Broken fixings on fairing I_icon_minitimeby MikeO Today at 6:23 pm
Broken fixings on fairing I_icon_minitimeby POCAHONTAS Today at 6:05 pm
Broken fixings on fairing I_icon_minitimeby terryweasely Yesterday at 10:48 pm
Broken fixings on fairing I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Broken fixings on fairing I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Broken fixings on fairing I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Broken fixings on fairing I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Broken fixings on fairing I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Broken fixings on fairing I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Broken fixings on fairing I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
RiverSong77
Number of posts : 10
Registration date : 2021-09-17
Broken fixings on fairing Empty
PostSubject: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun May 08, 2022 7:38 pm
Howdy all ..
2007 Swing 600 in Brisbane, Australia ..
Wondering if anyone else has had a similar issue they’ve had to deal with ..
Returning from a ride recently, I noticed that the fairing was coming away on the front left from the screen to about halfway down ..
It wasn’t flapping in the breeze or anything as dramatic as that, it had just opened up a bit of a gap that I felt needed to be closed again ..
I opened it up in an attempt to find and rectify the cause, only to find that the screw fixtures attached to the inside of the fairing down the left side had all sheered away from the fairing to varying degrees and were essentially irreparable ..
Now, as a plastics fabricator, I’m a great woodworker !
Obviously, something had to be done, so I ended up drilling a small hole in what was left of the plastic bracket on the fairing, and using a reasonably small gauge wire, fabricated a VERY amateurish loop arrangement that I could pull back through the screw holes to tighten the screws up against.
The “fix” has worked in so far as the fairing has pulled back into position and is staying there (for now), but I know it’s not a long-term repair and will become messy whenever the fairing is next removed.
Finding replacement used panels here in Brisbane is not really a happening thing, and I’m sure that trying to order new replacement fairings would be a long drawn out, (and I expect, very costly) process !
Has anyone else had to face this issue, and if so, short of replacing the entire fairing, how did you effect a repair that is more permanent and allows for easy removal and refitting of the fairing later on ?
Would be most appreciative of any helpful advise from this fine family of “Swing’ers” !
Cheers,
Andy
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun May 08, 2022 8:21 pm
Hello Andy. It might help if we could “see” the area you are talking about. As impossible as it probably is at this point, if you could post a photo…
Also, we just corralled a lot of earlier discussions about plastic repair in Maintenance, Tips, and Hints under the subject title “Tupperware Repair”. Do a Search for that. You’ll find quite a few opinions and probably find a few viable answers too.
But do keep up informed how you sort this out.
Number of posts : 403
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun May 08, 2022 8:55 pm
I had some similar issues with my SilverWing, I believe the PO only had a prybar but no screwdrivers, and the panels were glued back on with silicone caulk. I'm not kidding! So I got pretty handy at rebuilding the tabs and screw fixings. I used a Permatex Plastic Welder two part epoxy, which bonds super-well onto the ABS that the panels are made from.
RiverSong77
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun May 08, 2022 11:43 pm
Thanks for that mate, I’ll check that out first and then see where we go from there 👍
RiverSong77
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun May 08, 2022 11:48 pm
Thanks for that .. The original tabs were pretty much perished beyond salvation and crumbled away to basically dust and shrapnel when I removed the screws .. I may have to try to fabricate new tabs and try the Permatex epoxy solution (whilst standing on my ear and holding my mouth just right) .. It’s certainly a fiddly job, particularly when arthritic hands don’t like to play nice when it comes to small things in awkward places !
Appreciate the thought .. I’ll keep formulating plans including all the helpful suggestions ..
The Dude
The Dude
Number of posts : 193
Registration date : 2022-02-20
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeMon May 09, 2022 12:48 am
Hey Brother,
My front fairing is held together with cable ties, wood blocks and super glue. As is many others. It's not as bad as it sounds. It's tight and rattle free.
A new one, in my color, is still available, it's about 400 bucks. I may or may not go that route. I do plan a color change in the not too distant future. Considering rebuilding broken connectors at that point. I also found new blinker lenses at AliExpress, and mine are clouded and greenish. So I may snag some of those.
I am thinking if I pull all the parts, prep them for paint, then take them to my favorite auto paint place it might be less than $500 to shoot them all.
RiverSong77
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeMon May 09, 2022 11:02 am
The Dude wrote:
Hey Brother,
Sounds like a bargain priced fix !
I expect parts are more readily available and in greater numbers in the US than they are over here in Australia .. Nonetheless, I’ll keep working on a solution, I’m not gonna let it beat me ! .. Thanks to you guys on this site, I’ve got some great suggestions and ideas so IT will happen !
Thanks again …
Dutch SilverWing
Dutch SilverWing
Number of posts : 75
Registration date : 2020-07-16
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun Jul 10, 2022 6:03 am
Thanks again …
Hello Riversong77
Maybe a long shot but I may have something to help you with your search.
Okay, then some bridges would have to be crossed.
Or actually a few Oceans.
Overhere in the Netherlands there is a company, CMSNL.com, and they still have OEM parts for our beloved SiWis.
Through a worldwide network and contacts with the factories in Japan, they provide genuine parts. Always take a good look at the year of manufacture and to which part of the world your Silver Wing applies. FJS [Europe], FSC [US] and JDM [Asia]
They ship the goods worldwide and for Australia the free shipping of goods applies from an order amount of € 200. I checked for you.
You might want to check their website, who knows. https://www.cmsnl.com/honda-fjs600_model1208/
Best of luck with your search
RiverSong77
PostSubject: Re: Broken fixings on fairing   Broken fixings on fairing I_icon_minitimeSun Jul 10, 2022 9:19 am
Hi Dutch Silver Wing ..
Many thanks for passing on this information and for the research you’ve done.
Sadly, my SW is no longer MY SW !
An opportunity came up for me to buy my friends’ Triumph Bonneville T100 at a price I just couldn’t refuse, and as I couldn’t keep both, the Honda had to go ..
I originally bought the S/Wing due to nerve damage in my legs and a feet forward automatic was ideal for me at that stage of my recuperation .. Strength has returned to some degree, and as I have always been a Triumph guy, and given the lightness and beautiful riding position of the Bonnie, it was a no brainer for me to return to the Triumph fold !
Having said that, I enjoyed my time on the Silver Wing very much, and have sold it to a lovely chap with similar physical issues to those I had when I bought the Honda.
I will pass this information on to him, I’m sure he’ll be most appreciative !
Thanks again for your thoughtfulness ..
Cheers,
AJ
» broken down on m6
» Are there any serious problems or issues with the Silver Wing ?
» Ever had your scooter broken into?
» Broken the faith..............
» Broken coolant bolt - Help!
