master is bad maybe seals are torn up or rear caliper is sticking and overheating fluid. Lever is sticking bad master cylinder most likely. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Mon Mar 15, 2021 10:03 pm | |
| ill test that by installing back the old working master cylinder and see how it acts |
steve_h80 Silver Wing Guru
Number of posts : 1036 Location : Teesdale, UK Points : 4224 Registration date : 2016-05-15
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 4:39 am | |
| As the OP wasn't too sure how the brakes are plumbed up I'd guess its just a bleeding issue, they do need to be done in the correct sequence. |
Number of posts : 1606 Age : 63 Location : South East England Points : 4750 Registration date : 2016-10-01
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 3:31 pm | |
| I had long relationship with this problem since I overhauled the rear caliper and the rear master cylinder followed by problems bleeding etc.
After replacing almost every part of the whole braking system, (slight exaggeration), and still having the same, problem it came down to a bad rear master cylinder and the rear caliper pistons getting 'sticky'.
Thinking back on it now, I was never completely happy with the rear caliper because of powder coating overspill near the bores, which I cleaned away. Also, I think I used the cheapest master cylinder kit money could buy; bad move.
Just my two bobs' worth.
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 5:58 pm | |
| Also one thing I forgot to mention. After riding and pumping that brake for like 10 minute it stiffs up nice and tight again like factory. Come back to it tomorrow. It lost all the preaure. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 6:25 pm | |
| Well that's curious. During my dilemma, forum member 'tech 1 twa' suggested pulling the rear brake lever very slowly and if it comes back to the bars without resistance, then the master cylinder is the culprit. This turned out to be the case with after all my work.
If this is not the culprit then I would say it's 'air in the system'....somewhere. I let the shop do my bleeding, I guess I don't have 'the knack', despite several attempts. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 6:29 pm | |
| - Loosemarbles wrote:
- Well that's curious. During my dilemma, forum member 'tech 1 twa' suggested pulling the rear brake lever very slowly and if it comes back to the bars without resistance, then the master cylinder is the culprit. This turned out to be the case with after all my work.
If this is not the culprit then I would say it's 'air in the system'....somewhere. I let the shop do my bleeding, I guess I don't have 'the knack', despite several attempts. Should I bleed BOTH cylinders even though I'm ONLY having issues with the left? Because I have not been draining both. I did the right one ONE time and it was tight and good. I though theirs no need to drain the right one seeing how it was great. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Tue Mar 16, 2021 6:51 pm | |
| Yes, bleed BOTH valves for the rear brake. Bleed the rear brake linked hose on the front caliper first, then the rear caliper. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Wed Mar 17, 2021 6:07 am | |
| XDM, are you bleeding the rear cylinder through the nipple on the front caliper as well as the rear caliper?
In theory, you shouldn't need to bleed the front cylinder at all if that brake is good. It's the operation of the front brake from the rear lever which is in question, i.e. that second nipple on the front caliper. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Thu Mar 18, 2021 12:22 pm | |
| From our forum back when.
A. Front = right hand reservoir = upper front caliper bleeder valve.
B. Rear = LEFT hand reservoir = FRONT LOWER bleed valve THEN rear caliper bleed valve.
I have a folder that I keep with tips and hints from here, print them out and keep them handy. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Thu Mar 18, 2021 2:10 pm | |
| Please forgive me for sounding presumptuous but I suspect that XDM is wondering if the right brake lever could affect the effectiveness on the rear brake lever, affectively speaking! On my non-abs SW the answer would be no. Don't know about ABS systems though.
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Thu Mar 18, 2021 2:17 pm | |
| So far my bike likes to make me look like a fool, for 2 days SO FAR it kept pressure but I'm still going to take action with it very soon because it WILL happen and I want to find out why. |
| Subject: Re: Left (back) brake handle Still spongy after MULTIPLE bleeds Thu Mar 18, 2021 2:22 pm | |
| I know how that feels. |
