Broken coolant bolt - Help! I_icon_minitimeby MikeO Today at 6:23 pm
Broken coolant bolt - Help! I_icon_minitimeby POCAHONTAS Today at 6:05 pm
Broken coolant bolt - Help! I_icon_minitimeby terryweasely Yesterday at 10:48 pm
Broken coolant bolt - Help! I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Broken coolant bolt - Help! I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Broken coolant bolt - Help! I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Broken coolant bolt - Help! I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Broken coolant bolt - Help! I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Broken coolant bolt - Help! I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Broken coolant bolt - Help! I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
4 posters
Jonathan
Number of posts : 6
Registration date : 2023-03-08
Broken coolant bolt - Help! Empty
PostSubject: Broken coolant bolt - Help!   Broken coolant bolt - Help! I_icon_minitimeWed Mar 22, 2023 2:12 pm
So the coolant bolt snapped from the inside and I was wondering if anyone knows how I can get it out? Any ideas will help a bunch, thanks!Broken coolant bolt - Help! A7808810
Broken coolant bolt - Help! 1b7e3610
Number of posts : 1606
PostSubject: Re: Broken coolant bolt - Help!   Broken coolant bolt - Help! I_icon_minitimeWed Mar 22, 2023 4:34 pm
You might as well remove the thermostat housing. That will give you better access to the broken bit inside. Drilling a hole into it and using an 'easy-out' could work.
cello33
Number of posts : 150
Registration date : 2018-07-09
PostSubject: Re: Broken coolant bolt - Help!   Broken coolant bolt - Help! I_icon_minitimeThu Mar 23, 2023 6:31 pm
I cant make out from the image if the bolt has sheared off but assuming it has you may be lucky..........
I had the same issue on the opposite side of the engine when fixing the grommet oil leak, a bolt sheared off but I managed to rotate what was left with a small flat screwdriver. If it is seized you could try heating up the bolt by using a car battery and touching the bolt with the positive cable , this applies the current directly to the bolt and burns off the oxidization.
DISCLAIMER - This method works and allows you to target the bolt directly unlike using a blowtorch , care must be taken as you wil get some sparks when you make/break the connection. Make sure you have no fuel leaks on the bike or get out in the open where there is plenty of fresh air circulating to avoid any combustion of fuel vapour.
Number of posts : 1384
PostSubject: Re: Broken coolant bolt - Help!   Broken coolant bolt - Help! I_icon_minitimeFri Mar 24, 2023 5:44 pm
Is that the coolant drain bolt?  If so it's in the water pump not the thermostat housing. Water pump has two parts and the outer unbolts without pulling the pump but get a new gasket old one will never reseal.
There might be enough threads sticking out to get a bite on it after splitting it. Broken coolant bolt - Help! Img_2017
PostSubject: Re: Broken coolant bolt - Help!   Broken coolant bolt - Help! I_icon_minitimeSun Mar 26, 2023 9:21 am
Sorry, my mistake. We are talking about the water pump not the thermostat housing!!
As mentioned above, removing the pump outer cover might leave enough broken bolt to get a grip on it. IAC an easy-out might still work after soaking bolt hole with WD40.
» broken down on m6
» broken crank sensor clip
» Broken left compartment latch
» Broken Spark Plug Extraction
» Broken fixings on fairing
