Need info on Exhaust I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Need info on Exhaust I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Need info on Exhaust I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Need info on Exhaust I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Need info on Exhaust I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Need info on Exhaust I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Need info on Exhaust I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Need info on Exhaust I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Need info on Exhaust I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Need info on Exhaust I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
jockhmfc
Number of posts : 9
Registration date : 2012-01-14
Need info on Exhaust Empty
PostSubject: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 12:16 pm
Got a 2007 with a delkevic exhaust changing it back to stock 2004 exhaust but its not got the o2 sensor on the exhaust so will it be ok to install the 2004 exhaust on the 2007 without any problems .
Number of posts : 1606
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 12:37 pm
I can't say for sure whether the exhausts are compatible but you might want to check the laws on 02 Sensors. An MOT station might be expecting to find a sensor. The wiring would still be there but no sensor. Just a thought...
I'm sure somebody here will know whether the exhaust will fit OK.
jockhmfc
Number of posts : 9
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 1:28 pm
Its got the same part number for the exhaust for 2004 and the 2007 .
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 1:55 pm
My 2002-2004 parts catalogue has two numbers but there is no sign of a sensor in the diagram.
18310-MCT-010
18310-MCT-950
Try going David Silver Spares website and put the numbers in. The description may say which is which and if it's relevant to your SW?
Number of posts : 403
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 2:25 pm
I think a bigger issue will be the bike's behaviour if the O2 sensor is not reinstated in the exhaust. The ECU is using this to adjust the fuel injection. Not sure about the Swing but it is not uncommon on motorcycles fitted with performance exhausts to eliminate that sensor, and in that case a widget is plugged into the loom in its place to avoid fault codes being generated. The widget normally just contains a suitable resistor to mimic the O2 sensor.
It would not be a big job for a muffler repair business to weld on a socket so you can refit the O2 sensor onto the 04 exhaust.
Number of posts : 4218
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 2:36 pm
2008 onwards Silver Wings are fitted with an O2 sensor in the exhaust, the earlier and less fuel efficient FJS models just a bog standard exhaust.
jockhmfc
Number of posts : 9
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeWed Feb 09, 2022 4:51 pm
Thanks for the info , my son is going to cut the socket of the delkevic and weld it on to the 2004 exhaust .
JamieB
JamieB
Number of posts : 224
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeThu Feb 10, 2022 12:43 pm
I loved the Delkelvic exhaust I had on my Silverwing lovely throaty sound but not intrusive.
stock exhaust on the Forza.🤔
Number of posts : 1384
PostSubject: Re: Need info on Exhaust   Need info on Exhaust I_icon_minitimeThu Feb 10, 2022 8:23 pm
Don't cut old exhaust, just buy a O/2 bung and drill, weld it in a much cleaner install. Something like this and not expensive
 Need info on Exhaust Bung10
Sell Delkevic  and make a few bucks.
Bike will run fine with no O/2 but check engine light will be on forever. Honda PGMFI will still function but I'm sure fuel mileage will be lower.
» Pretty Sunset in the Chiltern Hills, Buckinghamshire UK
» New Member Greetings
» Need more info from an old post
» info needed if its out there
» Bernardo, I need some info please
