| | Annoying Vibrations | |
Carlos Scooter Rider
Number of posts : 10 Age : 60 Points : 116 Registration date : 2024-06-29
| Subject: Annoying Vibrations Sat Jun 29, 2024 2:40 pm | |
| Hello from Portugal
I have a 2012 Honda SW-T 600 with 28,000 km and now I get an annoying vibration that appears there between 3500 rpm and 4000 rpm. It is only at this stage of the rotation that vibration appears, having increased over time. I don't know what the problem is. If anyone has had a similar problem and can help, I would appreciate it. Otherwise, it's a fabulous machine that I'm very happy with. Thank you.[b][b][b]b] |
Number of posts : 355 Age : 71 Location : Bristol, UK Points : 1017 Registration date : 2022-12-23
| Subject: Re: Annoying Vibrations Sun Jun 30, 2024 6:47 am | |
| Hi Carlos, and welcome to the forum btw.
Any chance you can define roughly where you think the vibration may be coming from, as in low and behind you (possible drive train) or under you (possible worn out rollers) or in front (as in loose body work). I have personally found several annoying rattles over time coming from the running board support framing, having to take all the Tupperware off to apply Loctite to numerous chassis fixing bolts. Because of the quoted rpm that the vibe hits I would consider removing the drive chain cover to inspect the belt(for fraying and stretch, belt slap marks on the bottom of the cover) and the rollers for flat spots and debris dust. A quick search of the forum should bring up serval " how too" postings (including tools used).
Hope this helps, awaiting your reply.
Be safe, be seen! |
| Subject: Re: Annoying Vibrations Mon Jul 01, 2024 8:45 am | |
| - JohnyC wrote:
- Hi Carlos, and welcome to the forum btw.
Be safe, be seen! Thanks for your comment. The vibration I'm talking about comes from the left side of the scooter, at the rear, where the transmission system is located. It's a very strong vibration, between 3500/4000 rpm sometimes accompanied by a strange noise. Before or after this rev range, it runs flawlessly, smoothly and without any kind of vibration. |
| | | john grinsel Curmudgeon
Number of posts : 3309 Age : 85 Points : 9411 Registration date : 2009-08-18
| Subject: Re: Annoying Vibrations Mon Jul 01, 2024 9:59 am | |
| simple fixnoise probably from drive belt---put on brake, run engine up against brakes for 1015 second--think it burng any glaze off---worked for me with 2 new Silverwings and 100,000 miles |
| Subject: Re: Annoying Vibrations Tue Jul 02, 2024 2:22 pm | |
| - john grinsel wrote:
- simple fixnoise probably from drive belt---put on brake, run engine up against brakes for 1015 second--think it burng any glaze off---worked for me with 2 new Silverwings and 100,000 miles
Hello John, I've been told to do that, but I haven't done it yet for fear of causing any damage, especially to the clutch. Unfortunately in these last two weeks I haven't been riding the scooter, because I'm suffering from tendinitis in my shoulder and so I have to avoid it, for now. But whenever possible, I make some trips here in Portugal that I'll have all the peace to share here on the forum, with photos, as soon as I know how to post them. |
Number of posts : 557 Age : 65 Location : Ocala, FL Points : 1953 Registration date : 2020-12-26
| Subject: Re: Annoying Vibrations Wed Jul 03, 2024 11:02 am | |
| Not knowing more of scooter condition or service history, it could be "Belt Slap" which is kinda normal at that rpm range, but is usually exaggerated by an old belt or a cvt needing cleaning/servicing, at that mileage/age the belt/cvt should had been replaced/cleaned/serviced several times already. |
| Subject: Re: Annoying Vibrations Wed Jul 03, 2024 12:08 pm | |
| - zrx212 wrote:
- Not knowing more of scooter condition or service history, it could be "Belt Slap" which is kinda normal at that rpm range, but is usually exaggerated by an old belt or a cvt needing cleaning/servicing, at that mileage/age the belt/cvt should had been replaced/cleaned/serviced several times already.
Hello I bought the scooter two years ago with 17 thousand km. At 24,000 km, the overhaul was carried out with the replacement of the belt, more rollers and guides, as well as the change of engine and transmission oil, and oil and air filters. In addition, the front suspension oil has also been changed to a slightly thicker one, which has changed the behavior of the scooter in cornering for the better. I'm going to ask the workshop to check and clean the transmission system, I'll give you some news later. Thank you all. I apologize for my sometimes confusing and weird English, but the culprit is Google Translate! |
| Subject: Re: Annoying Vibrations Wed Jul 03, 2024 12:51 pm | |
| " At 24,000 km, the overhaul was carried out with the replacement of the belt, more rollers and guides, as well as the change of engine and transmission oil, and oil and air filters." Well, that's good, sometimes I misread km vs miles , that's actually very low mileage for the very robust SW600, but since your vibration only occurs at certain rpms, I still believe is CVT operation related, not bearings, etc. Since belt slap is kinda normal on the SW600, due to the long belt oscillations, is really hard to determine what is normal by just looking at the wear marks on the inside of the cvt aluminum case/cover from belt hitting it, what virtually eliminated the issue for me and improved overall operation , was installing a Malossi white contra/torque spring, cheap part, but not so easy to install. BTW, make sure they installed a Honda or similar quality belt, Mitsuboshi, Malossi, etc. https://www.malossistore.com/en/us/white-variator-adjuster-spring-external-81x130-mm-wire-7-mm-k-15-honda-silver-wing-600-4t-lc-2912478_w0-hosi600-M-P |
| Subject: Re: Annoying Vibrations Wed Jul 03, 2024 3:10 pm | |
| Thanks for the comment. Regarding the parts I can confirm that they were original Honda and the belt was from Bandoo. By the way, there are two things I make sure to always have on the bikes I've had over the years: original parts and Bridgestone tyres. Now I'm going to see if I can call the workshop to have my scooter's drivetrain cleaned. [/url |
| Subject: Re: Annoying Vibrations Wed Jul 03, 2024 9:35 pm | |
| Another thing to check/look at is, the smooth operation/movement of the pulleys, especially the rear pulley halves, as in removing the torque spring and making sure they move (open and close) smoothly, the OEM grease in there is not very good quality, on my 2012 the grease was very dry at just 11k miles (18 km), about 3yrs ago. I did a full teardown/inspect/replace/lube, etc., as needed when I got scooter, no problems since. |
Number of posts : 1024 Location : Teesdale, UK Points : 4170 Registration date : 2016-05-15
| Subject: Re: Annoying Vibrations Thu Jul 04, 2024 2:30 am | |
| Carlos, as said above there is some harmonic resonance at the 3500-4000 rev range which makes the belt slap about. I expect this is what you are experiencing. You've replaced the belt and weights. Clutch problems are usually at start off and slowing down, then it just needs cleaning (an easy job). Don't worry, it all sounds normal. |
