brake light not lighting  when brakes are applied I_icon_minitimeby MikeO Yesterday at 6:23 pm
brake light not lighting  when brakes are applied I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
brake light not lighting  when brakes are applied I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
brake light not lighting  when brakes are applied I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
brake light not lighting  when brakes are applied I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
brake light not lighting  when brakes are applied I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
brake light not lighting  when brakes are applied I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
brake light not lighting  when brakes are applied I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
brake light not lighting  when brakes are applied I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
brake light not lighting  when brakes are applied I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
som2002
micbusathens
jamestanker
jamestanker
Number of posts : 9
Registration date : 2013-10-29
brake light not lighting  when brakes are applied Empty
PostSubject: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 10:22 am
Not sure whats wrong! The brake lights were working perfectly fine now both are just not lighting when the brakes are squeezed.
The tail light works, fuse is not blown, the bulbs look perfect, I have taken them out and reseated them.
Anyone ever have this issue? I guess I need to find out where along the lines the connection is not being made just wondered if anyone else had this issue and was able to rectify it before I take the damn thing apart!
James
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 11:08 am
Odd that both would fail simultaneously. Check the brake light fuse. If that's ok then you'll have to remove the switches at the brake levers. IIRC they are 'normally closed' switches --if that helps. It could be that you've had one switch previously fail and the opposite switch was the one that was giving you brake light operation. Eventually that 2nd switch failed as well and now you've got no brake lights at all. HTH
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 2:47 pm
Bulbs ? Lil strange of couse for both at the same time
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 3:37 pm
The switches get my vote also.
som2002
som2002
Number of posts : 120
Registration date : 2009-06-19
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 4:25 pm
My switches would quit working at times, normally just the right side one though. Easy enough to take apart, clean up, and reassemble.
http://www.fquick.com/som2002
NWSSC
NWSSC
Number of posts : 418
PostSubject: Rear brake lights   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 8:28 pm
Not to be contrary but I think both brake light switches are normally open and when activated you have continuity through the switch.The shop manual (page 21-10) tells you can access the switch connector by removing the handlebar cover. Remove the connector and check for continuity across both terminals of the switch when you activate the switch. If you have. turn the key on and find the hot wire to the switch. Turn off the ignition switch and check the other wire for continuity through the various connectors back to the stop lights. I doubt that you would have both switches defective at the same time.But again you know what the word assume means.The other probability could me moisture.If you can spray WD40 (stands for water dispersant 40 test) into the switch and activate several times to clean up the contacts. The other probability would be if some one has removed various components and not properly assembled a connector. I'm a firm believer in relativity. :lol!:  Howard
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeThu Oct 31, 2013 11:15 pm
I agree that to have both switches go bad at the same time would be odd. But as Tim said "It could be that you've had one switch previously fail and the opposite switch was the one that was giving you brake light operation." and now that one has gone bad too.
Winger61
Winger61
Number of posts : 452
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeFri Nov 01, 2013 5:11 am
NWSSC wrote:
The other probability could me moisture.If you can spray WD40 (stands for water dispersant 40 test) into the switch and activate several times to clean up the contacts.  Howard
That would be my first course of action. The switches on the levers are pretty well exposed to the weather, so it could be as simple as some dirt on the contacts.
Graham
surlybiker58
surlybiker58
Number of posts : 350
Registration date : 2011-12-11
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeFri Nov 01, 2013 6:40 pm
For what it's worth, my brake light switch failed after 18 months and had to be replaced.
My Silverwing is garage kept and though I ride year round, I try to avoid the wet stuff (rain, snow, sleet) if I can help it.
The dealer said they also see them fail on Goldwings .
jamestanker
Number of posts : 9
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeSat Nov 02, 2013 7:12 am
Thanks guys the first thing I'm going to do is try WD 40
AldusFran
Number of posts : 210
PostSubject: Re: brake light not lighting when brakes are applied   brake light not lighting  when brakes are applied I_icon_minitimeTue Jun 30, 2015 8:13 am
I bought my 2009 SW with a faulty right brake light switch. Even after applying lube very intermittent lighting. Ordered a new switch from Classic Cycle Parts in Hilliard,OH for $9.59 shipped and they worked perfect.
» So, how many of you have ridden with the parking brake applied?...
» Brake light help!!!
» brake light
» front brake light
» Givi brake light kit….
