| Subject: Stupid backrest screw Tue May 04, 2010 7:20 pm | |
| Subject: Re: Stupid backrest screw Tue May 04, 2010 7:35 pm | |
| Gently drill out and try a cheap easy-out. |
| Subject: Re: Stupid backrest screw Tue May 04, 2010 8:33 pm | |
| - bigbird wrote:
- I tried to adjust the driver's backrest on my seat. The cap screws underneath were so tight that I ended up rounding the hex drive on one.
The first time I had to remove the nut with a 6-point socket, it was incredibly tight. - bigbird wrote:
- I will have to drill the screw out. Any tips on doing that?
Or use a cutting wheel and cut right through the nut and bolt. |
| Subject: Re: Stupid backrest screw Tue May 04, 2010 8:49 pm | |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6177 Registration date : 2009-03-24
| Subject: Re: Stupid backrest screw Tue May 04, 2010 9:16 pm | |
| Not being said already, it will be easier to remove the seat and place on a work bench so you are not working upside down. You will be able to drill straight and steady. Nothing like having to twist into weird positions just to be able to reach the bolt or screw you are working on. |
| Subject: Re: Stupid backrest screw Wed May 05, 2010 10:01 am | |
| You might try a soldering gun -or old timey soldering iron- to apply some concentrated heat directly on the bolt. The idea is to 'free' the bolt from the threaded plate it screws into.
Then you'd have to use vise grips on the original bolt to remove it.
Ace / True Value Hardware usually has a selection of metric nuts & bolts. I replaced my backrest screws with stainless steel hex head bolts from the same reason.
| Subject: Re: Stupid backrest screw Thu May 06, 2010 12:16 pm | |
