Variator Drive Shaft...movement? I_icon_minitimeby landisr Today at 11:03 am
Variator Drive Shaft...movement? I_icon_minitimeby MikeO Thu Nov 14, 2024 6:23 pm
Variator Drive Shaft...movement? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Variator Drive Shaft...movement? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Variator Drive Shaft...movement? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Variator Drive Shaft...movement? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Variator Drive Shaft...movement? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Variator Drive Shaft...movement? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Variator Drive Shaft...movement? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Variator Drive Shaft...movement? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Number of posts : 1606
Variator Drive Shaft...movement? Empty
PostSubject: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSat Jul 24, 2021 1:42 pm
Whilst giving the drive train a clean-up today my curiosity got the better of me. I became fixated with the drive shaft:
Variator Drive Shaft...movement? Primar11
I grabbed hold of it firmly and rocked it up and down...there appeared to be some lateral movement which gave a dull 'clunking' noise further back into to the housing. It also had some 'in and out' movement.
Is this normal? Opinions, Suggestions and Advice welcome Suspect
Number of posts : 1935
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSat Jul 24, 2021 3:27 pm
At 8500 miles mine had a little slop in the shaft, I didn't consider it a problem.
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSat Jul 24, 2021 4:24 pm
Whilst giving the drive train a clean-up today my curiosity got the better of me. I became fixated with the drive shaft: (Snip)
My 2¢ opinion is that if the seal isn’t leaking then don’t worry.
That is not to say that if the seal does leak that the big end is knackered. I overfilled my crankcase a couple of times on my, high mileage ‘03 SW, which caused the seal to leak. I replaced the seal (a genuine PITA) and all was well.
Number of posts : 3313
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSat Jul 24, 2021 4:50 pm
Just put it back together and ride it---both of my purchased new SilverWings at the near 50,000 mil mark when I sol them....had no problems or leakage in that area....and I am sure they will go 100,000 miles with no trouble in that area.
Number of posts : 1384
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSat Jul 24, 2021 9:35 pm
What you are calling the drive shaft is the crankshaft of engine. A little side to side is normal, lateral movement would indicate serious internal bearing wear. Plain bearings in cases are all it rides on and I doubt there's a problem. Normal.
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSun Jul 25, 2021 7:15 am
Well there is no sign of leakage in this area. I guess my terminology is a little rusty in my old age. I imagine a little 'end-float' is normal, i.e. 'in and 'out' movement, but it's the 'up and down' and 'side to side' movement that's bothering me. I've included arrows to show which way it's moving. Thoughts of big end bearing failure are nagging me:
Variator Drive Shaft...movement? Primar12
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeSun Jul 25, 2021 8:27 pm
Don't be a Nag.   Smile  It needs a little clearance in bearings to rotate freely once engine starts that slight gap is filled with pressurized oil and all is well.  If it starts to sound like a diesel then you got problems or oil light is coming on at idle.
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeMon Jul 26, 2021 4:06 am
OK I concede, but I had to ask. Oil light goes out instantly the engine fires up and has never come on at idle. Thanks for all the soothing noises.... Sleep
Number of posts : 578
PostSubject: Re: Variator Drive Shaft...movement?   Variator Drive Shaft...movement? I_icon_minitimeMon Jul 26, 2021 6:14 pm
Quoting a famous one liner from the US southeast region "If it ain't broke, don't fix it."
» bearing in the final drive assembley
» Final Drive Shaft Dust Seal and Oil Seal Replacement Advice Needed
» Variator video and drive belt inspection
» Homemade variator tool
» Belt Change - simplified facts...
