Full or semi synthetic?  I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Full or semi synthetic?  I_icon_minitimeby JohnyC Today at 11:53 am
Full or semi synthetic?  I_icon_minitimeby COMick Yesterday at 6:13 pm
Full or semi synthetic?  I_icon_minitimeby xwelder Yesterday at 12:31 pm
Full or semi synthetic?  I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Full or semi synthetic?  I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Full or semi synthetic?  I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Full or semi synthetic?  I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Full or semi synthetic?  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Full or semi synthetic?  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Notanymore
Number of posts : 36
Registration date : 2021-06-02
Full or semi synthetic?  Empty
PostSubject: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeTue Jun 22, 2021 4:39 am
Hey folks,
Should I run fuchs silkolene pro4 fully synthetic or should I run motorex top speed semi synthetic?
I have both oils in my garage. Would be nice if I could use one of them.
What kind of oil do you run on?
Best regards, Anders
Number of posts : 1935
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeTue Jun 22, 2021 7:09 am
What the book recommends, brand wise Castrol and Valvoline are two I use most. As far as blends go what is the " blend " percentage, nothing on a jug ever gave me that info and as far as I know no industry standard for that. If you want a blend by 2 jugs and mix them at least that way you will know.
Number of posts : 2625
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeTue Jun 22, 2021 7:17 am
Either one will work fine. The main difference with full synthetic is longer change intervals... If you are a rigid (change every 3000 miles) person than use the blend.
Number of posts : 1384
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeTue Jun 22, 2021 8:39 pm
I've been running on Mobile 1 FS 0w40 for the last 2 years. Car oil. No wet clutch on SW. Full SNY. oil more like a 10W30 at at normal riding temperatures. Has a higher Zink level than most car oils not not so expensive like motorcycle oil. $25 for 5 Qts. Silkolene is one of the best oils out there either one is fine.
Notanymore
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeWed Jun 23, 2021 12:01 am
Thank you so much for your replyes, really nice to hear from other SW riders. Its a shame theres only 2 or 3 silverwings in Denmark.
Yesterday evening I went trough all my oil in the garage and I discovered I have a silkolene comp semi 10w40 on the shell as well. Think im gonna use that one
Dabutcher
Number of posts : 30
Registration date : 2021-03-21
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeWed Jun 23, 2021 6:39 am
I run Rotella T-6 in my Goldwing so I used it in my Silverwing at 5K. Good luck. D
PostSubject: Re: Full or semi synthetic?    Full or semi synthetic?  I_icon_minitimeWed Jun 23, 2021 7:28 am
My Goldwing absolutely loved Rotella T-5 which is 10W30 synthetic blend. Engine was quieter, shifted better and fairly cheap as well. I have used the T-6 in many applications also, since it is a "diesel" oil; Rotella is fine for motorcycles. And yes, has a higher zink content than most auto oils.
» 20W-50 Castrol MC semi-synthetic
» Oil change. Ok to use full synthetic oil?
» Regular oil vs synthetic
» Synthetic Engine Oil
» Synthetic oil
