| broken crank sensor clip | |
batiatus Scooter Rider
Number of posts : 28 Location : Bay Area Points : 4104 Registration date : 2013-09-25
| Subject: broken crank sensor clip Tue Oct 15, 2013 12:01 am | |
| I just put in a new engine and noticed that I broke the clip for the crank sensor. I tried to replace it but its hitting the frame. Is there any other option to replace the sensor without lifting the engine? |
| Subject: Re: broken crank sensor clip Tue Oct 15, 2013 5:28 pm | |
| Hmm... I don't believe anyone here has broken a crank sensor --at least not on a SW. Congratulations, you're in first place! |
| Subject: Re: broken crank sensor clip Tue Oct 15, 2013 5:52 pm | |
- Hmm... I don't believe anyone here has broken a crank sensor --at least not on a SW. Congratulations, you're in first place!
I put in a new engine I guess one of the harness broke the clip. The only way for me to replace it to lift the engine about an inch. The sensor still works, just have to tape the plug to prevent from coming off. Just want to replace it as a preventative |
echris108 Scooter Rider
Number of posts : 27 Age : 48 Location : singapore Points : 4098 Registration date : 2013-10-05
| Subject: Re: broken crank sensor clip Wed Oct 23, 2013 9:49 am | |
| is it the sensor at the left side of the engine ,next to the thermo valve? i tried to removed the sensor to change the o ring today but just cannot get it out. wat stupid deign is it? |
SCTLVR Maxi-Scooter Rider
Number of posts : 186 Location : Fairfield, CA Points : 4731 Registration date : 2012-06-27
| Subject: Re: broken crank sensor clip Wed Oct 23, 2013 12:39 pm | |
| Probably the "stupid design" that makes the scoot' easier to assemble at Honda. Honda likely fully assembles and maybe even tests the engine before installing on scoot'. Unfortunate, indeed. |
| Subject: Re: broken crank sensor clip Wed Oct 23, 2013 12:43 pm | |
| - echris108 wrote:
- is it the sensor at the left side of the engine ,next to the thermo valve?
i tried to removed the sensor to change the o ring today but just cannot get it out. wat stupid deign is it? That is correct. My clip broke because the harness of the engine hoist. I fired it up the other day and its working now |
| Subject: Re: broken crank sensor clip Wed Oct 23, 2013 1:12 pm | |
| Subject: Re: broken crank sensor clip Wed Oct 23, 2013 7:28 pm | |
| i got a bad oil leak at that sensor therefore trying to replace the o ring to solve the problem. |
