First Post, Hello and Help! I_icon_minitimeby MikeO Yesterday at 6:23 pm
First Post, Hello and Help! I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
First Post, Hello and Help! I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
First Post, Hello and Help! I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
First Post, Hello and Help! I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
First Post, Hello and Help! I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
First Post, Hello and Help! I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
First Post, Hello and Help! I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
First Post, Hello and Help! I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
First Post, Hello and Help! I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
sc00ter
AldusFran
MUCHoldERwingguy
artvarck
artvarck
artvarck
Number of posts : 7
Registration date : 2022-03-03
First Post, Hello and Help! Empty
PostSubject: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeThu Mar 03, 2022 6:52 pm
Hiya -
Long time motorcycle rider, and hopefully soon-to-be scooter owner.
I am close to being the owner of a 2012 FSC600 w/ around 5,000 miles. I say "close to" because I am taking a look at it tomorrow, and feel fairly certain I am going to purchase it, however...
I'd like your expert opinion(s) on what I need to look for when inspecting this Silverwing. I know what I'd check out on a motorcycle (chain/sprocket/oil or any fluid leaks/fork seal/engine sound/etc), and am sure many of the same checks apply. But what should I look for that is unique to this scooter? I have zero knowledge of CVTs (except for my CR-V); is there anything to pay attention to there?
Thanks to this forum, I've already asked the question, "does it have the accessory plug in the left-hand storage compartment", to which the answer was Yes.
Thanks in advance, and I look forward to learning from and participating in this community.
-artvarck
MUCHoldERwingguy
Number of posts : 89
Registration date : 2022-01-29
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeThu Mar 03, 2022 8:42 pm
artvarck, hello and welcome from 43135. The bike is 10 years old so tires and rubber parts are a question, does it have any records of the Maintenace done? Fluid changes including brake fluid and antifreeze and a belt inspection would be a good start. Was it stored inside and dry?
Number of posts : 2621
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 6:43 am
With only 5K on the clock it probably needs to be RUN! Make sure it starts and idles well. Fuel injection work can be expensive. Check the rubber as mentioned above, the tires probably look good but most likely need to be replaced anyway. That and fluid changes and you should be good, these are bulletproof machines. Good luck.
AldusFran
Number of posts : 210
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 9:38 am
Welcome, artvarck; if you decide to buy this low mileage Silverwing ,the first thing I would do is get a good repair manual .The one I use is printed by Honda which are excellent and was found on Ebay. I'm on my fourth Swing and really enjoy their simplicity and ease of use. Good luck
sc00ter
Number of posts : 232
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 9:52 am
Sounds like the used Silverwing for sale at my local dealer. Is this a private seller or dealer? Does it come with any history? Price of said Silverwing?
Number of posts : 1606
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 2:34 pm
Welcome ardvarck. For what it's worth, my SW was my first scooter and like any machine it has it's idiosyncrasies.
At 5000 miles I can't see you having many issues. Assuming it hasn't been modified from stock I would suggest; that you look for an even idle speed; 1100rpm ideal but a little above this from cold. Think about the CVT, belt and centrifugal clutch all engaging smoothly for a steady take-off without any scraping or whining noises. Some juddering can be acceptable for the take-up but you'll know if it doesn't feel good.
BTW, check the parking brake. Some SW riders don't use it so it could be a bit sticky but is easily remedied.
There's plenty of help here if you have any issues but the age and mileage suggest that you might have a good'n there thumbs up
artvarck
artvarck
Number of posts : 7
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 7:28 pm
Thanks for the welcomes!
As the now-proud owner of an 2012 FSC600(!), let me try to answer your questions.
All the rubber was in surprisingly good condition, and the SW looked to have been stored under cover most of its life.  It looks like someone dropped it on the right side, an "oops" I have been guilty of in one of two parking lots and driveways in my life.
I've used one of the member's recent posts here to download the service manual .pdf. but will be purchasing a paper copy on eBay as well.
Private seller (Boulder, CO - I need to update my profile location), $3400, was asking $4K.  5500 miles.
Shoot!  I didn't check the parking brake.  Will do so shortly.
Oh, the owner was wrong; no accessory plug, just the rubber-covered blank where one would live.  I've seen good suggestions on this forum to add the plug, which I will likely be attempting.
