Sputters won't crank I_icon_minitimeby MikeO Yesterday at 6:23 pm
Sputters won't crank I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Sputters won't crank I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Sputters won't crank I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Sputters won't crank I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Sputters won't crank I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Sputters won't crank I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Sputters won't crank I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Sputters won't crank I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Sputters won't crank I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
rhkxr250r
Number of posts : 4
Registration date : 2022-05-26
Sputters won't crank Empty
PostSubject: Sputters won't crank   Sputters won't crank I_icon_minitimeFri May 27, 2022 8:41 am
Hey folks, first post after looking for similar situations.  I'm from Mississippi and my wife owns a Silverwing.  Has always cranked instantly and ran perfectly, however, yesterday after taking it down the road a few miles to exercise, I got back turned it off and later tried to crank it.  It turns over fine as I keep it on a battery tender.  It does fire and sputters but won't go ahead and crank over and run.  I am totally unfamiliar with this type of engine and fuel injection so I really don't know where to go with this.  I hate to haul it to the Honda shop without at least trying something myself.  Any suggestions?
Number of posts : 3313
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeFri May 27, 2022 3:30 pm
First---how old is battery? I would take battery out, take it to battery plus in US, have it load tested, etc. Not good buy new battery. Batteries over 2 years old on bike not in daily use can be problem period, especially in bike with no kick starter or ability to bump start. Fuel injection has certain voltage requirements to function
rhkxr250r
Number of posts : 4
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeFri May 27, 2022 4:47 pm
That will be next step because it will turn over now but no sputter at all and it does seem slower. Suppose I could put a jump box on it? I do catch the odor of gas. Battery tender does show green fully charged though.
rhkxr250r
Number of posts : 4
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeFri May 27, 2022 6:08 pm
Well, sadly I don't think the battery is the issue.  Made sure, using a jump box and cables there were plenty of volts and amps available.  Motor spins over nicely but doesn't fire at all.  Battery wasn't that old anyway and was always kept on a battery tender so jumping made no difference.  Thought we were onto something.
Number of posts : 1036
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeSat May 28, 2022 2:23 am
Fuel? Plugs? Start with the basics.
Number of posts : 403
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeSat May 28, 2022 5:14 am
Could be flooded. If you wind the throttle fully open and crank it, the FI knows to shut the fuel off while you do that to clear the engine.
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeSat May 28, 2022 10:39 am
If what Terry says, above, doesn’t work you need to check whether you are getting proper fuel delivery. IIRC chapter 5 of the FSM covers the fuel system. Could be that the Fuel Pressure Regulator (FPR) has failed or that the pump has failed of the filter is impacted. Here’s a link to an online FSM:
[url=https://manuals.wotmeworry.org.uk/Honda/Honda 2002-2013 Silverwing 600 Service Manual.pdf]https://manuals.wotmeworry.org.uk/Honda/Honda%202002-2013%20%20Silverwing%20600%20Service%20Manual.pdf[/url]
Do use the Search / Google function here to find many previous discussions about fuel pressure / fuel volume issues.
Please let us know how you sort this out. We all benefit from shared information.
rhkxr250r
Number of posts : 4
PostSubject: Re: Sputters won't crank   Sputters won't crank I_icon_minitimeSat May 28, 2022 12:22 pm
Appreciated. Tried the full throttle thing no success. However, I looked down into the fuel tank and saw major rust, pretty ugly. Probably going to the shop with it as this is fast becoming more than my expertise. I'll keep ya'll posted. Thanks.
» Engine won't crank
» broken crank sensor clip
» Sliver Wing shop manual and crank holding tool.
» Engine wont start
» Clutch removal of 22mm bolt
