| | 2006 SW won't start, just clicks | |
okcseoul Scooter Rider
Number of posts : 10 Age : 63 Location : Seoul, SK Points : 2939 Registration date : 2016-09-09
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: 2006 SW won't start, just clicks Sat Jul 02, 2022 6:23 am | |
| I have ridden this same 2006 SW for fifteen (15) years. I am puzzled because it doesn't start. I just hear one click from under the seat area when I push the electric starter button.
Yes, I pull the rear brake and hear both clicks. I even hear all the sounds that are heard in the process of starting the bike. But when I push the starter button, it just sounds one click from under the seat area.
I'm in Seoul and my daughters are coming next Wednesday from Boston. Maybe I could get them to buy anything that I might need (Solenoid?).
Any advise or suggestions?
Thanks in advance. |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | 1Wingman1 Maxi-Scooter Rider
Number of posts : 126 Age : 82 Location : Jacksonville, Florida Points : 4383 Registration date : 2013-01-19
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Sat Jul 02, 2022 7:35 am | |
| Your symptoms are classic signs of a weak battery that has enough power for small jobs like operating the starter solenoid but does not have enough power for big jobs like turning the starter motor. If battery is fairly new try charging it. If not, replace it. |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | Cosmic_Jumper Site Admin
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Sat Jul 02, 2022 7:39 am | |
| Hello Bill. The under seat “click” you hear is most probably the starter solenoid. So that seems to be working.
Have you checked the battery? Check voltage —if the voltage is below 12.3V it needs charging; check battery terminal connections; check ground connections to the frame —a weak ground connection can be troublesome. There is a ground connection behind the left side rear panel above the ECM.
Not that it’s easily accessible but the starter motor brushes may be binding and not contacting the starter armature. While I’ve never tried it on a Silverwing, I’ve whacked a couple of car starters with the wood handle of a sturdy hammer and that has managed to free up the binding brushes.
Good luck. Please let us know how you sort this out. |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | dovahkiin Scooter Rider
Number of posts : 58 Location : SG Points : 937 Registration date : 2022-05-09
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Sun Jul 03, 2022 12:10 am | |
- Hello Bill. The under seat “click” you hear is most probably the starter solenoid. So that seems to be working.
Good luck. Please let us know how you sort this out. I second what Cosmic mentioned about the starter motor brushes binding. I had the same issue as you on my 400; Doesn't start up yet I hear all the pre-ride noises & clicks. My advice (temporary fix) is to remove the left passenger seat peg so that the motor is accessible from underneath and use a t-shaped hex socket wrench to give the motor a few good taps before starting the SW up. In the long run, you will have to replace the starter motor brush. (See pic below of my SW's crusty starter motor brush) ![2006 SW won't start, just clicks Start_13](https://i.servimg.com/u/f67/20/42/52/90/start_13.jpg) |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | steve_h80 Silver Wing Guru
Number of posts : 1021 Location : Teesdale, UK Points : 4140 Registration date : 2016-05-15
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Sun Jul 03, 2022 8:07 am | |
| If it's been running the same battery for 15 years I'm not at all surprised it's tired. You could try a jump starter if you have one * or a couple of jump leads to a car battery (but do not start the car). If it fires up then it's new battery time. * and if you don't have one it's certainly worth getting one. |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | okcseoul Scooter Rider
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Mon Jul 04, 2022 1:04 am | |
Good luck. Please let us know how you sort this out. Thanks Cosmic...I believe it is the starter motor brushes are binding and not contacting the starter armature. However somebody said there is a start relay…”check that first” … not sure what to do or where that is…? I've check the battery voltage and it is just like a new battery (not used 15 years that is how long I've had a SW, it is six months old). I took off the panel of the rear passenger foot peg (not the seat peg) and I couldn't see anything that looked like a starter motor. I tapped on a few things, but to no end. There is a click sound (one loud click) when I push the starter button. So I need to know where the starter motor is located and try to get it to turn when somebody is pushing the start button at the time that it clicks. Open to your suggestions. Thanks |
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Mon Jul 04, 2022 7:25 am | |
Thanks Yeah so once you remove the left passenger foot peg, you should be able to see what is the top part of the engine block. The starter motor (cylindrical looking) is in front of this engine block. If tapping it doesn't work, then you must give it a few good strikes. Worked like a charm while I was finding a mechanic who could repair my starter motor. P.S Do go easy on the strikes though. Striking too hard with a stainless steel tool will leave some dents (albeit negligible on the engine block exterior. |
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Tue Jul 05, 2022 5:27 am | |
P.S Do go easy on the strikes though. Striking too hard with a stainless steel tool will leave some dents (albeit negligible on the engine block exterior. As you instructed I went easy on the strikes, but I still couldn't see enough shape to know whether it was the starter motor or solenoid or just another part. Anything within reach of the tool's reach I struck and low and behold the bike started. I drove it to the repair shop and they ordered a solenoid and a brush part to change. He will take it apart and see what the problem might be. We both tried to see if we could get it to not start again, but it continued to start without a hiccup. My SW has been so dependable through the summer, winter and rainy seasons of these fifteen years, but I know it is starting to need more attention. (66,200 kilometers = 41,375 miles) The repair shop gave me a TMax to ride and told me to come back tomorrow morning. He must be giving me the temptation to get a newer bike. Haha...Thanks again for all your help and advice! |
![2006 SW won't start, just clicks Empty](https://2img.net/i/empty.gif) | Subject: Re: 2006 SW won't start, just clicks Tue Jul 05, 2022 9:21 am | |
Haha...Thanks again for all your help and advice! Great to hear you were able to get your SW into the repair shop! Do keep us updated on the progress |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | | 2006 SW won't start, just clicks | |
Similar topics | ![+](https://2img.net/s/t/12/97/68/i_tabs_more.png) |
