Latest topics | » Passenger Back rest by landisr Today at 12:02 am
» OE Quality Drive Belt by landisr Wed Oct 16, 2024 6:11 pm
» Mini-Mate Camper by MikeO Wed Oct 16, 2024 12:17 pm
» New to the forum by Dale N. Mon Oct 14, 2024 3:10 am
» Complete Fairing Bolt Kit For silverwing/ worth buying?? by zrx212 Thu Oct 10, 2024 12:41 pm
» New FPR, new vacuum pipes, still 22mpg by steve_h80 Wed Oct 09, 2024 8:18 am
» Gulf shores, AL by Mauryturnsoutitsmine99 Tue Oct 08, 2024 8:52 pm
» Searching for Honda or After Market Part by sonuvabug Tue Oct 08, 2024 5:22 pm
» A strange howl by zrx212 Tue Oct 08, 2024 3:44 pm
» First impressions of the silver wing by RedRaider Tue Oct 08, 2024 1:04 am
| | Questions after 16K Maintenance | |
BroOKS2K9 Scooter Rider
Number of posts : 25 Location : Oklahoma Points : 1627 Registration date : 2020-06-13
| Subject: Questions after 16K Maintenance Thu Jun 03, 2021 2:26 pm | |
| 1. If ATF had a weight, what would you think it would be? Not know what previous owner used, I wanted to change to recommended 10W. What came out of forks was purple so assuming ATF. With Honda fluid, I feel the road —and the bumps— more. The handlebars push down faster and the front end seems to dive more. A hard squeeze on the front brake produces a more-responsive stopping situation. Not strange or scary, just more responsive.
2. 10W or 15W fork oil? Any preferences?
3. Any negatives experienced after switching to sliders? Faster initial responsiveness? Absolutely!! But the bike seems to have more vibration now (i.e. a lot more buzz through the floorboard). I noticed it a bit more after the fork oil change. A lot more after roller change.
4. Finally, what differences were noticed after changing drive oil? Whatever came out was dark(er) and heavier than the Honda recommended oil.
Overall, the bike feels more responsive. A bit more nimble. That stated, it's "buzzier" than before too. I look forward to your responses. Thanks. |
Number of posts : 562 Age : 65 Location : Ocala, FL Points : 1971 Registration date : 2020-12-27
| Subject: Re: Questions after 16K Maintenance Thu Jun 03, 2021 5:00 pm | |
| IMO and IME the SW is very weak on front forks, going to 15W-20W helps, some add. spacers and/or increase oil quantity, do a search !!
Do a search on sliders, plenty posted on it !!, with lighter sliders rpms will be higher at lower speeds will augment any vibration, maybe throttle bodies need synch ??
Some people use gearbox oil in lieu of engine oil in gearbox, either will work, if engine oil is used, a motorcycle specific rating is best for gears, lot's of threads about it !! |
Number of posts : 1030 Location : Teesdale, UK Points : 4189 Registration date : 2016-05-15
| Subject: Re: Questions after 16K Maintenance Thu Jun 03, 2021 6:41 pm | |
| Switching to lighter weight sliders allowes the engine to rev a little higher at any speed, good for riding dynamics but can lead to a little more vibration if your chosen speed is at an engine vibration speed! Regards oils I would say go with Honda's recommendations and change from there if you feel the need. Something resembling sludge came out of my forks, new oil at the recommended weight has improved things no end. |
Number of posts : 1384 Location : Allentown PA. Points : 4694 Registration date : 2016-01-02
| Subject: Re: Questions after 16K Maintenance Fri Jun 04, 2021 1:56 am | |
| I've don't know of any trans fluid that is purple? Red mostly but newer CVT fluids are yellow. Fork oil can come in many colors whatever manufacture wants it's just a dye in oil. I like Torco Rff 15W fork oil but sharp edged bumps are still stiff more of a fork problem.
Vibration does increase with sliders but only at some engine speeds nature of every engine.
Rear gear oil? Engine oil is what Honda recommends but the are better choices. Manual trans oils offer better protection in my opinion. GL4 oils not GL5 gear oils. Red Line MTL a 10W30 or they have thicker options MT 90 more like a 10W40. good stuff comes out clean not dark colored . $20 buck a quart though.
| Subject: Re: Questions after 16K Maintenance Fri Jun 04, 2021 4:52 am | |
| Thanks to all for the responses. If it wasn't clear from the original post, I switched to 26g sliders (based on what I've read from the forum). Love the responsiveness, dislike the vibration. |
| | | GHM-PM Site Admin
Number of posts : 2615 Age : 72 Location : Bullhead City, AZ Points : 7470 Registration date : 2012-05-17
| Subject: Re: Questions after 16K Maintenance Fri Jun 04, 2021 12:58 pm | |
| I just had the fork seals replaced and the shop used 10W oil. It was way too soft so I had them switch it to 15W...much better. I have used motor oil AND gear oil in my final drive, both seem to work fine. I change the final drive oil every other oil change and use same oil as crankcase, very easy job.
I have DR Pulley sliders in mine but may switch to Honda rollers next time, I don't see enough difference to justify the expense of the sliders. Just my 2 cents.
But egad I also use K&N air filter and NGK iridium plugs too! LOL |
| | | thecruiser Scooter Rider
Number of posts : 61 Location : GR, MI Points : 1391 Registration date : 2021-03-16
| Subject: Re: Questions after 16K Maintenance Sun Jun 06, 2021 12:27 am | |
| - BroOKS2K9 wrote:
- Thanks to all for the responses. If it wasn't clear from the original post, I switched to 26g sliders (based on what I've read from the forum). Love the responsiveness, dislike the vibration.
Where did you get your sliders? Everywhere I've looked, they are out-of-stock. |
