Dabutcher Scooter Rider
Number of posts : 30 Location : Twin Cities , Mn. USA Points : 1392 Registration date : 2021-03-21
| Subject: A tail of two Swings. Sat Apr 10, 2021 8:16 pm | |
| Bought a 2003 a month ago. Then yesterday I bought a 2008 with less scratches and lower miles. So I switched windshields and tail trunks. And rear rim and tire and front rim and tire. Because I bought all these items new a week ago.
Everything went according to plan til I got to final thing. Swap front tires and rims. I had my Pitbull lift on one bike and car jack on the other.
I could not get rim to go on other bike? Cussed and bitched and finally prayed. Then it dawned on me the rotor on the 08 is wider. So I had to switch rotors on both rims and problem solved.
Love yours. D |
| Subject: Re: A tail of two Swings. Sat Apr 10, 2021 10:08 pm | |
| Good tip, I know the 88 89 G'Wings rotors were different from 90 91. |
Number of posts : 1384 Location : Allentown PA. Points : 4728 Registration date : 2016-01-02
| Subject: Re: A tail of two Swings. Sat Apr 10, 2021 10:12 pm | |
| Wider or larger? I think width is all the same but ABS bikes might have a larger front rotor. 5 MM on all rotors for front. I think brake pads were just pushed a bit closer and it wouldn't fit . Wedge a screw driver in between brake pads and expand it a little. |
| Subject: Re: A tail of two Swings. Sat Apr 10, 2021 11:28 pm | |
| Larger. Not wider. Neither bike has ABS. As far as I know. I also ride a 2012 Goldwing. Those with ABS have like a gear on one side of front wheel . Thanks. D |
| Subject: Re: A tail of two Swings. Tue Apr 13, 2021 10:14 pm | |
| Thanks for the information!!! This may help someone down the road. |
