| Regular oil vs synthetic | |
+5Mech 1 twa Cosmic_Jumper Scootypuff Snr Meldrew Lugwrench 9 posters |
Lugwrench Scooter Rider
Number of posts : 37 Age : 78 Location : Columbus, Ohio Points : 2366 Registration date : 2018-08-15
| Subject: Regular oil vs synthetic Tue Aug 28, 2018 2:49 pm | |
| The SW I just purchased is a 2002 with 50K miles. The previous owner used regular 20w50 oil. I would like to switch to synthetic 20w50. I just purchased Ams oil scooter oil 20w50. Should I use this or purchase regular synthetic. |
Number of posts : 4217 Location : York, North Yorkshire, England UK Points : 9438 Registration date : 2010-11-16
| Subject: Re: Regular oil vs synthetic Tue Aug 28, 2018 3:38 pm | |
| - Lugwrench wrote:
- The SW I just purchased is a 2002 with 50K miles. The previous owner used regular 20w50 oil. I would like to switch to synthetic 20w50. I just purchased Ams oil scooter oil 20w50. Should I use this or purchase regular synthetic.
You shouldn't be using 20w 50 at all, just because that dick of a previous owner used it. The Owners Manual states using 10w 30, or 10w 40 oil. |
Number of posts : 230 Location : France & UK Points : 3010 Registration date : 2017-04-21
| Subject: Re: Regular oil vs synthetic Tue Aug 28, 2018 3:54 pm | |
| - Meldrew wrote:
You shouldn't be using 20w 50 at all, just because that dick of a previous owner used it. The Owners Manual states using 10w 30 or 10w 40 oil. don't hold back,speak your mind Meldrew. Lugwrench,oil is a hugely debatable topic with reasoned arguments on all sides. I personally use the recommended oil, bearing in mind the viscosity is the key to suit the climate/usage. However if the original owner used stated to 50K without issues & you're happy to do so carry on.(as they say if it ain't broke don't fix it) |
| Subject: Re: Regular oil vs synthetic Tue Aug 28, 2018 4:17 pm | |
| Oh boy, another oil dust-up I'm with Scootypuff. At 50000 miles the engine has certaily loosened up enough to accommodate a higher viscosity oil. However I wouldn't advise using 20 wt during the frigid winter months. Now switching from regular oil to full synthetic... The jury is out on that. IMHO it's going to be okay making that leap. If not your oil consumption will increase. I'd favor full synthetic 20 w 50 over standard oil anyway. I recall seeing a post somewhere stating that full synthetic viscosity rating are merely a suggestion. Evidently ther's a lot of wiggle room in those ratings. Contradictory statements, I know. But it's my 2¢ opinion Tim |
| Subject: Re: Regular oil vs synthetic Tue Aug 28, 2018 7:14 pm | |
| Thanks for all he comments I really have to apologize I purchased the 10w40. I have a sportster that I was getting ready to sell and had 20w on the brain sorry guys. But with that being said, the oil I purchased was Ams Oil 10w40 blended for scooters. I am not sure that a SW could be classified scooter(I might get hammered for this statement) now should I keep or return for regular synthetic.
I have to also say that since I have had this SW I feel much more comfortable and safe(but still 100% focused when riding). I have ridden on freeway at 70mph which is something I would never do on sportster unless riding with group. It quick and nimble. |
Number of posts : 1384 Location : Allentown PA. Points : 4722 Registration date : 2016-01-02
| Subject: Re: Regular oil vs synthetic Tue Aug 28, 2018 7:58 pm | |
| 10W40 is what you want. SYN oils flow better in colder temps. and stays thicker at higher temps. Nothing wrong with that oil. Sometimes SYN oil starts to clean out old deposits left from other oils and will turn darker after a change. Oil is still good just cleaning up internal engine parts a bit.
SW is a big scooter it can out corner a Sportster because parts don't start to drag. |
Number of posts : 2621 Age : 72 Location : Bullhead City, AZ Points : 7504 Registration date : 2012-05-17
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 8:38 am | |
| I have used various 10w-30 and 10W-40 oils with no problems. Normally I use Rotella T-5 10W-30 semi synthetic. The only oil my SWing did not like was Rotella T 15W-40... I had enough of this left over from another bike to do one oil change and the Silver Wing did not like it, used nearly a quart of oil in one cycle (5K miles). Since reverting back to correct oil viscosity the SWing has not used any oil. |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3593 Registration date : 2015-10-10
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 9:16 am | |
| I use Amsoil and wont look back. |
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 10:24 am | |
| I don't get hung up on oil brands, I'm currently using Castrol in the Silver Wing and I've also used Motul, and Silkolene. Over the years I've happily used Elf, Mobil, Shell, Pro Honda, Agip, Aral, BP, Comma, Texaco, Duckhams, and just about any other brand that's easily available. As long it's in the spec recommended by the Owners Handbook for the two or four wheeled vehicle I need it for, it's fine. |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3175 Registration date : 2017-09-07
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 3:09 pm | |
| Synthetic spec or natural spec oil is fine, as long as it's changed when spec mileage expires. Synthetic will last about twice as long as natural.
Mobil is now advertising a 10,000 mile synthetic for cars.
I vaguely remember a lawnmower company recently advertising a no-oil-change lawn mower. Never have to change the oil for the life of the mower. Just top up when needed. (Maybe because the engine will wear out before the oil life.) |
Number of posts : 1935 Location : Hocking Hills U.S.A. Points : 5352 Registration date : 2016-01-29
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 6:07 pm | |
| - bikehiker wrote:
- Synthetic spec or natural spec oil is fine, as long as it's changed when spec mileage expires.
I vaguely remember a lawnmower company recently advertising a no-oil-change lawn mower. Never have to change the oil for the life of the mower. Just top up when needed. (Maybe because the engine will wear out before the oil life.) One must be careful with oil claims and warranties, after the warranty expires it's yours to change when you please until then no matter what the oil is it must be changed on time, both Honda and Subaru were emphatic about that when I questioned them about this. Honda went by the " oil change light " Subaru by miles driven, Honda's light came on around 8000 miles. Both vehicles used full synthetic 0 w 20 oils. |
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 6:11 pm | |
I vaguely remember a lawnmower company recently advertising a no-oil-change lawn mower. Never have to change the oil for the life of the mower. Just top up when needed. (Maybe because the engine will wear out before the oil life.) That said I have a Craftsman rotary mower that I bought new in 1996! Still starts and runs fine. Change the oil every year or two depending on use. Does not use a drop... So glad I did not go with a Walmart special at the time LOL |
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 7:21 pm | |
| Like my dentist says, "You floss and brush only the teeth you want to keep." You change oil for only the engines you want to keep. |
| Subject: Re: Regular oil vs synthetic Wed Aug 29, 2018 8:51 pm | |
| Just pulling a leg, there's more green in Az. then some people think, When you tell people they grow apples and alfalfa within 80 miles of Phoenix they give you a strange look. |
| Subject: Re: Regular oil vs synthetic Thu Aug 30, 2018 8:31 am | |
| - oldwingguy wrote:
- Just pulling a leg, there's more green in Az. then some people think, When you tell people they grow apples and alfalfa within 80 miles of Phoenix they give you a strange look.
True story, that And cotton too. Water the desert and most anything will grow. It's why Arizona is such an allergy nightmare. All the people from around the country bring their native plants and grasses and grow them in AZ... Go figure. |
| Subject: Re: Regular oil vs synthetic Thu Aug 30, 2018 8:42 am | |
| I remember it from 1960 on our first trip out there, change has been phenomenal, you have to search for the old Az. |