Sadly, I got it home, and now it won't start (I made sure it was cold when I first inspected it). Lights, dash LEDs, but nothing happens when I hit the Go button. Hoping for an easy fix, but troubleshooting already begins...
[Edit: you have to pull the brake lever back with a little more force than I was expecting - it starts fine]
Oh - it's a lot of fun to ride!  Enough get up and go to [mostly] satisfy my need for speed on two wheels.
Thanks all!
-Art-
Number of posts : 1999
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeFri Mar 04, 2022 10:02 pm
Hi Art, My 08 SWing only has the rubber plug where the outlet is supposed to go. I just put a cigarette lighter socket under the seat and wired it right to the battery with a 10 Amp inline fuse and screwed it down so it wouldn't flop around. It's out of the way for my purposes and it works. I only use it for my MP3 player to keep it charged while riding. You'll notice in the photo the four speakers I have on the topbox. I also have a lighted toggle switch to turn on the Bluetooth receiver and 300 watt amp that are in the topbox. I put a lighted toggle switch on it because one time I forgot to turn it off and when I went to the garage to go for a ride the battery was stone dead. I learned my lesson!! I can hear my 50's and 60's music very nicely while going down the road. I have a Ram mount between the handlebars that holds my MP3 player. It works to my satisfaction.
First Post, Hello and Help! Coborn43
artvarck
artvarck
Number of posts : 7
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeSat Mar 05, 2022 8:51 am
Dale, that is a crazy SW! I am so curious how it became a trike, but I'll look over your previous posts to learn more.
I can't identify that top case? I just ordered the SR19 mounting kit, and have yet to decide on a Monokey case.
Are there any characteristics to distinguish models years between 2002-2013? They look the same to me.
Number of posts : 3837
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeSat Mar 05, 2022 10:42 am
It's a Givi E52 top case, methinks.
They aren't cheap but last for ever.
Add to that: if you need a passenger backrest, the TB19 (I think) fits with the Givi boxes so one can take off the box and still have a backrest.
On the Forum is JeffR's How-To pictorial for fitting the backrest; it also points the way to fitting the Givi rack. All one has to do is drill four holes as marked instead of two.
It's here:
https://www.silverwing600.com/t31-givi-passenger-backrest-installation-pictorial
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeSat Mar 05, 2022 9:36 pm
Hi Art, It's a GIVI top box. Off the top of my head I can't remember the size. The trike kit is a Motor Trike kit. You can go onto their site and check them out. They also will tell you which dealers are in your area.
www.motortrike.com/ It's the GT3 kit.
My trike kit cost me about $8,000 total. That's for them to make it, ship it and have my Honda dealer install it. I also got all my parts back too.
It took a bit of getting used to but now I'm at home with riding it and love it. I rode it around town for an hour or so to get used to not leaning and how fast/slow to do intersections etc. Then I took it out on the highway for a few mile ride to see how it handled. It was great!! I only lost about 5 MPG on the highway but a bit more in town with stop and go. But either way it still gets better mileage than my pickup... LOL
I just went out and looked. It's a V56 Monokey box. I put this box on last summer. The one that came with the SWing when I bought it seemed "mis-used" shall I say. But it lasted me a few years until it started to not lock or close properly. The hinges didn't seem right either so I just said the heck with it and bought this one. It bolted right on to the existing bolt holes too so no problem. I've still got to install the electronics and speakers before summer.
Number of posts : 930
PostSubject: Re: First Post, Hello and Help!   First Post, Hello and Help! I_icon_minitimeSun Mar 06, 2022 12:32 pm
artvarck wrote:
... snipped ... Thanks for the welcomes!  As the now-proud owner of an 2012 FSC600(!), let me try to answer your questions.
[Edit: you have to pull the brake lever back with a little more force than I was expecting - it starts fine] Thanks all!  -Art-
Welcome aboard the board Art.  Regarding the left side lever, you can feel and hear the "click" when engaged for starting. It's subtle but it is there.  You can also observe it engaging if you're off the bike, observe and engage the left hand lever from the front and looking up.  I had to adjust mine after replacing the standard levers.
» My first post here
» My last post
» Just trying to post a pic
» About me ( I guess just for this post it's all about me)
» First post
