Brake lights I_icon_minitimeby xwelder Today at 8:06 am
Brake lights I_icon_minitimeby GHM-PM Today at 7:06 am
Brake lights I_icon_minitimeby sonuvabug Yesterday at 3:17 pm
Brake lights I_icon_minitimeby JohnyC Wed Nov 20, 2024 9:04 am
Brake lights I_icon_minitimeby john grinsel Mon Nov 18, 2024 6:50 am
Brake lights I_icon_minitimeby Meldrew Sat Nov 16, 2024 3:37 pm
Brake lights I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 5:05 pm
Brake lights I_icon_minitimeby terryweasely Wed Nov 13, 2024 9:48 pm
Brake lights I_icon_minitimeby AldusFran Mon Nov 11, 2024 8:21 am
Brake lights I_icon_minitimeby landisr Sat Nov 09, 2024 11:46 am
 Brake lights
MUCHoldERwingguy
The Villager
The Villager
Number of posts : 21
Registration date : 2022-03-05
Brake lights Empty
PostSubject: Brake lights   Brake lights I_icon_minitimeSun Mar 06, 2022 4:20 am
I checked the front and back connections.
Turn signals work fine
Horn fine
Tried both brakes with bike ignition on and the running.
No brake lights.
Any ideas.
The Villager
The Villager
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeSun Mar 06, 2022 6:24 am
Update.
I took the two wires off the brake switch on the right side, turn on the key and touched them together and the brake lights came on. I would say the switch is bad.
The left brake switch has 4 wires. Too complicated to me. Any advice.
MUCHoldERwingguy
Number of posts : 89
Registration date : 2022-01-29
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeSun Mar 06, 2022 7:58 am
You might try buying a good contact cleaner, get one that's plastic friendly then spray the switches while working them. That would be my 1st step in trying.
Number of posts : 1037
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeSun Mar 06, 2022 9:57 am
The 4 wires on the left brake lever are 2 for the brake and 2 for the starter interlock.
As mentioned above it might be worth giving them a good clean and rub with a bit of sandpaper. I had a similar issue last year when the bike didn't want to start, a good clean of the contacts and all is well.
The Villager
The Villager
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeSun Mar 06, 2022 10:58 am
Thank you. That brake has to be pressed to start the bike. Half of that switch is work8ng
The Villager
The Villager
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeMon Mar 07, 2022 12:35 am
Just ordered both switches from partzilza. I will update if that is the issue.
Number of posts : 3314
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeMon Mar 07, 2022 11:49 am
first remember SilverWings are now old bikes---but ridden very little----WD-40 on switches and switch area can fix things up. Sidecar? who hooked up sidecar brake lights?
gustav
Number of posts : 192
Registration date : 2019-04-13
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeMon Mar 07, 2022 5:40 pm
People with Poodles, of course!
Number of posts : 403
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeMon Mar 07, 2022 7:52 pm
The left brake switch is a bit tricky and I recall having to bend one of the actuating tangs to get it functioning reliably. A new switch is probably not a bad idea. The microswitches on both sides do get some corrosion and dirt and stop switching nicely; WD40 or Deoxit contact cleaner might well do the job with no disassembly.
Number of posts : 2624
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeTue Mar 08, 2022 5:44 am
I just replaced my brake switch on the left side. Starter switch still worked but brake light did not. Very easy replacement and working great now. You live in Florida and if close to the water the corrosion will be bad...
Personally I would avoid WD40 for this purpose. It is a light oil and while it might help a little it will attract dirt. Use an electronic cleaner from an auto parts store, good to have on hand.
Good luck.
The Villager
The Villager
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeTue Mar 08, 2022 6:00 am
Good luck.
Can of electronic cleaner will be here on the 10th.
Both switches will be here on the 15th.
The Villager
The Villager
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeTue Mar 15, 2022 6:47 am
Got the brake light Switch’s and they fixed the issue.
Brake lights Empty
PostSubject: Re: Brake lights   Brake lights I_icon_minitimeTue Mar 15, 2022 7:33 am
Fantastic, I am sure glad these switches are still available...
Brake lights
» Brake lights always on
» Brake lights
» brake/tail lights
» Brake Lights Don't Work...
» brake light not lighting when brakes are applied
