The 2006 Silver Wing Fairing... I_icon_minitimeby MikeO Yesterday at 6:23 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
The 2006 Silver Wing Fairing... I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
The 2006 Silver Wing Fairing... I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
The 2006 Silver Wing Fairing... I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
The 2006 Silver Wing Fairing... I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
Starkman
Starkman
Starkman
Number of posts : 42
Registration date : 2020-02-22
The 2006 Silver Wing Fairing... Empty
PostSubject: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeTue Jun 08, 2021 1:30 pm
Hey all,
Does anyone know what the fairing is made of? I need to have it cut down so I can see over it, but I understand that depending on what it's made of will determine if this can be done and how well it can be accomplished.
Thanks much.
Number of posts : 1935
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeTue Jun 08, 2021 2:08 pm
Starkman wrote:
Hey all,
Thanks much.
Fairing meaning windshield?  Painters Tape in the area you want to cut. Measure accurately. Use a jig saw with a fine tooth blade meant  for plastic, saw slowly. This worked for me on a G'Wing.  Good luck.
Starkman
Starkman
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeTue Jun 08, 2021 2:45 pm
@oldwingguy,
Yeah, the windshield. I heard that if it's plain plastic it can crack really easy when being cut. If it's acrylic, there seems to be more forgiveness. I'm taking it into a glass shop to be cut, so we'll see.
Thanks.
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeTue Jun 08, 2021 3:29 pm
Please let us know how much it cost to have that glass shop cut down your windshield.
We all benefit from shared information.
Starkman
Starkman
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeTue Jun 08, 2021 3:47 pm
@cosmic,
Will do!
Michel Vachon
Number of posts : 142
Registration date : 2019-03-26
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 6:39 am
Hi,
I personnaly often cut windshield. I use masking tape to mark the cutting line and use a little air angle grinder with a cutting disc. After  to get a rounded finish cut, I use a polishing electric angle machine (like a huge electric angle grinder but with variable speed) with a sanding disk to buff it like rounded shape. You surely could also make that sending with the little air angle grinder with a sanding disk on it to. When starting to make the round shape use rought grit to go faster and go smoother until you are happy. I usualy finish it with a rubbing compound using an electric angle grinder because of the speed needed to polish with rubbing compound ...
It take about an hour to do it... Be carefull when cutting with the disk because it trow some liquid melted plastic on you . So always wear safety glasses and long sleeve.
Good luck and if you fell like having it cut for free  come up to my home I will do it for you. You surely will deserve the job if you do the trip....
Michel
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 7:16 am
I never tried the angle grinder with a disk, maybe a Dremel tool would do the job? Edges were always hand smoothed, but again it's what one is comfortable with. I had an old G'Wing windscreen to practice on at the time.
Michel Vachon
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 9:13 am
Not sure if a dremel would be powerfull anought into plastic when getting hot , sticky and melting....
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 10:06 am
That’s why using a saber saw (jig saw) with a fine tooth blade and advancing slowly has always been the go-to procedure for those who’ve done it.
Ya can’t argue with success.
dickie
dickie
Number of posts : 240
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 11:33 am
Been a while since I have posted so I need to get back into the groove. Like Michel Vachon I have cut down several windshields. And like Starkman, I want to see over the top rather than thru the shield.
I mask off the shield and using a cardboard templet a magic marker is used to outline where I want to cut. I use a dremel tool with a 1/8" bit and follow this line with drilled holes very close together. Then use the same drill bit as a mill cutter and slice my way from hole to hole. You will get some minor melting as Michel noted. Remove the tape and with a rasp and fine file smooths things up. Not a fast way of cutting it down but the results are very good.
Dickie
Starkman
Starkman
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 12:22 pm
Well, I can't cut this myself, so I'll be taking it to a glass shop. I do, however, need to know if there's any hiccups when trying to take off the windshield--the shop can't cut it if it's not removed from the scooter.
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 2:15 pm
Use the Search function for the "Remove front fairing. How to video". He eventually gets to the "tricky" part of removing the windshield garnish. After that it's pretty straight forward.
Starkman
Starkman
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeWed Jun 09, 2021 2:32 pm
Well, assuming this was the correct video (https://www.silverwing600.com/t11146-how-to-fairing-removal-video-in-depth-steps?highlight=fairing), I wasn't sure what to make of it. I mean, all I had to do was take out the two screws near the dash, the two screws in the front holding the winged plate on, and the six screws holding the winshield in place. That was it. I did have to use the manual, which, for me, is usually a disaster...not a visual person at all! But I got the windshield off and down to the shop. They should have it finished later today. Yea! (Now, to get it back on. We shall see. We shall see!)
Oh, and for those of you who wanted to know, the price I was quoted was $35.00.
1Wingman1
Number of posts : 126
Registration date : 2013-01-19
PostSubject: Re: The 2006 Silver Wing Fairing...   The 2006 Silver Wing Fairing... I_icon_minitimeThu Jun 10, 2021 5:07 pm
After cutting with a jigsaw a hand-held belt sander will quickly smooth out the edge. Care is needed because the sander eats plastic away in a hurry. It does not melt the plastic when 80 grit is used.
» 2006 Silver Wing
» Identifying my 2006 Silver Wing?
» Buying 2006 silver wing
» Northeast GA - Silver Wing 2006 for sale - below KBB value!
» 2006 fsc s wing variator,belt ??
