LED Indicators - Hyper Flash I_icon_minitimeby balconio Today at 7:24 pm
LED Indicators - Hyper Flash I_icon_minitimeby zrx212 Yesterday at 4:40 pm
LED Indicators - Hyper Flash I_icon_minitimeby Meldrew Yesterday at 4:37 pm
LED Indicators - Hyper Flash I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
LED Indicators - Hyper Flash I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
LED Indicators - Hyper Flash I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
LED Indicators - Hyper Flash I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
LED Indicators - Hyper Flash I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
LED Indicators - Hyper Flash I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
LED Indicators - Hyper Flash I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
3 posters
DavidL
Number of posts : 14
Registration date : 2022-06-17
LED Indicators - Hyper Flash Empty
PostSubject: LED Indicators - Hyper Flash   LED Indicators - Hyper Flash I_icon_minitimeSun Oct 30, 2022 7:38 am
Fitted LED bulbs to front indicators. Now have the 'hyper' flash issue.
Doing a bit of searching there seems to be 2 ways of rectifying. A resistor in parallel or replace flasher relay with a LED compatible one. I prefer the replacement of the relay option.
Anybody done this? Is the relay under the front fairing? I would like to pre-purchase a relay and need to confirm connection type. I see 2 pin and 3 pin relays.
Any suggestions appreciated.
Number of posts : 381
PostSubject: Re: LED Indicators - Hyper Flash   LED Indicators - Hyper Flash I_icon_minitimeSun Oct 30, 2022 7:55 am
I researched this in the past- I may be wrong, but it looks like the relay is soldered to the board and not a simple plug and play type (like in the older Honda bikes)- another option (that I selected) is to use LEDs with the resistor built in so you don’t get hyper flash. They are 1156 type- I’ll edit this post if I can find what I used.
Here they are:
https://www.amazon.com/gp/product/B096JVGXTY/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
I really wanted switchbacks so they’re white when not in use as indicators but yellow when you hit the switch- the issue is that they are 1156 bulbs so 1 contact only vs an 1157 that has 2 (even as yellow, they're still pretty bright)- there’s likely a way to wire it to work but I wouldn’t know how to do that.
PostSubject: Re: LED Indicators - Hyper Flash   LED Indicators - Hyper Flash I_icon_minitimeSun Oct 30, 2022 11:39 am
There is a workaround for bypassing the embedded turn signal flasher and replacing it with an electronic flasher relay. But your LED bulbs at ~$23 ; pair would be a lot easier than adapting a flasher relay to the front wire harness.
DavidL
PostSubject: Re: LED Indicators - Hyper Flash   LED Indicators - Hyper Flash I_icon_minitimeSun Oct 30, 2022 11:59 am
Erdoc48 wrote:
Here they are:
Thanks, I've found them on the Amazon UK site. Be easier than messing with the relay. Either way fairing off again Neutral
» Tire Wear Indicators
» Voltage of Turn Indicators"?
» Kuryakyn LED Battery Gauges
» Hyperpro Fork Springs
» Headlight; Flash to Pass Button, on Left Grip
